don81603
Aircraft Parking At Tbit
Sat Jan 26, 2008 4:09 pm
TOM BRADLEY INTL TERM GATES: ALL ARR WIDEBODY ACFT SHUT DOWN ENGINES ON TWY ADJACENT TO GATE AND TOW ONTO GATE.
What is the reason for all wide bodies at TBIT to be towed to the gate?
Eagles may soar, but weasels don't get sucked into jet engines.
xjramper
RE: Aircraft Parking At Tbit
Sat Jan 26, 2008 4:58 pm
Quoting Don81603 (Thread starter):
My guess is that there isn't enough room between concourses for the heavies to turn into gates without blowing the ramp on the other concourse across the alleyway, well away. Detroit Metro had this same rule when NW operated out of the C concourse over at the Smith terminal. If you were parking at the end B gates, you had to shut down prior to docking at the gate for the jetblast for a sharp turn into like B10 (for those familiar with metro).
XJR
Look ma' no hands!
Sat Jan 26, 2008 5:23 pm
Looks like Span clearence issues or close proximity to ground equipment at that gate.
Hence as a precaution better to tow in than taxi.
regds
MEL
Zkpilot
Sat Jan 26, 2008 11:28 pm
Have you ever arrived into TBIT on a 747 or other large WB? It is a very tight fit!! and also there are the jetwash issues/
57 types. 38 countries. 24 airlines.
LAXintl
Sun Jan 27, 2008 5:42 am
Tow in is required for two reasons -- wingspan clearance -- lots of 747-400s on gates, and jet blast mitigation to adjacent terminal 3 and 4 which use common alley with TBIT -- over the years AA, Alaska etc have had their share of dinged up planes having ground service equipment of containers pushed into them.
don81603
Sun Jan 27, 2008 1:26 pm
Quoting Zkpilot (Reply 3):
I only arrived at TBIT once, and to be honest, I was so wiped out and jetlagged, I barely recall it.
mark5388916
Sun Jan 27, 2008 10:01 pm
Quoting Don81603 (Reply 5):
Don't blame ya, been there as well. Seeing me in an A343 taxiing out as a B773ER taxi in, it gets VERY tight.
I Love ONT and SNA, the good So Cal Airports! URL Removed as required by mod
Users browsing this forum: harrisair, thepinkmachine and 1 guest
