Blackbird
DC-8 Tailcone Aerodynamics
Tue Dec 25, 2007 4:02 am
How did the DC-8's tailcone fare compared to the modern screwdriver tailcones on the MD-80's, MD-11's, and B-777's?
Andrea Kent
EMBQA
RE: DC-8 Tailcone Aerodynamics
Tue Dec 25, 2007 4:30 am
Why does this one keep coming up...?? This is the third time its been asked this fall.
metroliner
Tue Dec 25, 2007 3:11 pm
Andrea, you are obsessed...  Wink
Are you writing a thesis on the aerodynamics of the DC-8?
Toni
Set the controls for the heart of the Sun
Blackbird
Wed Dec 26, 2007 3:44 am
EMBQA,
Simple, couldn't get an answer. So I kept asking.
Metroliner,
LOL, Perhaps!
The question kind of had to do with the screw-driver MD-80 tail and 777 tail. I was told by somebody that the DC-8's tail was in a way a screwdriver type design, but I'm not exactly sure I understand unless you mean a triangular cross section. But I'm still wondering if the 2D type MD-80 or 777 would work equal or better.
Andrea Kent
113312
Wed Dec 26, 2007 3:00 pm
Screwdriver type tail cone? McDoug called it a Beaver Tail. First Gen jetliners didn't put much emphasis on a tail cone other than to try to fair out the fuselage smoothly. In later years, additional research was done to the flow and drag in this area particularly for tail mount engine designs, such as the MD-80, which induce flow at the tail with the engine thrust. Lessons learned from that airplane were applied to other designs such as the MD11.
AirframeAS
Wed Dec 26, 2007 7:45 pm
Oh, lord...kill me now!  box   sigh
Blackbird
Thu Dec 27, 2007 1:31 am
113312,
Regarding the designation of the type of tailcone use, I'm glad to know the correct designation! Thanks,
Are you sure about that early commercial jets didn't put much emphasis on the tailcone? I was told by one person, (although I have not been able to substantiate or verify this; which by the way, is the reason I'm asking questions here to verify) that the DC-8's tail-cone was highly efficient and while conical (or more like rounded triangle) behaved much like a screw-driver/beaver-tail tailcone. Is that true or not?
The same person also told me that the beaver-tail was largely incorporated into the MD-80 because it had a different tail design (Again, not entirely able to substantiate this -- other than what you said about the exhaust flow over the tailcone; but the MD-11 and 777 don't have engines on the tail, although they do use different tailcones than the DC-8, honestly, I don't know)
Andrea Kent
Blackbird
Sat Dec 29, 2007 3:45 am
Does anybody have any additional data?
Andrea Kent
AirframeAS
Sat Dec 29, 2007 2:52 pm
Quoting Blackbird (Reply 7):
Yeah. Google.com
Blackbird
Sat Dec 29, 2007 5:24 pm
I'll look, but I doubt I'd find anything useful on google regarding the tailcone of the DC-8 and how it would compare to a beaver-tail / blade-tailcone.
Note: I just looked, all links lead back here...
Andrea Kent
[Edited 2007-12-29 09:27:24]
Starglider
Sun Dec 30, 2007 1:16 pm
Quoting Blackbird (Reply 9):
Andrea Kent
As i've mentioned a while ago, it is useless to just look at just one component (in this case the tail cone) to ask why it is shaped like it is and how it could be improved or be compared with other configurations. It is the sum of all the aircraft's aerodynamics (and engineering compromises or even paradoxes) which determine the final shape of any aircraft. What i mean is that sometimes one would like to sculpture a great aerodynamic shape but may need compromise for other than aerodynamic reasons. The DC-8 is no exception to that rule, certainly not when it was designed with 1950s technology.
May i suggest you write McBoeing a letter and throw in all your charm and kindly request from them all the proprietary aerodynamic and engineering data regarding the DC-8? And then do the same for the MD-80, MD11 and B777, the aircraft you want to compare the "8" with.
Only then you will find the answer as to why the tail cone on the "8" is as it is and only then you will get a factual answer as to how it compares to other aircraft. Without such data it remains a guessing game.
Starglider
Blackbird
Sun Dec 30, 2007 2:49 pm
Starglider,
I suppose you're right about just looking at one component. But it is an interesting question none of the less -- would a blade-cone have worked on an older fuselage like that?
