TupolevTu154
Cessna Stationair Etc. Weight And Balance Issues?
Thu Jan 03, 2008 9:19 pm
Evening everyone.
Whilst browsing through the database, and having seen them "in the flesh", Cessna Stationairs and Piper Cherokee 6's, amongst others, look like they could be prone some weight related issues.
Photo © Jonathan Rankin
Photo © Andrew P Scott
How much of a danger is there of the aircraft "popping a wheelie" like that infamous Korean MD11 photograph? How is the weight balanced to ensure the rear fuselage doesn't touch the ground, should the rear seats be occupied?
I'm assuming some description of ballast would be required in the front of the aircraft, or in cruise, some serious trimming.
Any insight as to the prevention of an incident would be appreciated.
Tom
[Edited 2008-01-03 13:20:04]
cptspeaking
RE: Cessna Stationair Etc. Weight And Balance Issues?
Thu Jan 03, 2008 10:43 pm
I've flown a 206 at Max Gross...the tail comes pretty close to the ground, especially before you start the engine, but once you get it running, the nosewheel strut compresses and it's not that much of an issue... In this case, I make it a point to put somebody up front first before loading the rear passengers to further reduce the chances of the plane coming back on the tail. Also, the 206 and PA-32s are designed that way...I've never seen one that doesn't sit low in the back...
All airplanes have weight and balance limitations that are clearly laid out in the POH. This data is modified for any changes to the airplane also, whether it be an avionics upgrade, new interior, bigger fuel tanks, etc. The manufacturer establishes limits for how much weight can be put where in the airplane so you don't run into issues like this. If you follow the rules, you shouldn't have any issues...if you bend the rules a little, you run a greater risk of damaging the aircraft.
...and don't call me Shirley!!
2H4
Fri Jan 04, 2008 12:01 am
Quoting CptSpeaking (Reply 1):
Man, what a great pilot name that would be....
2H4
Intentionally Left Blank
cptspeaking
Fri Jan 04, 2008 12:51 am
Quoting 2H4 (Reply 2):
 biggrin  I hadn't ever thought of that...good point!!  Smile
lowrider
Fri Jan 04, 2008 2:08 am
It is easily possible to load the 206/7 out of CG with high density items. When empty, I found the 206 to be somewhat nose heavy. After you run a few practice scenarios though, it is easy to get a feel for what will work and what wont. I always tried to put the heaviest items in the middle.
Proud OOTSK member
L-188
Fri Jan 04, 2008 5:16 am
Quoting TupolevTu154 (Thread starter):
I have put a 207 (actually it was the same A/C) on it's arse twice. Once putting a free-standing commerical ice cream maker in one, and the other time it too 3 150HP and two 75HP Mercury outboards to do it.
Both the 207 and the stretched PA-28's have a nose baggage compartment to help out with CG issues. But that being said, both aircraft have pretty wide CG ranges.
TupolevTu154
Fri Jan 04, 2008 5:50 pm
Thanks for the replies everybody.
So, if the aircraft is empty, it's nose heavy ayway? I'm also assuming the aircraft would be equipped with a more powerful engine up front in order to lift those two more extra people.
Thanks again.
Tom Big grin
cptspeaking
Fri Jan 04, 2008 6:55 pm
Quoting TupolevTu154 (Reply 6):
Sure thing...of course, "more powerful" is a relative term, but I'm assuming you're referring to a number in relation to a 172 or 182, something along those lines, considering the addition of two seats. Standard 172s now come with 180hp engines, normally aspirated...the 206 I fly has a turbocharged 310hp engine... the Lycoming TIO-540. As a bigger engine, you've got to be more careful about shock cooling it in the descent, and it's actually very easy to do because the airplane does not like to slow down...if the descent planning isn't done well ahead of time, you're usually not going to make target altitudes and airspeeds without shocking the engine. It's a very fun airplane to fly when it's lightly loaded though  Smile
atct
Sat Jan 05, 2008 1:44 am
Yea ive never had a problem with CG in the Cherokee 6 300 I flew a couple times. (once with 6 adults). I cant say anything for the 206 or 207's as ive never flown one as PIC (or done any w&b calcs on em), closest for me would be a 210 which is a little different (though very similiar).
ATCT
Trikes are for kids!
pilotpip
Sat Jan 05, 2008 3:05 am
Six seat aircraft can get a little interesting. This is one of the reasons many have a club seating configuration. Yes, it's better for passenger interaction but the primary purpose was placing the two in the middle seat further forward.
The third seat in a bonanza is pretty much useless unless you have a couple kids along for the ride. Then again, an adult wouldn't have enough headroom anyway.
DMI
KELPkid
Sat Jan 05, 2008 3:25 am
Quoting ATCT (Reply 8):
The gear retraction system in the 210 helps out any nose heaviness issues that the bird might otherwise have...I have flown the 210 solo before. Nothing like a 182...I think when I'm solo aboard a 182 with full fuel, the CG is actually too far forward Big grin (that's what a 5'6", 160 pound pilot does for ya..  Wink ). I was shocked when I actually computed a weight and balance for a 182 (with just me and fuel on board) once...
L-188
Sat Jan 05, 2008 7:58 am
Thanks again.
One other thought,
A lot of these aircraft if they are used in rural Alaska will take a nose high attitude while sitting on the ground. It is a combination of running larger then stock tires and putting more pressure in the nosewheel strut.
Improves the ground angle and floatation on soft strips.
Users browsing this forum: parapente and 1 guest
