flyvabb
HUD In Commercial Aircraft (pic)?!?
Tue Jan 08, 2008 9:06 pm
Photo © Nitin Sarin
First i would like to congratulate nitin on finally getting a picture from Chandigarh on this forum!!
Secondly i want to ask a question about Heads Up Display, if you notice the top right corner of this pic, this Gulfstream has a HUD, How come its only located on the Captains side.
Further, do any other commercial airliners come with HUD? What is the significance of such an option?
And lastly are there any regional airlines operating Gulfstream aircraft:?
VABB
Up, up and away!
EMBQA
RE: HUD In Commercial Aircraft (pic)?!?
Tue Jan 08, 2008 9:19 pm
Quoting Flyvabb (Thread starter):
Yes... several.... jetBlue has them in their E190...... Alaska has or is adding them to their B737.... I think Southwest is as well...and I'm sure there are many many more
Stitch
Tue Jan 08, 2008 9:20 pm
At least a few do, like some AS 737s. The advantage is that in tricky approaches (either terrain or weather), the pilot's eyes are outside the cockpit.
tdscanuck
Tue Jan 08, 2008 9:23 pm
Probably expense...it's typically an option, and an expensive one. Since only one pilot is actually flying, you can probably live with one HUD most of the time.
It's an option on the 737 now. Not sure about other current Boeing or Airbus production. Dual HUD's will be standard on the 787. I'm not a pilot, but as I understand the benefit is it allows the pilot to keep his eyes out the window while still getting crucial info (the HUD basically duplicates the PFD). Among other things, I believe this allows you to have lower minimums.
Tom.
Pihero
Tue Jan 08, 2008 9:52 pm
For a long time, it has been an option.
Air Inter, as far back as the late sixties had their Caravelle / Mercure aircraft equipped with one.
When they received their A320s, they had them fitted , too. Sadly,they were removed a few years ago as only the Orly-based airplanes had them and it was a bugger in terms of fleet training.
Here are the pics, first of a deployed HUD :
Photo © Thierry IZZI
and then of a stored one :
Photo © Captainnico
There were three main uses :
  • In visual flight, it used to allow for a very accurate flight path control, especially useful in mountainous terrain, haze, over the sea approaches.
  • On an LVP approach, it allows the captain to monitor the approach status / conditions while looking outside
  • On a LVP takeoff, allows a virtual vision of the runway, therefore getting very low minima.
Quoting Tdscanuck (Reply 3):
Not quite. All HUD's base their main information on the actual airplane energy, here translated into the *flight path vector* symbol....Makes for very stable approaches as you just *place* the *bird* on the runway markers.
The symbology changes on an ILS approach, on which one can visualize the ILS windows, or during takeoff where the centerline is materialised.
What is interesting is that HUDs seem to have regained a lot of favour from the bean counters : B^ having them allows crews to go down to CatIII manual flying, costing less than a redundant A/P set.
All new types :787s, 380s and 350s will have them, either as an option of as a basic equipment ( Jury is still out for the 350 where it seems to be part of the basic package).
Contrail designer
Skyweasy82
Tue Jan 08, 2008 9:53 pm
JAZZ has them on their CRJ's
flyvabb
Tue Jan 08, 2008 10:27 pm
Quoting EMBQA (Reply 1):
Quoting Stitch (Reply 2):
So its a very selective option? Depending on routes flown by a particular airline? I ahve gathers from Justplanes.com that alaska flies to various unusual airports. Is that a reason?
Quoting Pihero (Reply 4):
Wow that interesting, i never knew that!
I havent seen one in the A380 till now! Can anyoen confirm if its an option or a standard feature?
Personally i feel its a technology transferred from airforce fighters, can that be a right assumption?
Up, up and away!
AirframeAS
AS has them on ALL of their 737's. Their M83's don't have them. WN has them on all of their 737's, IIRC. The idea of the HUD is to help keep the pilots eyes on the final approach and the instruments at the same time rather than going without the HUD and the pilot would have to look at the approach and then look down at the intruments then look up at the approach and repeat. HUD's eliminate that practice.
jkudall
Tue Jan 08, 2008 10:29 pm
WN has them on at least some (maybe all?) NG 737's and some older model 737's.