Andrea Kent
Starglider
Sun Dec 30, 2007 9:49 pm
Quoting Blackbird (Reply 11):
As an educated guess without going into the numbers, perhaps it would work on the DC-8 since it did not have an APU in that area (or anywhere else for that matter) and basically already has somewhat blade-cone features. So if there is no other mechanism or structure in that area requiring the existing tail cone contours, there would be no argument not to pinch it into screwdriver cone if that proved to be an advantage. Provided the tapering starts aft of the horizontal stabilizers/elevators to avoid altering those to prevent a gap between the fuselage and the elevators. Aerodynamically that would probably amount to extending the tail cone somewhat beyond the current aft most contour which means slightly more surface area.
Question then is if the improved aerodynamics, as is claimed by installing a screwdriver tail cone on current aircraft types, weigh up against a slight increase in drag due to increased surface area compared to the original DC-8 design. Maybe a (slight) reduction in base drag at the trailing edge of the pinched cone tips the scale in favor of such alteration.
Again this is just an assumption. To really find out would require wind tunnel testing of a complete aircraft model and compare it with the original design data.
Starglider
Blackbird
Mon Dec 31, 2007 9:25 pm
Starglider,
Thank you for your response. Just out of curiousity, the DC-8 doesn't have any structures or mechanism in that particular area does it? Also, what does "base drag" mean?
BTW: I'm not sure if you could answer this one, but how much surface area could possibly be increased as a result from such a tail modification?
Andrea Kent
Starglider
Tue Jan 01, 2008 12:05 pm
Quoting Blackbird (Reply 13):
Aft of the rudder trailing edge, not that i am aware of except a tail running light.
Base drag or base pressure drag is related to vigorous unsteady motions in the near wake of an aerodynamic body due to vortex shedding (in this case at the DC-8 aft fuselage). At the tail cone area the near wake flow aft of the cone, the lift-drag-ratio decrement depends on how blunt the contours of the cone are. Boeing's blunt B737 tail cone is a good example whereby it is visible what measures were taken to counter this problem by adding vortex generators in this area. If more blunt, base pressure is lower compared to ambient pressure which means an increase in drag (suction drag) which is referred to as base drag. This phenomena results in a considerable drag increase at transonic speeds if no measures are taken to reduce this base drag. Comparing the DC-8 tail cone with the one on the B737 gives me the impression that the cone on the DC-8 is more efficient than on the B737 because it is a clean design and more pinched and it does not require additional measures such as vortex generators.
Base pressure drag is even more evident on supersonic aircraft, where base drag, depending on aerodynamic shape of the aircraft, can result in a considerable drag increase up to approx Mach 1.3 which results in a significant lift-drag-ratio decrement when compared to speeds of Mach 0.8. After M 1.3 the negative pressure slowly shifts to a higher pressure with increasing Mach number. Above Mach 2.5 it can result in a favorable increment of about 2 percent in terms of lift-drag-ratio.
But that is a different story for another time so back to the DC-8 example. A different class of flows is obtained by eliminating the vortex-shedding instability with a splitter plate in the near wake. This increases the base pressure and reduces drag, the mechanics in the near wake is now governed by unsteady motions (turbulence) in the separated free shear layers.
Essentially, the pinched or screwdriver tail cone functions as such a splitter plate.
Not much, most likely it would result in a slight lengthening beyond the existing cone trailing edge and the upper contour changed in a straight line aft as an extension of the aft fuselage where it pinches and ends at the perpendicular sharp trailing edge. The bottom contour could be an extension of the fuselage bottom contour ala B777 or MD11. Alternatively it could be shaped like the MD80 where the bottom contour changes to a horizontal line parallel to the upper contour. Either way this would increase surface area when compared to the original cone design. Only after testing these changes against the original design (wind tunnel and/or CFD) will give you a definitive answer to which shape is the most efficient.
Hope this helps you.
Starglider
Blackbird
Tue Jan 01, 2008 5:19 pm
Dear Starglider,
Where's the tail-running light? Is that the one that lights up the vertical-stab?
Andrea Kent
Starglider
Tue Jan 01, 2008 7:29 pm
Quoting Blackbird (Reply 15):
No, those are logo-lights and are installed on the upper surface of the horizontal stabilizers with the beam pointed to the vertical stabilizer left and right surfaces (some aircraft have the logo lights at the wing tips with the beam pointed to the respective vertical stabilizer surfaces).
The tail running light is a white light at the aft end of the tail cone as part of the navigation light system (which also includes a red light at the left- and a green light at the right-wingtip) enabling to determine an aircraft's relative visual position/direction. Additionally, not on the DC-8 back then but some of the current airliners also have a high intensity recognition light (strobe light) in near the white navigation light at the tail.
Starglider
Blackbird
Tue Jan 01, 2008 8:18 pm
Dear Starglider,
Would there have been problems fitting a tail-running light to a blade-cone back during the DC-8's era?
