airportugal310
Prist / Additive
Mon Jan 28, 2008 7:41 pm
I have been working for the past 3 months as a fuel person for a well-known private jet "broker" and have a few questions regarding Prist or other additives:
It has to be pre-mixed or mixed with the fuel as it enters the tank but, what does it really do. A google search or two tells me that it is to prevent freezing or water droplets in the fuel if they exist and also, that it acts as an anti-microbial agent.
Now, it is generally optional (i.e requested by the flight crew) and other times is a requirement for operating to colder areas such as winter time in the Northeast etc...
So, the question is really: Can someone knowledgeable (which most here on this section are) explain some things about it and if there are different kinds of it? Also, some of the reason why some planes need it more than others?
And why does the cost range from, what I have been quoted here and there, anywhere from .02 to .011 cents per gallon of Jet-A added? And does 100LL need it?
I sell airplanes and airplane accessories
KELPkid
RE: Prist / Additive
Mon Jan 28, 2008 8:30 pm
Quoting AirPortugal310 (Thread starter):
Certain early jets had problems with ice crystals forming in the fuel tanks once the jet was at alititude and the fuel was getting cold soaked. These ice crystals would then get trapped by screen filters in the engine, and could lead to (best case) degraded engine performance, or (worst case) fuel starvation. This is reason #1 for the existence of Prist.
Prist does, also, inhibit bacterial growth in the fuel system, and yes, there are little nasties in nature that prefer a diet of not very purely refined oil (as both jet fuel and diesel fuel are). The trouble with private corporate airplanes is that a typical airplane can sit around for weeks or months between usage, and then be suddenly called to duty, which gives these bacteria time and possibly the right environment to do their worst in. It's not good for fuel systems components.
Nope. Avgas fuel systems have built-in safeguards for water (well, within reason, and providing that the PIC does his/her part...remember the big warning placards that Cessna had in the 80's and 90's as part of an AD that warned the pilot that failure to remove water from the fuel system could result in bodily injury or death?).
If you ever get the opportunity to handle Prist, be very careful with it. The stuff is one step below a toxic environmental disaster, and the safety warnings on the cans definitely need to be heeded!
N231YE
Tue Jan 29, 2008 2:22 am
Quoting KELPkid (Reply 1):
However, Cessna does state that a 0.10-0.15% concentration of DiEGME (basically Prist) is permissible.
Scooter01
Wed Jan 30, 2008 12:29 am
-Especially when water is added to the fuel. These bacterias will grow in the boundary layer between fuel on the top and water at the bottom. To avoid water in the tank, is to keep the tank as full as possible at all times, the less air in the tank the better as moisture from the air will condensate on the walls of the tank and sink to the bottom. This happens mostly on warm days/cold nights.
In my profession I deal with a lot of (diesel) pleasure-boat owners and we see this problem coming up quite often.
After the 4-6 month winter-hibernation period with a less than full fueltank, the boat gets called back to duty in the spring, makes a few cruises in sheltered waters -no problem. Next the boat gets into some waves, the fuel gets shaken up a bit in the tank and -presto, the bacterial growth which now is like black muddy gel gets mixed with the top-fuel and gets sucked into the fuelline clogging the filters, fuelpump, injectors etc. Can be a quite hairy experience when someone loses engine-power at sea.
Therefore I always recommend a dieselfuel additive year round when people are tanking up their boats.
Then again, carrying a lot of fuel burns more fuel and affects performance both with airplanes and boats, so the user must find a way to suit his own needs.
Scooter01
citation501sp
Sat Feb 02, 2008 2:42 am
Some Aircraft are placarded as requiring Fuel Additive. Most straight wing Citations, for example, require it year round. Generally mostly light jets require additive because larger aircraft have fuel heaters. The Phillips 66 brand of Jet fuel usually comes premixed. I have heard many a flight crew suggest tha all Jet fuel should just come premixed anyway. It burns the same as straight Jet fuel.
Smoke and Thunder! Stage 2 FOREVER!!!
pjflysfast
Sat Feb 02, 2008 3:19 pm
Some aircraft have fuel heaters and others actually recirculate warm fuel back from the Fuel Control Unit to the fuel tanks to keep the temp of the fuel warm enough to prevent ice build up which can block the fuel lines. Though we still use Prist on occasion for the anti microbe agent.
If you don't blend it with the fuel it will not be as effective.
A google search or two tells me....
Don't miss reading the part about how PRIST is a highly toxic and dangerous material and must be handled accordingly.
PRIST is effective. Years ago I flew Lears and if it wasn't properly blended or a sufficient amount not added you would know after the first hour at cruise when one or more FUEL FILTER annuciators would come illuminate. Time to descend into warmer air and make a precautionary landing as necessary.
[Edited 2008-02-02 07:22:14]
tb727
Sun Feb 03, 2008 4:44 am
Quoting PJFlysFast (Reply 5):
That stuff is super nasty, I had a fueler in EWR get it in his eyes when I was helping him add the can of Prist in while he was pumping fuel on our Lear. You are supposed to attach a little tube onto the nozzle and attach the other end with a clip onto the end of the fuel nozzle, I preferred to "Super Can" it. Stomp the top of the can off, take the thing apart and spray a stream right into the tank using the sprayer I took apart while they are fueling. You are supposed to do it while the fuel is going in because the Prist will puddle in the tank and is corrosive if not mixed well with the fuel. I'm just glad I am in a real airplane with a Fuel Heater now! I am still pretty sure the CJ610 on 20-series Lears will burn anything though!
flymatt2bermud
Sun Feb 03, 2008 2:52 pm
Quoting Tb727 (Reply 6):
Yeah, they will indeed burn almost anything. The problem is anything has got to get through the fuel filters and ice buildups eventually stop the flow!
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward" Leonardo Da Vinci
