parapente
US FAA To Impose Special Conditions On Boeing 787
Thu Feb 28, 2008 9:36 am
Article on headlines on Flight International.
I am assuming that Boeing has already forsaw this and built in the required back up sources of power into the aircraft from the origonal design onwards. (ie that it could decend from cruising altitude to land without power as the FAA have stated.)Yes?
BlueShamu330s
RE: US FAA To Impose Special Conditions On Boeing 787
Thu Feb 28, 2008 10:08 am
So I drive a 4x4. So what?! Tax the a$$ off me for it...oh, you already have... :-(
smokeyrosco
Thu Feb 28, 2008 10:48 am
Whats
a permanent magnet generating system
EDIT: Never mind, google is my friend.
[Edited 2008-02-28 02:55:09]
John Hancock
scbriml
Thu Feb 28, 2008 11:44 am
I'd be surprised if this comes as news to Boeing. They said they were working very closely with the FAA to define the certification requirements, so it would be a bit of a shock if this is the first time the FAA has raised this issue with Boeing.
Quoting Smokeyrosco (Reply 2):
Whats
I suspect it's a system that generates a permanent magnet.  duck
pilotboi
Thu Feb 28, 2008 2:04 pm
From the article:
This change requires the aircraft's two engines to drive four auxiliary power units (APUs) generating 1.45mW of electricity
For being an aviation related news site, I can't believe they got this wrong. These are not called APUs, these are called Integrated Drive Generators (IDGs).
parapente
Thu Feb 28, 2008 2:11 pm
"This change....." so does it have 4 IDG's already or not. If its "a change" it suggests not. If it does then is it news at all? Confused!
Thu Feb 28, 2008 2:25 pm
Is this really a big deal? Doesn't the FAA impose "special conditions" on pretty much any new major airliner since any new airliner will probably incorporate some sort of technological advance?
pilotboi
Thu Feb 28, 2008 2:42 pm
Quoting Pilotboi (Reply 4):
Quoting Parapente (Reply 5):
The change the article is talking about the new FAA requirements for the aircraft.
The whole APU thing was just an error, but I brought it to the writer's attention and he has fixed it promptly.
It does already have 4 IDGs, 2 per engine. Nothing is changing there.
Quoting Starlionblue (Reply 6):
Basically, yes. But then of course, how could the FAA predict what the aircraft industry is going to come up with next?
NoWorries
Thu Feb 28, 2008 2:43 pm
Looks like the article changed to say four IDGs instead of four APUs. Even this may not be strictly correct -- I don't know if they're still called IDGs because the 787 generators aren't regulated to a constant 400Hz, the frequency is allowed to float. I don't think it's a surprise to Boeing -- what's a little bit different here is that Boeing needs to prove it can restart everything if all electrical generators (including those driven by an APU) go offline. Even generators typically need an external electricity supply (to excite their field windings) -- so they need to prove that battery power and/or electricity from a permanent magnet generator is sufficient to get the system restarted.
parapente
Thu Feb 28, 2008 3:20 pm
Thank you No Worries. So fundamentally the basic engineering does not need to change but that the FAA require proof that it does do what they say it will do. In this case I imagine that they (Boeing) have already satisfied themselves that the electrical power system can stay "online" in the event of a total loss of mechanical power for the required FAA time. Is that right?
Tod
Thu Feb 28, 2008 3:35 pm
The 747, 757, 767 and 777 Type Certificate Data Sheets all list Special Conditions.
Tod
NoWorries
Thu Feb 28, 2008 3:37 pm
Quoting Parapente (Reply 9):
Is that right?
I think so. Sort of a chicken and egg problem -- the mostly electric 787 systems need some electricity to get started -- it has to come from somewhere. I'm assuming the same problem (to a lesser degree) exists with more conventional designs -- on non-787s do engines/APUs still need some electric power to be restarted in flight? I'm assuming the issue on the 787 is that it needs more electric power than a typical plane to get everything restarted.
Thu Feb 28, 2008 3:45 pm
That is correct, FAA/EASA rules in many was lag behind new designs.
pilotboi
Thu Feb 28, 2008 4:01 pm
Quoting NoWorries (Reply 8):
I don't think that's the specific issue here. The issue they are talking about is making sure that the aircraft is capable of landing in the event of both engine loss. To do this, they need to ensure that the flight controls can be used after both engines are gone.