Photo © Patrick McManus
Photo © Matthew Hom--Frame of Mind, Inc.
[Edited 2008-01-08 14:30:43]
tdscanuck
Tue Jan 08, 2008 10:45 pm
Quoting Flyvabb (Reply 6):
Alaska flies in some horrible weather. The improved ability to fly in low visibility, apparently, significantly decreases the number of flights they have to cancel or divert because of weather.
Yep.
Tom.
2H4
Tue Jan 08, 2008 10:53 pm
Quoting AirframeAS (Reply 7):
...And they make it soooooo easy to fly a precise approach down to minimums. Simply keep a small circle centered in a larger circle, and you'll fly a perfect approach.
2H4
Intentionally Left Blank
KensukeAida
Tue Jan 08, 2008 11:04 pm
Quoting Jkudall (Reply 8):
I believe they have them on all. They first got them on the ex-Morris 733s, liked them a lot, and then retrofitted them to their whole fleet (and are now having them installed on 73Gs from the factory).
- John
corey07850
Wed Jan 09, 2008 12:08 am
This should be an add-on to the G-IV as I don't believe it came as on option from the factory that way. The G450 and 550 have it as an option, if not standard. There are some models that will display just PFD/nav info, while others like the ones on new Global's integrate an EVS camera to display a synthetic infrared view of the terrain on the HUD as well.
Absolutely not
2H4
Wed Jan 09, 2008 2:11 am
Quoting Corey07850 (Reply 12):
Absolutely not
There were, though:
Photo © Bill Sheridan
Photo © Dave Sturges
Photo © Bob Garrard
Photo © Alastair T. Gardiner - WorldAirImages
Photo © David Oates
Photo © JetPix
Photo © Gerard Helmer
Pity they're not anymore.
2H4
Ceph
Wed Jan 09, 2008 8:27 am
I'm I'm not wrong its offered as an option on the A380.
FlyASAGuy2005
Wed Jan 09, 2008 12:31 pm
Delta has them on a lot of their 737's. I also know that it is an option from the CR2-CR9.
What gets measured gets done.
Wed Jan 09, 2008 4:39 pm
Photo © Jeff A. Jones
Photo © Michael Ciasullo
Watching the Instruments as well as Visual viewing of the Exterior.
Anyone aware of the Manufacturers for the Type HUD approved on the B737s.
regds
MEL
2H4
Wed Jan 09, 2008 4:42 pm
Quoting HAWK21M (Reply 16):
Rockwell Collins is one.
2H4
Wed Jan 09, 2008 5:11 pm
Quoting 2H4 (Reply 17):
http://www.rockwellcollins.com/produ...cs/displays1/cockpit-displays/HUD/
Thanks.The Link does not state B737,so I was wondering.
regds
MEL
AAR90
Wed Jan 09, 2008 5:14 pm
Back when I transitioned to the 738, AA published Marconi as the manufacturer of its HUDs. The supplier has changed names numerous times since then and I don't know who claims that title today.
Quoting 2H4 (Reply 10):
Actually, you have to keep the larger circle (airplane symbol really) around the smaller circle (flight director symbol). And it is not "soooooo easy" as it looks. The display is so "expanded" that virtually any deviation looks large to the pilot and he will be working his a** off while the plane doesn't appear to be moving at all the those not flying --it is a common teaching technique to show new FO's what the CA was doing as they essentially see no deviations the entire approach. It also takes some getting used to as the fancy "trend vectors" often don't match trend directions (again, due to the greatly expanded displays). Still... a very good tool indeed. And yes, AA's experience is that the 737s CAT-III HUD is way cheaper to purchase and maintain than a comparable CAT-III autopilot system --and it was proven to be more accurate as well.  Wink
2H4
Wed Jan 09, 2008 5:28 pm
Quoting AAR90 (Reply 19):
Ah, my mistake. My impression of the overall ease of use was based on the fact that a monkey like myself could successfully fly such a precise approach through weather in the sim.  Wink
2H4
AAR90
Wed Jan 09, 2008 6:05 pm
Quoting 2H4 (Reply 20):
Oh, well with "that" definition... you are correct.  Wink When AA began initial testing to determine if it wanted HUD or CAT-III for its 738s, some of the secretaries at the school-house were brought to the sim to fly CAT-III HUD approaches. They more often than not successfully landed the plane. Stopping was another matter though.  duck
boeing767mech
Wed Jan 09, 2008 10:17 pm
AAR90
And it is great for hitting your head on while getting into the pilots seat (the joy of bieng a 6'4" mechanic). Since we don't see the 738 here. Have they fixed the problems of MU failures due to overheating?
