SXDFC
Process Of Painting An Airliner
Thu Feb 21, 2008 10:55 pm
Hey Guys:
I have noticed many times in many pictures when planes first roll out of the paint shop and look sharp and clean, and I always wondered what process it takes to paint one, Is there certain parts of the plane that get removed? Do the wings get painted? Also in the case of a 737 do they plug the eye brows, repaint the winglets? All of this information would be gladly appreciated, I wonder what part of the plane they start with first!
EMBQA
RE: Process Of Painting An Airliner
Thu Feb 21, 2008 11:23 pm
mask it...strip it.... prep it...wash it.... prime it... paint it.....
Mask it..... composite areas and windows are protected during the stripping process.
Strip it...... Chemical stripper is applied. It is left on for a few hours. It is then pressure washed away.
Prep it...... the fuselage is cleaned up by hand sanding all areas.. including composites
Wash it... . the fuselage is pressure washed again....then alodined.
Prime it..... just what it says..primer is applied
Paint it...... the finish coats are applied. Logos are layed out following blue-prints. Placards are installed.
Yes.... many times the wings are painted.
No... on 737 they do not just plug the windows. The plug Mod is pretty extensive.
[Edited 2008-02-21 15:35:46]
FlyUSCG
Thu Feb 21, 2008 11:35 pm
There are several videos on YouTube that are quick time lapses of aircraft painting. Everything from CRJ's to A340's. They are pretty impressive videos and even have some good music with them. I am also fascinated with aircraft painting and would love to do it someday. But definitely check out those videos, really cool stuff.
Go Trojans! Fight On!
FlyUSCG
Fri Feb 22, 2008 12:03 am
Here is Horizon's latest project...
http://www.youtube.com/watch?v=0QVuQyI6aaE&feature=related OSU Beaver's CRJ
http://www.youtube.com/watch?v=7SKY7K_KUDs&feature=related Oregon Ducks CRJ
http://www.youtube.com/watch?v=tPvz6fIKL4I&feature=related WSU Cougars CRJ
I imagine the Huskies plane is in the shop right now.
http://www.youtube.com/watch?v=APOH_rmaNcU 737 Dreamliner
http://www.youtube.com/watch?v=ilXDziiS7H0&feature=related Dragonair A330 assembly painting
There is also a Virgin America one that isn't as exciting as far as the scheme goes but does show the ridiculous number of coats they put on per color.
cancidas
Fri Feb 22, 2008 3:19 am
are there any major advantages to painting after construction like boeing and airbus do it as opposed to embraer?
why is it more common to see airplanes painted with the gear down rather than the gear up and the airplane on jacks. wouldn't having the gear stowed make it easier to evenly paint the fuselage?
"...cannot the kingdom of salvation take me home."
EMBQA
Fri Feb 22, 2008 3:54 am
Quoting Cancidas (Reply 4):
Makes no difference at all.....
FlyASAGuy2005
Fri Feb 22, 2008 5:50 am
Ok so I have a question.
I've heard many people say some "paint jobs" is actually just a bunch of stickers.
Not sure how to explain what I mean but it's just printed graphics and not actually sprayed on.
What gets measured gets done.
Inbound
Fri Feb 22, 2008 6:59 am
Quoting FlyASAGuy2005 (Reply 6):
Yup, it's true. Our entire "livery" at Caribbean Airlines is just a bunch of stickers on a white painted background/base.
Even the huge hummingbird is stuck on.
Photo © Airtrafficontrol
Photo © Suresh A. Atapattu
Maintain own separation with terrain!
tbanger
Fri Feb 22, 2008 7:31 am
Quoting Inbound (Reply 7):
So are ours.
Photo © Rob Van Ringelesteijn
Photo © George Canciani
FlyASAGuy2005
Fri Feb 22, 2008 4:31 pm
Is there an added benefit?
I know our Blue Bonnet and Atlanta Stone Mountain special liveries is stickers too.
EMBQA
Fri Feb 22, 2008 5:04 pm
Quoting Tbanger (Reply 8):
So are ours.
Not all of it...... it's a mix of paint and placards.........
ps.... 389 is due to leave Nashville today.
Quoting FlyASAGuy2005 (Reply 9):
You can do some more complex stuff. Just look at Frontier's tails.......
