Blackbird
Airspeed Indicator Question
Fri Dec 07, 2007 3:23 am
Regarding airspeed indicators -- why can't they read reliably below 60 to 80 knots?
And how do they determine groundspeed if the speed-gauge isn't reliable below 60-80 knots. I was told with the 747 for example 20-25 knots was as fast as you could taxi with using full-steering... or something like that -- either way how do they determine growndspeed?
Andrea Kent
HAL
RE: Airspeed Indicator Question
Fri Dec 07, 2007 3:34 am
Quoting Blackbird (Thread starter):
Today, we all use GPS groundspeed as our most reliable indicator for taxiing. It's shown somewhere on almost every primary flight display or Nav display. Even in our old round-guage DC-10's we could pull up the info on the FMS computer. In the old days??? I was still puttering around in 2-seat Cessnas so I don't know.
HAL
One smooth landing is skill. Two in a row is luck. Three in a row and someone is lying.
PhilSquares
Fri Dec 07, 2007 3:36 am
10 Knots for a 90 degree turn. On the 400 there is a ground speed readout on the ND. On the classic, you select TK/GS on the INS and there you go!
The ground speed is computed via the IRS/INS, just as it would be in flight.
Fly fast, live slow
Jetlagged
Fri Dec 07, 2007 3:43 am
Airspeed below 60 knots is not useful information on an airliner.  Smile Anyway, the ASI cannot read groundspeed, because of wind effects.
The 747 classic had a groundspeed readout based on INS velocity available in digital form on the HSI. The dedicated TAS indicator stops reading below about 115 knots. The 744 of course has similar data available on EFIS.
I think 10 knots is regarded as a better speed for full steering angle on a 747. Above 20 and you will start to get scuffing vibration.
tdscanuck
Fri Dec 07, 2007 6:43 am
There is also a speed sensor on the wheels. It's used to drive the autospoilers and antiskid, among other things.
Tom.
DH106
Fri Dec 07, 2007 6:57 am
ASIs work by measuring a pressure differential between static and dynamic flow pressure.
Like everything else 'pressure' related (e.g. lift, drag etc.) this differential doesn't vary linearly with speed but is a function of speed squared.
So at low airspeeds ASIs become disproportionately more inaccurate as the pressure differential measured becomes relatively tiny.
...I watched c-beams glitter in the dark by the Tanhauser Gate....
KELPkid
Fri Dec 07, 2007 7:22 am
Well they do in some aircraft...  Wink [like many of the ones I fly...]
I guess the pitot tube just can't transfer enough pitot below certain airspeeds Big grin
3MilesToWRO
Fri Dec 07, 2007 8:51 am
Every measuring device has its range of valid values and it must not necessarily begin from 0. Actually I think hardly ever it does. Your car's speed indicator also doesn't start exactly from 0, does it? (Well, if if does it's only pretending  Wink )
If you need reliable values of speeds in flight, you need a device that works well in range, say, 100 to 500 knots (for an airliner, I mean). What's less or more is not very useful (or not so important) so the design of speedometer can be less accurate (up to total uselessness) for it.
FredT
Fri Dec 07, 2007 6:04 pm
You are moving a mechanical needle through air pressure. The air pressure is roughly proportional to the airspeed squared. At 60 knots it is one quarter of the pressure at 120 knots. At some point or other the friction etc in the mechanics will become significant enough, compared to the air pressure, for the resulting errors to be large enough to render the reading inaccurate to the point where it is effectively useless. At that point, insert peg in instrument face.
As for finding a nice, suitable taxi speed there are two TSMDs, taxi speed monitoring devices, in most commercial aircraft. They operate mainly by measuring the changes of angles between visually recognizable features in the aircraft surroundings, and are typically able to give a somewhat rough but exact enough estimate of actual speed over ground for taxi. These are installed in TSMDHs, taxi speed monitoring device holders, in the cockpit in order to give the devices a relatively unobstructed view of the surroundings. The TSMDs are unfortunately prone to wear and must be replaced every eight hours or so, at least. To facilitate quick installation and removal the TSMDs are usually mounted to the TSMDHs through four-point belts equipped with quick-release buckles. They are almost always combined with the control actuators. They are very sensitive devices, and great care is taken to keep their environment within the specified operating range. Most people working in aviation agree that they are the single biggest source of trouble. Still, few would like to do without them.
777236ER
Fri Dec 07, 2007 8:59 pm
Quoting FredT (Reply 8):
Did you know that TSMDs cause more than half of all crashes? Amazing, but true.
Jetlagged
Fri Dec 07, 2007 10:57 pm
Quoting Tdscanuck (Reply 4):
True, but no speed readout is provided to the crew from this source.
737tdi
Fri Dec 07, 2007 11:12 pm
Had a write-up the other day. Control wheel feels stiff (just so happened it was the night of the Cowboy/Packer football game). Amazingly enough after removal of the TSMD/F.....'d up stick actuator, the aircraft was inspected and returned to service with no faults found. Go figure. Have to say though, this is very rare with our flight crews.
737tdi
Tornado82
Sun Dec 09, 2007 7:56 pm
Quoting Jetlagged (Reply 3):
Yep, the new G1000 equipped light piston singles are probably the best examples of this because of the better resolution of their ASI's. Talking to a gentleman with a "glass" C172 while sitting on the ground with the electrics turned on to show me his new toy... the thing was dancing around up to 28kts or so on a windy day. Theoretically, had we been taxing on a paralllel to a runway so that the wind was a tailwind, we could have gone 28kts GS and the ASI would read 0.
Users browsing this forum: sadiqutp and 2 guests