David
Never under-estimate the predictably of stupidty
AAR90
Thu Jan 10, 2008 12:51 am
Quoting Boeing767mech (Reply 22):
I can only imagine. Its only taken me 7+ years, but I only hit my head once or twice a year now.  conehead
Yes... a few years ago. Now I'll see a "system fail" msg two-three times per year. I still see OHU's overheating though that is usually caused by pilots leaving the combiner down (and the system "on") between flights --even though the checklist requires the combiner to be "stowed" after parking.  cry
rampkontroler
Thu Jan 10, 2008 1:40 am
Horizon had/has them in their Dash 8 -200's which are heading over on lease to Commutair. So I guess you could say Commutair has HUD's too:
http://www.opshots.net/gallery/displayimage.php?pos=-2964
matt2242
Thu Jan 10, 2008 4:31 am
Qantas and some of their B738s use a HUD system as well.
Matt
Tornado82
Thu Jan 10, 2008 4:55 am
For AAR90 and other pilots... how often are the HUD's used? Every moment of every flight? Just approaches? Just in IMC? Varies by pilot?
I'm just thinking that in a nice clear/calm/P6SM visual approach a HUD would almost be a hinderance rather than an aid.
Thanks.
AAR90
Thu Jan 10, 2008 5:32 am
Quoting Tornado82 (Reply 26):
If working, AA requires its use for EVERY takeoff and EVERY landing. Primary stated reason is to prevent tailstrikes, but it is just a good source of critical information in the line-of-sight of the Captain.
Once you get used to it, it is quicker/easier to see all the critical flight instrumentation than looking inside at the instrument panel. After all these years, I am still not comfortable with the "declutter" mode (numerical values instead of graphical representations). That requires additional mental comprehension vs. graphical representations are instantly recognizable... at least to me.
Thu Jan 10, 2008 8:50 am
Whats the Scheuled Maintenance on the Unit like?
Quoting AAR90 (Reply 27):
Interesting.
regds
MEL
boeing767mech
Thu Jan 10, 2008 9:25 pm
Quoting HAWK21M (Reply 28):
the maintenance program on the HUD is, it fails troubleshoot and repair it. I don't know of any scheduled checks on the unit, Unless it is done at B check or higher. I don't think you have the problems of burning the screen like the CRT's on the 747,757,and 767.
David
Tornado82
Thu Jan 10, 2008 11:00 pm
Interesting. Thanks for the info. Is there one on the FO side too for when the FO is the PF?
avt007
Fri Jan 11, 2008 12:03 am
Whats the Scheduled Maintenance on the Unit like?
The only maintenance on the HGS2100 and 4200 is cleaning the combiner glass, projector lens, ambient light sensor, and the alignment detector. Basically a couple minutes with some glass cleaner.
A picky note here- modern systems are HGS, Headup Guidance systems. The difference is that HGS is independent of the PDF. It takes in all the aircraft sensor data and computes it by itself and generates the displays and flight guidance cues.
Interesting to note that the C130 J has no panel mounted PDFs. The dual HGS are the primary flight instruments for the aircraft.
AirframeAS
Fri Jan 11, 2008 5:28 am
Shoot, I totally forgot who made ours at AS. I think it was Honeywell, but I could totally be wrong. I just don't remember.
Interesting.
 checkmark  Very, very interesting indeed!
Our Avionics department were the ones resonsible for the HUD's at AS. We didn't touch those in the C-D checks.
2H4
Fri Jan 11, 2008 5:36 am
Quoting Avt007 (Reply 31):
PDF
PDFs
You mean PFDs, right?
2H4
Fri Jan 11, 2008 7:26 am
How long would a replacement take in terms of Man-hrs?
regds
MEL.
Fri Jan 11, 2008 7:28 am
regds
MEL.
