Faro
Why No Wing Fences On Tailplanes?
Thu Jan 03, 2008 6:13 pm
Admittedly winglets would seem to be too heavy for horizonal stabilisers, but what about fences or raiked wingtips? Would they make economic sense on some of the bigger widebodies?
Faro
The chalice not my son
RE: Why No Wing Fences On Tailplanes?
Thu Jan 03, 2008 7:20 pm
Would the 1900D qualify.
regds
MEL
OldAeroGuy
Thu Jan 03, 2008 8:15 pm
The point of tip devices is to reduce induced drag due to lift. Horizontal tail lift loads are usually rather low in cruise, slightly up, slightly down or zero. Therefore there isn't much h. tail induced drag to reduce.
Since h. tail induced drag improvement potential is low, I doubt the improvement would overcome the form drag and weight penalties that adding h. tail tip devices would entail.
[Edited 2008-01-03 12:18:34]
tdscanuck
Thu Jan 03, 2008 8:33 pm
Quoting Faro (Thread starter):
In addition to what OldAeroGuy said, which I agree with, why wouldn't you just expand the span? The horizontal stab isn't span limited and increasing span is the most efficient way to reduce induced drag. That's why you see gliders with huge spans, not winglets.
Tom.
JRadier
Thu Jan 03, 2008 10:51 pm
Quoting Tdscanuck (Reply 3):
Plenty of gliders out there with winglets, from the raked wingtips on the Duo Discus
Photo © Phil Vabre
to full winglets on the Discus B and DG-808 (and plenty of others).
Photo © Andrei Bezmylov
Photo © Michael Priesch - Spotterteam Graz
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and ther
KELPkid
Thu Jan 03, 2008 11:09 pm
So sure about that?
How about this guy:
Photo © Mike Freer - Touchdown-aviation
 Big grin
Sea planes seem to have fences on the tail plane, too:
Photo © Parr Yonemoto
 Wink
OldAeroGuy
Thu Jan 03, 2008 11:39 pm
Quoting KELPkid (Reply 5):
How about this guy:
Directional stability band-aids.
2H4
Thu Jan 03, 2008 11:55 pm
Quoting OldAeroGuy (Reply 2):
So why have winglets never been installed on canards? I'm thinking of the Starship, Avanti, etc. Heck, even homebuilts.
The combination of being highly-loaded and short in span seems to make them ideal candidates for winglets.
2H4
Intentionally Left Blank
OldAeroGuy
Fri Jan 04, 2008 12:19 am
Quoting 2H4 (Reply 7):
Tdscanuck has the correct answer.
With the exception of the VariViggen, all the modern canards (fighters not included) I can think of are already high aspect ratio with relatively high spans in an attempt to minimize their induced drag. Besides, adding winglets to a canard would force you to add more wetted area to the v. tail and/or wing winglets to recover directional stability.
Sounds like a poor trade to me.
2H4
Fri Jan 04, 2008 12:56 am
Quoting OldAeroGuy (Reply 8):
Interesting points. Thanks for the input.
2H4
tdscanuck
Fri Jan 04, 2008 5:51 pm
Quoting JRadier (Reply 4):
A raked wingtip is a span extension...that was my point.
Now that's interesting...I'm a bit stumped as to the aerodynamic reasoning behind that. Are there situations were a glider is span limited?
Tom.
KELPkid
Fri Jan 04, 2008 6:19 pm
Quoting HAWK21M (Reply 1):
MEL, in the Beech 1900D's case, the "winglets" on the tail are there specifically to give the aircraft enough vertical stabilizer area...this was done so that a stock Beechcraft King Air 350 tail could be used and save lots of money on production costs (of course, as we all know, it's not quite stock when you have to hang "taillets" of the horizontal stab...  Wink ).
Fri Jan 04, 2008 8:21 pm
Quoting KELPkid (Reply 11):
Thats Educational.Never knew that.Thanks.
regds
MEL
rwessel
Sat Jan 05, 2008 12:18 am
Quoting Tdscanuck (Reply 10):
Absolutely. Any glider hoping to compete in a 15m or 18m class, for example. Probably a significant majority of single seat gliders being built have 15m wings. Those with flaps can compete in the 15m class, those without flaps can compete in the standard class (which still has a 15m wingspan limit).
