AeroTechnical
Static Pressure Port Research Help Requested
Thu Jan 10, 2008 1:42 am
G-Day all, (first post, go easy)
I am researching procedures/products employed across all Aircraft types for "static pressure port covering" (flush mounted not pitot-static), required for the purpose of aircraft Washing, Painting, storage and cleaning. Information help required to aid development of a new "static pressure port cover" to increase flight safety around critical pressure sensors during the above maintenance practices.
My reason for researching, the simply practice of applying let's say tape over static ports for a maintenance procedure is at best a very simple process, although at my place of work it's been done incorrectly for the past 15+ years, after I read the procedure & asked a few Q's it became quite clear we are simply doing it illegally.
Information requested;
1.Approved maintenance procedures
2.Approved tapes, covers and barrier materials used
3.Quantity of static ports per A/C type
4.Picture of port types (within red boarder)
5.Measurements, diameter of port containing multiple sensing holes, diameter of non-painted area around static port and distance between centre of multiple static ports clustered together.
6.Stories of close calls, illegal practices or what shouldn't happen at your work.
Please forward supporting information to my "contact" email tas6@optusnet.com.au , as the volume could be far too much for this site?
I understand this is a huge task and will take some time; your time & efforts on an international scale will be most appreciated
Aero Technical
tdscanuck
RE: Static Pressure Port Research Help Requested
Thu Jan 10, 2008 8:02 pm
Quoting AeroTechnical (Thread starter):
All of this information will be contained in the Aircraft Maintenance Manual. Since you're profile lists you as an AME, I suspect you should have access to these. Check out chapter 34 for the static port locations and chapter 10 for the washing procedures, including approved cover materials. For the paint layout, see chapter 51 of the Structural Repair Manual.
Cannonical case: http://en.wikipedia.org/wiki/Aeroper%C3%BA_Flight_603
Tom.
AeroTechnical
Sun Jan 13, 2008 11:46 am
Tom et all,
Quoting: tdscanuck, All of this information will be contained in the Aircraft Maintenance Manual. Since you're profile lists you as an AME, I suspect you should have access to these. Check out chapter 34 for the static port locations and chapter 10 for the washing procedures, including approved cover materials. For the paint layout, see chapter 51 of the Structural Repair Manual.
my aviation experience is all Military, access to domestic aviation information / procedures are not available and the main reason for the post.
Flight_603 was the reason I looked at our procedure, please don't just read, send a copy of yours & possibly prevent this reoccurring?
Aero Technical
tdscanuck
Sun Jan 13, 2008 5:15 pm
Quoting AeroTechnical (Reply 2):
Unfortunately, those documents aren't mine to distribute. I would discuss with your closest airline, or someone else who does have the authority to distribute them. In the interim, study up on the manuals you do have (they should address this for military as well, I would hope) and read as much of the accident data for Flight 603 as you can find.
Tom.
BWilliams
Sun Jan 13, 2008 5:23 pm
Quoting Tdscanuck (Reply 3):
Just a question that i've wondered: why is it that mechanics reference chapters of the AMM in different thread, but never actually say anything about what those chapters contain (other then a chapter title or the like), and in this case, can't distribute them? Do you have to be a licensed A&P to get a copy of the AMM/SRM?
Regards, Brad Williams
fr8mech
Sun Jan 13, 2008 5:48 pm
Quoting BWilliams (Reply 4):
No, you don't have to be a licensed AMT to get a copy of the AMM or SRM. Though these manuals are distributed by the manufacturers, they are revised by the operator, with concurrance from the manufacturer. This stuff is rarely confidential, but most employees sign non-disclosure agreements when they hire on. This agreement usually prohibits the distribution of company material without permission. Everyone of our manuals has the "This is the property of ..." clause on the very first pages.
MD11Engineer
Sun Jan 13, 2008 6:30 pm
Ok, according to our company procedure, the cleaners notify us that they need to do an external wash on aircraft XYZ. We cover the static ports using a bright red self-adhesive plasic tape, to which we attach long flags (appr. 1 metre) of red and white danger tape. Additionally a laminated card stating "CAUTION! STATIC PORTS COVERED!" will be attached to the captain's teering wheel. Then a tech log entry stating that the static ports have been coverted is made.