Pihero
Fri Jan 11, 2008 1:46 pm
I'm curious : do you rotate at T/O using the HUD ? Because on those I've seen, the expanded - a lot more than on the PFD - attitude scale makes it in this situation more difficult to judge the amount of attitude you'd require.
Normally, at "Rotate ! ", one would look down to the classic displays first.
Contrail designer
avt007
Sat Jan 12, 2008 12:57 am
PDF- Oops, been spending too much time on the computer lately........
Quoting HAWK21M (Reply 35):
For the computers, and control panel, basically a few minutes. For the projector, or the combiner, as the display unit is called, no more than one hour for each, including paperwork. They are essentially a few bolts and a cannon plug. No alignment is required, as it is all done during the installation process. Testing is very quick, no tools required, no test equipment, essentially a BITE process. The MTBF is excellent as well, it's very reliable.
2H4
Sat Jan 12, 2008 1:19 am
Quoting Avt007 (Reply 37):
Just making sure Adobe isn't meddling in the affairs of the avionics industry.  Wink
2H4
Mir
Sat Jan 12, 2008 1:36 am
TZ had them on their 738s (captain's side only IIRC). They still might. Interestingly, the pilot said that the attachements aren't as secure as he'd like, which makes the HUD rattle around a bit in gusty/turbulent conditions, making it hard to read accurately, so he didn't use it in those conditions.
B6 can do CatIIIa approaches by hand with the HUD in its 190s. Or, it will be able to once it gets the certification for it - I don't think the E190 is ready yet.
Quoting 2H4 (Reply 38):
Eventually you'll be able to print out PDFs of approach plates right from the cockpit.  Smile
-Mir
AAR90
Sat Jan 12, 2008 5:33 am
Quoting Tornado82 (Reply 30):
Just the CA's side. AA's primary reason for installing the HUD was for CAT-III capability. In those situations, the CA will be the one landing the plane.
Quoting Pihero (Reply 36):
Not me, but it is directly in my field of view so it is easy to see the critical flight information.
...more difficult to judge the amount of attitude you'd require.
The HUD has a TO/GA Target Pitch Line display that presents itself when the TOGA is pushed. Upon rotate, if you place the acft symbol between the gap in the Target Pitch Line will give you the proper rotation angle, then climb deck angles, headings or ground tracks. Essentially becomes the only dashed line you look for in the HUD. Instrumentation is not one of my primary scans during this critical phase of flight, but with the HUD, the critical information is available directly in my field of view. Using that info has become second nature now (wonder how I flew on/off ships without it; but now understand why those with HUDs claimed emergency status when it wasn't working). The HUD also has a (potential) TAILSTRIKE warning system built in, but I haven't seen it activate except in the simulators.  bouncy
Pihero
Sat Jan 12, 2008 9:54 am
AAR90
Thanks.I hadn't heard of that TOGA setting.
Cheers.
Contrail designer
AAR90
Sat Jan 12, 2008 10:48 pm
Quoting Pihero (Reply 41):
Shown HERE.
#8 is the Target Pitch Line.
#9 is the AOA indicator
#10 is the runway centerline.
Certified for as low as 300RVR for takeoffs.
Pihero
Sun Jan 13, 2008 12:00 am
Quoting AAR90 (Reply 42):
Is it because of the HUD limitations or for some ops reasons, because AF / IT used it for 75 m RVR takeoffs.
Contrail designer
mark5388916
Sun Jan 13, 2008 12:11 am
FAA vs JAA Rules perhaps?
I Love ONT and SNA, the good So Cal Airports! URL Removed as required by mod
DeltaGuy
Thu Mar 20, 2008 3:05 am
Moldy oldy thread, but I was going through my G-IV books today in prep for another trip to Flight Safety, and I saw that the HUD system was indeed an option with the G-IV, according to my manuals for the SPZ-8400 avionics package by Honeywell. It says there is provisions for the optional Honeywell 2020 HUD.
Abiet, this is a generation before the PlaneView G450 and the standard HUD with all of the toys. Still a very capable system either way you look at it.
DeltaGuy
9VSIO
Sat Mar 22, 2008 2:07 pm
Hmmm, if you had both autoland and HUD installed..which would you rather use?
Me: (Lining up on final) I shall now select an aiming point. || Instructor: Well, I hope it's the runway...