There's also a 20m class for two-seaters, several one design classes (formal and otherwise), an Open class, and a couple of handicapped classes.
tdscanuck
Sat Jan 05, 2008 1:27 am
Quoting Rwessel (Reply 13):
Fascinating! I had no idea (gliders aren't really my area of expertise, as I'm aptly demonstrating). This explains winglets on gliders perfectly...the canonical case for winglets is to reduce drag when you're span-restricted.
Tom.
rwessel
Sat Jan 05, 2008 2:05 am
Quoting Tdscanuck (Reply 14):
Somewhat off topic historical tidbit:
The desire for a bit more span caused quite a ruckus in the late eighties and early nineties. Before the rules were tightened up, there was a period when a large number of new composite designs with very flexible wings were first being introduced. A few builders tried to take advantage of the lack of precision and measured 15m (or whatever) for the glider in level flight (IOW, with the wings supporting 1G worth of glider), with a significant upwards bend in the wings.
Endless acrimonious debate arose over whether "15m" did, or did not, include the actions of a pair of burly wing benders.
Interestingly the rules took a bit of a compromise that did not disqualify the milder offenders (which included the vast majority of offending gliders). The nominal wingspan is now calculated with the wings in the zero G position (which means you can use stands to lift up the wing enough to make it match that shape), and you have an inch (2.5cm) of slack.
Devilfish
Sat Jan 05, 2008 4:10 am
Quoting OldAeroGuy (Reply 6):
Quite interesting then that installation of the dish for the Hawkeye did not necessitate adding any more fins to the four stabs on the Greyhound's already crowded tail? Aren't those based on the same airframe?.....
Photo © Gerhard Plomitzer
Photo © Andreas Zeitler - Flying-Wings
And equally intriguing that small and very large aircraft such as these both required (only) two proportionally sized vert stabs.....
Photo © Grzegorz Bojanko
Photo © Tim de Groot - AirTeamImages
OldAeroGuy
Sat Jan 05, 2008 7:52 pm
Quoting DEVILFISH (Reply 16):
And neither did the E-3A when the radome was added to the 707-320BAdv/C.
http://www.airliners.net/open.file?i...hoto_nr=1&prev_id=&next_id=1314053
http://www.airliners.net/open.file?i...=6&prev_id=1313315&next_id=1312820
The reason appears to be the same in both cases. The center of pressure (CP) of the radome and its supports appears to be at or aft airplane CG, thus the radome and its mounting would have a neutral impact on directional stability (Hawkeye) or might even improve it (E-3A).
Adding something like floats to a Beaver requires additional v. tail area because the float CP is forward of the airplane CG. Compare a Beaver on floats to a Beaver on wheels.
http://www.airliners.net/open.file?i...=6&prev_id=1308841&next_id=1308103
http://www.airliners.net/open.file?i...11&prev_id=1305794&next_id=1304557
You now need the additional vertical area provided by the verticals at the tips of the h. tail.
Obvioulsy, adding winglets to a canard surface would cause their CP to be in front of airplane CG. Restoring directional stability would require additional v. tail area.
Finally, the An-225 and the 747 Space Shuttle Carrier point out a different issue.
For the 747 Space Shuttle Carrier, the wake of the Shuttle lowered dynamic pressure at the v. tail, reducing its effectiveness. The verticals on the h. tail were required to restore directional stability.
The An-225, with an extensive design change, avoided the Buran wake issue by moving the v. tails out of the Buran wake.
[Edited 2008-01-05 11:56:43]
Mir
Sun Jan 06, 2008 2:56 am
Isn't one of those four stabs not necessary, but there because it would look wierd if they left it off?
-Mir
Devilfish
Sun Jan 06, 2008 11:13 pm
Quoting OldAeroGuy (Reply 17):
Thank you very much for the explanations. Much appreciated.
