pilotntrng
Converting Aircraft
Tue Jan 15, 2008 7:46 am
Obviously airlines that are buying used aircraft would like them to be similiar to the aircraft that they own.Sch as Delta buying AA's old TWA 757s, because of the type of engines they use. My example and question is, how hard would it be to replace a 757 with a GE engine with a RR and get them compatible with the rest of the fleet?
Booooo Lois, Yaaaa Beer!!!
tdscanuck
RE: Converting Aircraft
Tue Jan 15, 2008 5:58 pm
Quoting PilotNTrng (Thread starter):
It's technically possible but difficult and expensive. New strut, new aisle stand, some new overhead panels, new wiring from the engine to the aircraft, new reversers. The difficulty of doing the conversion is exactly why the 787 was designed for engine changes from the beginning.
Tom.
2H4
Tue Jan 15, 2008 6:41 pm
Quoting Tdscanuck (Reply 1):
Interesting that other models (eg: 757/767) weren't designed similarly. It seems obvious that such interchangeability would add value to an aircraft with multiple engine options.
2H4
Intentionally Left Blank
futurecaptain
Tue Jan 15, 2008 6:50 pm
It has been said that all things considered it is cheaper to buy a new aircraft from the manufactuer then it is to do this kind of conversion and get the plane recertified for normal pax operations.
But, if you don't want to use the plane in passenger service again...slap a GE-115 on a 747.
Photo © Jet City Aviation Photography
tdscanuck
Tue Jan 15, 2008 7:15 pm
Quoting 2H4 (Reply 2):
It was mostly driven by the shift from purchase to leasing. When the 757/767 were being designed, legacy carriers owned most of their fleets. Leasing was viewed as something for lower tier airlines. This meant that airplanes were bought straight from the manufacturer to their operator and stayed there for decades...no real demand for the ability to swap engines so little perceived value.
Fast forward 20 years and leasing companies are the biggest fleet owners out there and aircraft can go through 5+ owners in their lifetime. What the buyer (the leasing company) is looking at now is total return on their asset, not just efficiency within a particular fleet/route structure like an airline would look at. The ability to swap engines is of major value to the leasing company (although still of relatively low value to any particular airline) so, like any good supplier, the OEM's are adapting to what their new customers want.
Tom.
KELPkid
Tue Jan 15, 2008 7:21 pm
Quoting Futurecaptain (Reply 3):
I always found it hillarious that GE chose a Pratt-powered bird as their engine test bed  laughing
tdscanuck
Tue Jan 15, 2008 9:39 pm
Quoting KELPkid (Reply 5):
Makes sense to me...get your test bird and do a little competitive "research" at the same time. Thanks to the way the FAR's work for maintenance documentation, Pratt would have to turn over all of their maintenance material to GE if GE was flying Pratt engines.
Tom.
Viscount724
Tue Jan 15, 2008 10:49 pm
A small number of 747s were converted from P&W to GE engines. This is one of them:
P&W:
Photo © Ed Groenendijk
Photo © Marc Lehmann
GE:
Photo © Jordi Steeno
Photo © Tim Perkins
That aircraft was written off after a landing overrun incident at DUS in 2005.
metroliner
Tue Jan 15, 2008 11:16 pm
Here's a dumb question - did any aircraft ever use more than one engine type?
Tridents excepted  Wink I know about those!
Toni
P.S. Any jokes about BAe146s having five hairdryers are anticipated forthwith...
Set the controls for the heart of the Sun
Viscount724
Tue Jan 15, 2008 11:54 pm
Quoting Metroliner (Reply 8):
Yes, a few aircraft that used a mix of piston and "helper" jet engines to provide additional power during takeoff at at heavy weights. The Boeing B-36 was probably the most notable with 6 piston engines and 4 jet engines.
Photo © Ted Quackenbush
Photo © Matt Bearup
Fairchild C-123 Provider military transport.
Photo © Ralph M. Pettersen
Photo © Gerard Helmer
Lockheed P2V Neptune maritime patrol aircraft.
Fairchild C-82 Packet (the one in the photo was used by TWA to ferry replacement Constellation engines around Europe). Note the single small jet engine on top of the fuselage.
Photo © Robert Roggeman
Tue Jan 15, 2008 11:58 pm
Actually they're 5 APUs. Big grin
KELPkid
Wed Jan 16, 2008 12:52 am
IIRC, UPS'es 727's had Rolls-Royce Tays on the outside positions and they left the JT8D in the center (#2) position...
Photo © Carlos Borda
timz
Wed Jan 16, 2008 12:59 am
IIRC, you don't recall correctly.
57AZ
Wed Jan 16, 2008 2:36 am
Quoting Timz (Reply 12):
Correct. The enlarged air intake on the No. 2's S-duct was a requirement due to the volume of air required for the Tay to operate.
"When a man runs on railroads over half of his lifetime he is fit for nothing else-and at times he don't know that."
Viscount724
Thu Jan 17, 2008 2:08 am
Quoting KELPkid (Reply 11):
You're thinking of the Super 27 conversion program. A few 727s had the outer engines replaced with the JT8D-217/219 as used on the MD-80 but the original JT8D-15/17 was left in the center position. I think that's because the larger diameter fan on the -217/219 would not fit the center position without major changes. Super 27 photos below.
Photo © Adam Rowden
Photo © Gert Rosmann
Photo © T.Laurent
Photo © Samuel Schneeberger
KELPkid
Thu Jan 17, 2008 6:45 pm
Quoting Viscount724 (Reply 14):
Ah, thanks. I knew I wasn't full of crap then, just couldn't remember which 727 conversion program it was  Smile
CaptOveur
Fri Jan 18, 2008 9:14 am
I think this is also called a Valsan Conversion.
Also, I think the last few 727s off the line. The ones that went straight to FedEx might have been built with this feature already in place.
Things were better when it was two guys in a dorm room.
aeroweanie
Fri Jan 18, 2008 3:47 pm
Quoting Viscount724 (Reply 9):
Convair, not Boeing!
Quoting CaptOveur (Reply 16):
Yes. Valsan did the engineering, certified it and then went bust. Goodrich/Rohr picked up the pieces and continued it as the Super 27.
No, Boeing would have nothing to do with the conversion. They were converted after delivery.
Viscount724
Sun Jan 20, 2008 2:06 am
Quoting Aeroweanie (Reply 17):
Yes, sorry, you're right!
Sun Jan 20, 2008 3:53 am
Costs matter in this field.And if the option to buy a new Aircraft is available,why spend on a mod of such nature.
regds
MEL
CaptOveur
Mon Jan 21, 2008 6:54 am
Quoting HAWK21M (Reply 19):
The used aircraft is availible now. The new one might take months or years to be built.
Tod
Mon Jan 21, 2008 4:07 pm
Didn't Valsan hire Flight Structures to do the cert work?
Tod
airfoilsguy
Mon Jan 21, 2008 8:30 pm
Why stop at 1? Put 4 on it. Would probably rip the wings off at full thrust but take off distance would probably be significantly reduced.  Smile
It's not a near miss it's a near hit!!
KELPkid
Tue Jan 22, 2008 6:41 am
Quoting Airfoilsguy (Reply 22):
I can just see it now: The Air Planes 747 SST conversion, or the Riley Rocket 747  Silly
Users browsing this forum: swisslue and 9 guests
