OHLHD
Is This Normal On A B737-600? ( Video)
Sat Dec 22, 2007 1:23 am
Hi everyone. I recently travelled on a SK B737-600 and after some 20 B737 flights I saw this for the first time and was thinking if this shaking is actually normal on a B737 in general or on other aircrafts. I was not scared or so, just curious because I have not seen something like that before.
Any info is appreciated.
RE: Is This Normal On A B737-600? ( Video)
Sat Dec 22, 2007 1:40 am
I'm not an expert but it doesn't look unusual. I have seen that sort of shaking a few times. The canoe in the film is pretty close to the exhaust.
I'll let the experts correct me if I'm wrong.
OHLHD
Sat Dec 22, 2007 1:43 am
Quoting Starlionblue (Reply 1):
Actually it was only shaking while the flaps were out. During cruise there was no movement. I am always excited to find something new about A/C's. Big grin
bond007
Sat Dec 22, 2007 1:54 am
Were the spoilers deployed ??
These can have a significant effect on vibration. Most pax I talk to assume that it's turbulence when they are deployed !
Jimbo
OHLHD
Sat Dec 22, 2007 2:08 am
Quoting Bond007 (Reply 3):
No not yet. As you can see we were not that high anymore ( approx. 4-5min before touch down) but I saw it also on the ground while taxing for departure.  Smile
See this video a little time after I took the first one. Here you see more of the wing but nothing shaking anymore.  Smile
wilco737
Sat Dec 22, 2007 2:27 am
You are not allowed to use spoilers once flaps are higher than 10 degrees on the 737... Only on ground after touchdown...
And for the shaking: not unusual when flaps are extended. The airflow is a lot different than during cruise flight with a clean profile... The air is a lot more turbulent with flaps extended and that makes this thing shaking a bit.
If you have the chance, check out the stabilizer after touchdown of a landing aircraft with a lot of recerse thrust! This thing is shaking like hell then  Wink
WILCO737 (MD11F)
 airplane
AirframeAS
Sat Dec 22, 2007 2:28 am
Its perfectly normal. There is an open gap between the flap and the canoe fairing underneith, not much of it but there is a gap. It's something that I wouldn't worry about.
OHLHD
Sat Dec 22, 2007 2:42 am
Thanks guys! As I said I am always full of joy if I see/learn something new about an A/C. And this was really the first time I saw this.  Smile
Sat Dec 22, 2007 8:48 am
The TE Flap Fairing in question has play.
regds
MEL
AAR90
Sat Dec 22, 2007 9:42 am
Quoting WILCO737 (Reply 5):
Huh? Certainly no such limitation on -800's.
Quoting OHLHD (Thread starter):
Nothing abnormal in either video... on any aircraft I've flown or flown on... you see that quite a lot.
Sat Dec 22, 2007 1:20 pm
Quoting AAR90 (Reply 9):
The Movement of the TE Flap Fairing does indicate play which can def be detected if moved by hand on the Ground.
regds
MEL
wilco737
Sat Dec 22, 2007 1:23 pm
Well, at my airline we werent allowed to use the speedbrake when flaps are higher than 10 degrees... Maybe it is different at your airline...
WILCO737 (MD11F)
 airplane
AntonovA330
Sat Dec 22, 2007 6:02 pm
I've seen the same on AVROs. There was also quite a shaking of the flap fairings on taxiing and at take off.
Good day to you sir! Please turn left, your seat is in the first row.
Users browsing this forum: wagz and 2 guests