Andrea Kent
Starglider
Tue Jan 01, 2008 10:49 pm
Andrea,
No problem at all. As an example, look up a close-up picture of a B777 pinched tail-cone and look at the top and bottom corners of the trailing edge. No reason for it to have been a problem fitting a light back then if such a configuration would have been chosen for the DC-8 design.
Starglider
Blackbird
Thu Jan 03, 2008 12:46 am
Starglider,
Makes sense... the Convair 880 used a 2D tailcone... it wasn't really a blade (it had some bluntness in the back)
A blade cone would have lengthened the tail... would it have lengthened the aircraft (The horizontal stab sweeps back a lot so I'm not sure if it would increase the overall length or not) significantly? How much would it have lengthened about if you guessed?
Andrea Kent
Starglider
Sat Jan 05, 2008 11:58 am
Quoting Blackbird (Reply 19):
Depends on the how much the tail-cone taper would be changed. Looking at a plan view (top-view) drawing of the DC-8 i draw this conclusion: Since the taper of the aft fuselage along the root of the horizontal stabilizers is a good reference and, as mentioned before should not be altered, leaving the taper ratio unchanged the apex of the pinched tail-cone would be about 2 ft beyond the current overall dimensions dictated by the aft tips of the horizontal stabilizers. So yes, it would have lengthened the aircraft somewhere between 1 to 2 ft.
But it remains a guess. True dimensions and shape would have to be tested.
Starglider
Blackbird
Sat Jan 05, 2008 4:28 pm
Wow, the tailcone would with a blade-tip have extended all the way past the back of the tips of the swept-horizontal stabilizer?
Andrea Kent
Starglider
Sun Jan 06, 2008 11:07 am
Quoting Blackbird (Reply 21):
Yes. Between 1 or 2 ft beyond existing overall dimensions. Perhaps even a little bit more if the taper ratio were to be reduced near the end of the tail-cone. All hypothetically and depending in rigorous testing of course . . . . .  scratchchin
Starglider
Blackbird
Sun Jan 06, 2008 1:26 pm
Starglider,
That's one long tail there, lol... so it would be a lot longer than the beaver-tail/blade-cone than the MD-80, MD-11, and B-777 are fitted with to get any benefit?
Andrea Kent
Starglider
Sun Jan 06, 2008 5:45 pm
Quoting Blackbird (Reply 23):
to get any benefit?
Test it  stirthepot  to get your answer. Just talking about it to find the answer is like nailing jelly to the wall.
Starglider
Blackbird
Sun Jan 06, 2008 8:46 pm
Starglider,
How the hell would I test it? It ain't like I own a wind-tunnell (That would be an interesting conversation piece if I did, though wouldn't it?)
By the way, is this sort of what you were talking about in regards to the tailcone? Or were you thinking longer?
http://i161.photobucket.com/albums/t240/AVKent882/45517_1198322551.gif
(Photo by Nicolas Janssen)
Andrea Kent
[Edited 2008-01-06 13:19:18]
Starglider
Sun Jan 06, 2008 11:32 pm
Quoting Blackbird (Reply 25):
Sure would be interesting. And if you don't own one (yet) you could perhaps rent some time in one?
Nice impression of what it could look like but slightly longer when i calculate from the plan-view drawing mentioned in reply 20. And when extending the fuselage top contour aft, i come up with this:
Starglider
[Edited 2008-01-06 15:36:36]
[Edited 2008-01-06 15:37:20]
Blackbird
Sun Jan 06, 2008 11:46 pm
Starglider,
What possible point would that serve? Waste a load of money on a hypothetical "what if"?
Wow, that's a long tail! Out of curiousity, to make absolutely sure: If such a plane was designed from the get-go with a blade-cone, not modifying the already extant tail with the blade-cone, you'd get the same length result?
Andrea Kent
Starglider
Mon Jan 07, 2008 6:35 am
Quoting Blackbird (Reply 27):
Your call, since you want an answer to this hypothetical "what if" question.
Unless you could travel back in time and be part of the DC-8 design team, the airplane coming from the get-go design you suggest would simply not be the DC-8 as we know it and you would have had the answer to your question decades ago.