[Edited 2008-02-22 09:18:37]
Dalmd88
Fri Feb 22, 2008 6:39 pm
This one was all paint.
Photo © Christopher Liao - Spot This!
It has been asked if painting up on jacks with the gear sucked up had any advantages. I think it does, especially on a wide body. I first saw it down that way when we started painting the DHL 767s in ATL. They jacked the plane, sucked up the gear and then lowered the jacks. Two big time savings resulted. First you don't have to mask off the gear wells. Second, the bottom of the plane was now at a level that could be shot from the ground. With the plane on it's gear the belly had to be shot off of scissor lifts. The rest of the plane could still be shot off of the 'Flying carpet' stacker cranes.
EMBQA
Fri Feb 22, 2008 7:05 pm
SXDFC
Fri Feb 22, 2008 7:17 pm
Anyone know if WN's Slam Dunk One or Shamu are stickers?
Photo © John Klos
Photo © Brandon T. Perez
EMBQA
Fri Feb 22, 2008 7:20 pm
Quoting SXDFC (Reply 13):
Painted..........
Skyweasy82
Sat Feb 23, 2008 7:25 am
Actually those are all paint. The silver and soaring 700's are stickers. 738EV and 740EV. 849AS "The Ant Hill" had a grey bottom for a while because that was the one that had the left gear collapse about 6 years ago.
JAGflyer
Sat Feb 23, 2008 4:41 pm
How long does it take to paint an airplane?
Support the beer and soda can industry, your recycle old airplanes!
EMBQA
Sat Feb 23, 2008 8:45 pm
Quoting JAGflyer (Reply 16):
How big is the plane..? How complex is the job...? how many colors...???? what quality do you want...? strip and paint, or sand and paint...? Pick a number.........
JAGflyer
Sat Feb 23, 2008 8:49 pm
Quoting EMBQA (Reply 17):
Dash 8?
B737?
B747?
A380?
Does the paint peel off like "skin" or does it need to be sanded off?
EMBQA
Sat Feb 23, 2008 9:12 pm
Quoting JAGflyer (Reply 18):
You're still asking a question with many answers.....
In the basic sense... I saw UAL 747-400's get painted in about 10-14 days working 3 shifts.... I've seen Piedmont Dash-8 get painted in about 7 days. Keep in mind a lot of that is driven by the number of people you have working the job. We did an E135.... not a Legacy... for a corporate client last year that was in the paint shop for 3 weeks.
[Edited 2008-02-23 13:17:49]
tbanger
Sat Feb 23, 2008 9:15 pm
Quoting EMBQA (Reply 10):
The only painted areas are the blue and orange on the tail. The logo's are "Stickers". I know because we get them made in Oz and send them over for EAMS to put on prior to delivery.
Oh yeah and the large rego under the left wing is painted too. (It's in a vulnerable position and doesn't adhere too well.)
FlyUSCG
Sat Feb 23, 2008 10:53 pm
Quoting FlyUSCG (Reply 3):
And I can now confirm that the Huskies plane is painted and flying the line. I saw it at the Alaska terminal when I pulled into LAX today.
miller22
Tue Mar 04, 2008 3:47 am
This article shows a time-lapse video of an A320 being painted. First is the primer. Then the white base paint, and then the red accents.
http://www.airlineempires.net/content/view/223/79/
Dalmd88
Tue Mar 04, 2008 2:31 pm
I think DL is allocating seven days for the new paint scheme on the 757/767. That is the same for a strip job or a sand job. I believe they are allowing two layers of paint before they strip to bare metal.
Tue Mar 04, 2008 4:24 pm
Quoting Tbanger (Reply 20):
Not to pick on,but the correct term is "Decals".
regds
MEL
57AZ
Mon Mar 10, 2008 2:15 am
Decals are also used on railcars and buses-such as advertising wraps. Decals are fine for viewing at a distance, but the difference in finish quality between decals and paint can be quite noticeable up close. The tourist railroad I worked for experimented with vinyl striping and painted striping and determined that painting was the better method for our livery. We did keep with the vinyl letters for the letterboard though. When working with decals or transfers, you do have to take care that the surface they are applied to is not contaminated and smooth them to prevent air from being trapped.
"When a man runs on railroads over half of his lifetime he is fit for nothing else-and at times he don't know that."
