747Dreamlifter
A320 With 4-Wheel Main Gear
Thu Dec 06, 2007 1:07 am
Never knew that Airbus offered their A320 with 4 wheel main gears. Searching through the photo data base it seems that only Indian Airlines/Air India flies them. Any special reason or performance advantages ??.....possible higher GTOW?
Photo © Propfreak
RE: A320 With 4-Wheel Main Gear
Thu Dec 06, 2007 1:16 am
The reason was so that they could use "rough" fields where the normal wheel loading was too high. There was a weight penalty since the bogies are heavier and the gear doors larger.
As you noticed, only one airline ordered the mod, which IIRC was done by a third party. AFAIK they are all in the process of being converted to the standard wheel arrangement, if they haven't been already.
BreninTW
Thu Dec 06, 2007 1:19 am
This is a topic that appears regularly here ... from what I understand:
The 4-wheel bogies were specced for use on runways that couldn't support the A320 using standard 2-wheels MLG. This modification was only used in India (mostly for unpaved runways).
All the A/C with 4-wheel bogies have been retrofitted with the standard MLG, since the supplier of the 4-wheel bogies has gone out of business, and they're no longer required.
For more discussion:
8 Wheel Main Gear On A-320 (by Zebfly2 Sep 19 2001 in Tech Ops) Indian Airlines Four-wheel A320 Main Gear (by A388 Aug 2 2007 in Tech Ops) Dual Main Gear On A320 (by JoePatroni Aug 1 2007 in Tech Ops) Indian Airlines A320's Main Gear Have 4 Tires (by United777 Apr 25 2003 in Tech Ops)
Thu Dec 06, 2007 1:22 pm
After the vendor of the MLG closed shop.All the A320s are gradually switching to the Two wheeled version.As the purpose why they were chosen does not exist anymore.
regds
MEL
troubleshooter
Thu Dec 06, 2007 9:11 pm
Does anybody here have some maintenance documentation on that landing gear?
This job sucks!!! I love this job!!!
Viscount724
Fri Dec 07, 2007 5:05 am
Quoting Brenintw (Reply 2):
I am fairly certain they never operated on unpaved runways, but on paved runways with a low bearing strength that couldn't take the weight of the aircraft unless it was spread over 4 wheels per side rather than two.
Fri Dec 07, 2007 10:47 am
Quoting Viscount724 (Reply 5):
Thats true.
Although the reason for choosing the MLG was for the purpose if arose.which never did.
regds
MEL
Gr8Circle
Fri Dec 07, 2007 5:33 pm
Quoting HAWK21M (Reply 6):
Thats true.
regds
MEL
Are there any airports at all in India, which have unpaved runways and would warrant an A320 service....? I can't think of any.....what did IC have in mind....?
Sat Dec 08, 2007 8:27 am
Quoting Gr8Circle (Reply 7):
Not at present.But this was a consideration at that time,in case such use arose.
regds
MEL
Users browsing this forum: Google [Bot] and 1 guest