Starglider
Blackbird
Mon Jan 07, 2008 6:06 pm
Starglider,
It's just a hypothetical, much in the same way that XB-70 drawing with F-22-esque features was. (By the way, I found out in this book I just recently got... I'm not sure how up to date it is, it seems as if a few dates were off, but it mentioned the F-108 Rapier had thrust-reversers incorporated into the design
Yeah that's it, I have a secret time machine in my basement and only plan to alter the shape of the tail of an old aircraft from the fifties -- not buy stocks that were then worthless and would later become worth a bundle, convince the parents of people I didn't like to not marry each other so they'd never have them, and would never exist to bother me, come up with a few simple inventions which could be done with technology from the era and make some cash off it, and tell a guy who was a friend of mine to persue a date with a girl who he was attracted to before she started dating another guy, and many years later would be married by the time he encountered her again...  Yeah sure
Andrea Kent
Starglider
Mon Jan 07, 2008 10:12 pm
Quoting Blackbird (Reply 29):
Either way, you have been searching for an answer to your tail-cone question for some time now. At a point in time you would have to put theory into practice to find the correct answer if it could improve the DC-8 aerodynamics. "Hypothetical" is as far as Leonardo da Vincy came with the helicopter, his design was never put to any practical use.
Yes, that is correct, The F-108 (final) design had J-93-GE-3AR turbojets with thrust reversers before it was canceled.
May i ask which book you are referring to?
Never say never . . . . . . .
"All that we see or seem
Is but a dream within a dream"
- Edgar Allan Poe -
Starglider
Blackbird
Mon Jan 07, 2008 10:43 pm
Starglider,
I asked for a long time because I couldn't get an answer. I got an answer only very recently. The last question I was asked was kind of a what-if (Sort of looking for a realistic answer to a hypothetical question), much in the same way the XB-70/F-22 hybrid was kind of a what-if. It was pretty cool also.
BTW: Regarding Leonardo da Vinci's helo design... would it have worked? Hey, it's a good question!
VALKYRIE
North American's Mach 3 Superbomber
Dennis R. Jenkins & Tony R. Landis
One of the biggest books I've ever seen about the XB-70, and it had lots of cool graphics -- some I've never seen before. Needless to say I had to buy it (Saw it at the bookstore a few days ago)
Even if I could travel back in time, I doubt I'd seriously want to alter anything. Who knows what effects it would have?  Wow!
Andrea Kent
Starglider
Tue Jan 08, 2008 12:07 am
Quoting Blackbird (Reply 31):
It sure was.
Sure, it is a good question. But would it have worked? Maybe, history has proven that Igor Sikorsky found better way. If the da Vincy design was useful we would have seen the concept in the air by now.
VALKYRIE
Great book, most detailed referrence on the subject aircraft to date, i have it on my bookshelf, it never needs dusting off.
One may have countless paths to chose from but you can only make one choice and travel a single path.
Ultimately, that is why the DC-8 tail-cone is shaped like it is and da Vinci never flew his helicopter design.
Starglider
Blackbird
Tue Jan 08, 2008 3:00 am
Starglider,
Regarding the F-22/XB-70 hybrid with the B-58 forward TE Sweep, would you be bothered if I took that drawing to a 3D artist and see if I can get someone to make a 3D rendering out of it?
I looked at Da Vinci's helicopter design. I suppose if it didn't use cloth and had slots between the spiral shaped wing in key places it would have produced plenty of lift... but it would have needed that little aft rotor to prevent it from spinning all over the place. Sikorsky got it right...
It's amazing the amount of pictures in it. Especially the Rapier (The early drawings and the 1960 drawing after it was cancelled but was drawn up anyway because there was no suitable competitor), and the Boeing B-804-4
Andrea Kent
737tdi
Tue Jan 08, 2008 3:18 am
Blackbird: One thing you might have to put into the equation of changing the design of the DC8 tailcone, the airflow across the elevator control tabs is extremely critical. The DC8 having an unpowered elevator, any deviation in the original design/airflow could and probably would cause major problems. J.M.H.O. Douglas could have made it alot easier to remove though.
737tdi
Starglider
Tue Jan 08, 2008 6:34 am
Quoting Blackbird (Reply 33):
No problem, you can do what you like with it.
Starglider
Blackbird
Wed Jan 09, 2008 6:48 pm
The DC-8 Tailcone had flares in the tailcone aft of the elevators. It was part of overwater certification. If you had to ditch in the water you'd drop a flare or two at night to see the waves as you came down to ditch. The brackets and hatches (the hatches were six inches square) a few feet from the white nav light.
Would a blade-cone have been able to incorporate all that?
Andrea
Starglider
Wed Jan 09, 2008 9:05 pm
Quoting Blackbird (Reply 36):
If the flare installation was part of the design requirement then, technically i don't see a problem with such installation in a blade cone (just keep the installation at the same location at or near the same STA, BL and WL location. Not sure if with today's technology they would still be necessary or if regulations have changed through the years, no longer permitting an installation like that in an airliner.
Starglider
Users browsing this forum: flipdewaf, hotelmode, JHwk and 1 guest
