B773A346
Least Number Of Engines Can A B777/B767 Fly On?
Sat Feb 09, 2008 1:06 am
I was wondering if the Boeing 747 can complete an entire journey without turning on all 4 engines and using only 2 or 3 engines all the time, and one engine for the B767 and B777. Is it safe though ?
BAKJet
Sat Feb 09, 2008 1:16 am
Quoting B773A346 (Thread starter):
I think a BA 744 fly on 3 engines LAX-LHR(maybe it ended up landing in SNN). Although, I think it was because of and engine failure.
rwy04lga
Sat Feb 09, 2008 1:22 am
Zero! Any plane could still fly, just not maintain altitude (Space Shuttle). But, obviously, the answer is one, even a 4-holer.
And the word is 'LEAST'
Just accept that some days, you're the pigeon, and other days the statue
Stitch
Sat Feb 09, 2008 1:23 am
A four-engined plane can complete her mission on three, but if they lost two, I'm pretty sure they'd need to divert.
A two-engined plane needs to divert once it drops an engine.
Viscount724
Sat Feb 09, 2008 2:25 am
Quoting Stitch (Reply 3):
Three and four engine aircraft are also permitted to make ferry flights with one engine out under certain conditions (obviously with only the crew aboard) to get an aircraft to a maintenance base.
avioniker
Sat Feb 09, 2008 2:58 am
Many 747 operators leave it up to the captain to continue or divert if an engine is lost after departure.
My favorite is the BA 747 that lost an engine after departing LAX and continued on to LHR landing only slightly late. The crew apparently didn't even consider returning to LAX or diverting and BA didn't think much of it either; at least until the press panic artists got hold of it. . .  Silly
 Smile
citationjet
RE: Least Number Of
Sat Feb 09, 2008 3:21 am
Quoting Viscount724 (Reply 4):
And also one engine OFF.........
Photo © Norman Gage
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
TheSorcerer
RE: Least Number Of
Sat Feb 09, 2008 3:33 am
Quoting CitationJet (Reply 6):
Would this not affect the aerodynamic properties of the aircraft? I mean in terms of less drag on the one side than on the other. Could this be corrected simply by adjusting the rudder trim?
Dom
ALITALIA,All Landings In Torino, All Luggage In Athens ;)
avioniker
RE: Least Number Of
Sat Feb 09, 2008 3:42 am
The answer is a simple yes and yes.
Quoting Thesorcerer (Reply 7):
That's normal procedure on a three engine ferry. With the engine off there's less offset rudder trim required.
 Smile
RE: Least Number Of
Sat Feb 09, 2008 6:07 am
Do you mean that they should turn off an engine or two for some reason?
As for the answer, it has been given above.
- Quad can remain aloft on two or three. Two requires a diversion.
- Twin can remain aloft on one. This requires a diversion.
The time aloft is dependent on the amount of fuel. Note also a twin on one engine cruises slower.
XXXX10
RE: Least Number Of
Sat Feb 09, 2008 11:07 pm
Quoting Avioniker (Reply 5):
To be fair there is no evidence that they 'did not consider diverting'. I believe the crew contacted ops for advice and were told that it was up to the captain.
The aircraft diverted to MAN as they were unable to use all of the fuel that they had.
There was an AAIB report which IIRC did not criticize the crew for not landing earlier.
Viscount724
RE: Least Number Of
Sun Feb 10, 2008 12:19 am
Quoting XXXX10 (Reply 10):
The AAIB report on the BA incident:
http://www.aaib.dft.gov.uk/sites/aai...ng%20747-436,%20G-BNLG%2006-06.pdf
thegeek
RE: Least Number Of
Sun Feb 10, 2008 1:20 am
If a four engine plane were light enough, could it maintain level flight at a lower altitude on one engine? If so, they could continue even on two.
RE: Least Number Of
Sun Feb 10, 2008 6:33 am
Quoting Thegeek (Reply 12):
That would depend on the weight.
However:
- I don't know the two engine cruise speed of a typical quad, but I wager it's not too hot. So you might not get where you're going anyway. In other words, divert.
- If a quad lost two, that would be a pretty strong indication of a possible fault independent of the engines. Would you want to continue?  Wink
thegeek
RE: Least Number Of
Sun Feb 10, 2008 7:37 am
Quoting Starlionblue (Reply 13):
Good point.
RE: Least Number Of Engines
Sun Feb 10, 2008 10:46 am
Depending on the AUW of the Aircraft at the time of IFSD.
The B767 & B777 should be able to continue its journey on one Functioning power plant
regds
MEL
David L
RE: Least Number Of
Sun Feb 10, 2008 11:02 am
I'm pretty sure thery're not allowed to deliberately take off with one engine not operating unless it's under the special conditions of a ferry flight, as mentioned above. Continuing when an engine fails after take-off is another matter.
 checkmark  I'd go further than that. I'd say there's plenty of evidence that they definitely did consider diverting and continued to do so throughout the flight.
Francoflier
RE: Least Number Of
Wed Feb 13, 2008 2:40 pm
Every airline operating quads has specific guidelines in its ops manual regarding engine failures enroute for the pilots to follow.
Usually, it'll say that to continue to destination (or to a diversion airport a little more hospitable than a semi-deserted military airbase in Siberia) you need:
- Certain weather conditions at the planned destination
- Terrain clearance for the 2 engines scenario for the remainder of the flight
- Depressurization scenario fuel considerations for the remainder of the flight
- A certain amount of fuel upon arrival at the planned destination airport, and ultimately,
- The commander's satisfaction that the plane is safe to fly to the planned destination.
It varies from airline to airline, obviously, and depends on local regulations.
To give an idea of 1 engine inop performance on a quad, a 744 will burn around 10 to 15% more fuel on 3 engines than on 4. It'll usually have to descend around 2000 to 4000 feet below its optimum cruise altitude. It would usually be able to make it to destination within the above mentioned guidelines from an IFSD occurring around 1/3 to 1/2 of the way to that destination on a typical 12 hours flight, or even from earlier on in some cases. speed and time loss would be relatively marginal.
It all depends on weight and fuel on board, sector lenght, company fuel policy, weather, etc, of course....
When it comes to twin, I don't know of any airline/country regulations that would allow it to continue anywhere other than to the closest suitable airport when in a engine out scenario...
Whether it could physically do it is another question, and it would largely depend on altitude/speed loss and increase in fuel burn, which will obviously be much greater than for a quad.
soon7x7
RE: Least Number Of
Wed Feb 13, 2008 5:56 pm
Is that one of Kalittas'?
KELPkid
RE: Least Number Of
Wed Feb 13, 2008 7:49 pm
Any of them can still fly with no working engines  Smile Just don't stall...but you will for sure be descending. Best to trim for the best rate-of-glide airspeed at that point...and picking out a landing site  Wink The Gimli and Azores gliders both proved this.
FlyUSCG
RE: Least Number Of
Fri Feb 22, 2008 12:24 am
It actually didn't make it to LHR due to lack of fuel and headwinds etc... I think thats why it got so much negative press (and rightfully so).
Go Trojans! Fight On!
