747400sp
Future Of Hydrogen Hyper-jet Airliners
Wed Jan 30, 2008 2:49 pm
On the cover of Feb. 2008 Popular Science, shows a new jetliner call the A2, the A2 is Hydrogen Hyper-jet airliner design to carry 300 passengers at the speed of Mach 5. The A2 do not have any windows due to it speed, also due to it's four Scimitar engines it is a clean burning jet. As written in Popular Science, For takeoff, landing and subsonic flight, the A2's Scimitar engines sends intake air through a bypass duct and into a turbine, like a standard jet engine. After reaching supersonic speed, though, the engine redirects air from the bypass duct through the engine core for flight up to Mach 5. Like a ram jet, the Scimitar works by taking in air from the atmosphere at high speeds and funneling (or " ramming") it until it's intensely compressed. At this point, the extremely hot air mixes with fuel and causes ignition. But the Scimitar one-up traditional ramjet design by adding a turbine that compresses the incoming air even further. Ramjets usually can't use turbines because the incoming air is so hot that it will melt the turbine blades. The Scimitar solves that problem by first cooling the air in a heat exchanger using gaseous helium.
So, could the A2 work, and if yes , do you think passengers would want to trade in windows to make a 22 hour flight only 4 hours?
RE: Future Of Hydrogen Hyper-jet Airliners
Wed Jan 30, 2008 4:36 pm
I would note that Popular Science and so forth need interesting covers in order to sell magazines. This kind of project has been "front page news" since at least the late 50s.
I'm all for really fast, really cool airliners, but I don't see this thing happening anytime soon.
Quoting 747400sp (Thread starter):
Depends on the price, but yes, some of us would.
tdscanuck
Wed Jan 30, 2008 6:32 pm
Strictly speaking, that would be a compressor, not a turbine.
This doesn't sound right to me...the highest temperature in any engine is downstream of the combustor. If the engine can tolerate that temperature there's no reason that the incoming air temperature should be a problem (it just requires that you use turbine materials for the compressor...pricey but possible).
In principal, yes, but you're talking about an *enormous* fuel burn, which implies a hydrogen and helium infrastructure that just doesn't exist today as well as significant energy cost. If I had that kind of money I think I'd rather spend 22 hours on my comfy private jet rather than 4 hours on a windowless commercial jet.
Tom.
Users browsing this forum: arjun0412 and 1 guest