When the cleaners tell us that they are finished we remove the covering tape and carry out a duplicate inspection for the removal of the covers and close the tech log entry. The cleaners note the tech log page number on their cleaning sheet, which has to be signed by the captain in the morning.
Jan
tdscanuck
Sun Jan 13, 2008 7:44 pm
As Ff8Mech said, most people with access to the manuals are also under a non-disclosure agreement or other document that prevents them from distributing them to people that don't have access (usually, anyone outside the company). There's no A&P requirement, you just have to work for someone that has them. In my case, I can access all the Boeing manuals but the same contract that lets me do that also prohibits me from distributing the documents.
References to just chapter numbers work because the chapter numbers are standard across all manufacturers (they're set by the ATA). Also, any particular task is so long and tedious that reposting it in its entirety would just waste bandwidth...it's a lot easier to just reference the right chunk of the manual
If you want to know what a particular manual says, I'd be happy to dig that up, but doing it for all the manuals I have access to is long, tedious, and not particularly productive since they all say pretty much the same thing.
Tom.
MD11Engineer
Sun Jan 13, 2008 8:01 pm
The aircraft manufacturers, who write the manuals, consider the content proprietary material and don't like it distributed without their permission. Actually, to buy these manuals from e.g. Boeing, you'll need to be the owner of an aircraft.
Jan
AeroTechnical
Mon Jan 14, 2008 12:22 pm
Totally understand the legalities of documentation control, don't require electronic 100% certified copies of your publication, as per below is an example of what I am looking for.
"Seal by placing barrier paper MIL-B-121 or equivalent over static port. Seal edges with pressure sensitive tapes"
"Apply colour contrasting waterproof tape to static vents"
"Waterproof tape and barrier material containing PVC plastic must not be used"
"Static vents shall be sealed using 1 inch wide red coloured PVC tape only, 24 inch long streamers shall be left at each point, the use of clear tape is not permitted"
As you can read some methods contradict others (PVC), my understanding is masking or pressure sensitive tape is not to be directly applied to the static ports and a barrier material used over the holes?
Quote: MD11engineer, "We cover the static ports using a bright red self-adhesive plastic tape"
Aero Technical
tdscanuck
Mon Jan 14, 2008 11:09 pm
Quoting AeroTechnical (Reply 9):
Gotcha. Also, I realized I did a typo in Reply 1...the washing procedures are in Chapter 12, not 10. 10 is parking & mooring.
For a 737, the static port procedures are:
-Clean around each port with solvent and dry rag
-Place the end of a long (~4 feet) strip of barricade tape over the static port
-Tape the end barricade tape in place with Scotch or 3M #471 yellow vinyl tape (never put the Scotch tape directly over the static port holes)
-Tape edges of the barricade tape on each side of the static port with Scotch tape
-Tape across the barricade tape below the static ports, overlaping the edge tape
-Leave the tail of the barricade tape streaming as a visual indicator
-Wire a "Static ports covered" placard to the top of the left yoke
-When you're done, remove the tape and barricade tape, clean up any tape residue with solvent, and remove the placard (last)
"Barricade tape" is Boeing-speak for orange 3 inch "REMOVE BEFORE FLIGHT" tape.
Hope that's helpful,
Tom.
737tdi
Mon Jan 14, 2008 11:35 pm
Tdscanuck/Tom hit it right on the nose for us. The main point being is you do not apply the tape directly to the port due to adhesive residue being left in the sense holes.
737tdi
AeroTechnical
Tue Jan 15, 2008 6:00 am
Cool, now were on the same page, as it is we carry the 3M-471 but for another job,
Q, what solvent is used to clean area?,
Q, could you please measure the diameter across the static port holes as if you draw a circle around each port group and the distance from ctr to ctr separating each static port if a few within the cluster.
Trying to make this cover as universal as possible, the more A/C types the better, THANKS
Aero Technical
tdscanuck
Tue Jan 15, 2008 6:26 pm
Quoting AeroTechnical (Reply 12):
Aliphatic naphtha
Eyeballing it from the manual, on a 737 it appears to be a 3 inch circle of bare material around each port, and 3 inches between ports where you have clusters. However, that probably varies from airplane to airplane.
Tom.
MD11Engineer
Tue Jan 15, 2008 7:30 pm
Quoting 737tdi (Reply 11):
737tdi
Actually the same way we do it, I should have explained it in more detail.
Jan
Users browsing this forum: BoeingGuy and 2 guests