Quoting NoWorries (Reply 11):
That sounds possible, as the starters (which are the IDGs) are electric only and no bleed air is used. But I would think the battery and RAT should provide adequate power to use the starters.
True. For some reason they've still been labeling it as an IDG. But some articles do point out that it is not a typical IDG. Maybe they'll come up with a new name for it. But probably not...leading to more confusion.
I would imagine so. I highly doubt Boeing would overlook this problem. I think it's all been done on paper, and numerous independent tests. But it all comes down to a true test when they get it in the air.
NoWorries
Thu Feb 28, 2008 5:21 pm
Quoting Pilotboi (Reply 13):
Ah, OK .. I think I get it now ... If a more conventional design loses all fuel-burning power sources (engines + APUs), it needs enough electrical power for flight computers (batteries) and enough hydraulic power for flight surfaces (pump on the RAT) -- what's different is that if the 787 loses all fuel-burning power, it needs more electricity (flight computers + control surface actuators) and hence bigger batteries and/or on the RAT a permanent magnetic generator (which doesn't need an external electricity source to operate).
This makes me wonder why a similar requirement doesn't exist for the A380 -- it's hydraulic pumps are electrically operated -- seems like that implies a similar need for greater emergency electrical power, or an assumption that all engines and APU's are extremely unlikely to fail simultaneously.
[Edited 2008-02-28 09:40:02]
tdscanuck
Thu Feb 28, 2008 5:52 pm
Quoting Pilotboi (Reply 7):
They're not IDG's. They don't have integrated drives (the "ID" part). They've VFSG's...Variable Frequency Starter Generators.
No.
Yes. A "special condition" is just the FAA recognizing that the existing FAR's don't address some new technology. If you didn't have a special condition on a new aircraft I'd be very suspicious that the OEM wasn't using all the new tools that are available.
Quoting NoWorries (Reply 14):
The 787 still needs hydraulic power too...only the spoiler actuators are electric.
Quadruple engine failure isn't something that quad's are typically designed for.
Tom.
Thu Feb 28, 2008 5:54 pm
The A380 has dual actuators for control surfaces, hydraulic and electric, the hydraulic system pressure and electricity is engine generated (4 engine redundancy).
Electrical power is backed up with 4 engine driven generators, the APU, the RAT, and batteries. Hydraulic power is generated by each of the 4 engines, and the control surfaces are based up with Electrical Backup Hydraulic Actuators (EBHAs). They are a combination of a conventional servo-control and an Electro-Hydrostatic Actuators (EHA). In normal mode, they operate as conventional servocontrols. If there is a hydraulic failure, they operate as EHAs.
The A380 is the first large jet to be made for some time that has full redundancy in the event of total hydraulic system failure.
The electric hydraulic pumps are only on for ground operations like opening cargo doors.
2H4
Thu Feb 28, 2008 6:02 pm
Almost sounds like the FAA wants giant magnetos installed.  biggrin
2H4
Intentionally Left Blank
luv2cattlecall
Thu Feb 28, 2008 7:02 pm
There's a strong chance I have no clue what I'm talking about...but I thought it was alternators that needed an external electricity supply to excite the windings, while generators start cranking out the juice whenever they're rotating?
KELPkid
Thu Feb 28, 2008 7:08 pm
Quoting Luv2cattlecall (Reply 18):
Yup, however generators are much heavier than alternators, on account of the fact that they have to have very large permanent magnets inside the casing...
pilotboi
Thu Feb 28, 2008 7:16 pm
 checkmark  You've got it, except as Tdscanuck said:
Quoting Tdscanuck (Reply 15):
(To backup what you said...) A lot of people forget that the 787 still has hydraulics. What has been eliminated is bleed air, not hydraulics. The hydraulic system is still there, but there's a slight change. In the 787, there is no air-driven hydraulic pumps, they are all electric. So this becomes a slight problem when you lose all electricity.
Ah, that's a better name. All the documentation I've seen so far (including Boeing) has labeled them as IDGs.
KELPkid
Thu Feb 28, 2008 7:21 pm
Quoting 2H4 (Reply 17):
2H4
Imagine this in the 787 panel:
Big version: Width: 85 Height: 113 File size: 2kb
 Wink
NoWorries
Thu Feb 28, 2008 7:37 pm
Quoting KELPkid (Reply 19):
The terms alternator and generator have fairly loose definitions. Some assume than generator implies a DC generator, and alternator is a shortcut name for alternating current generator. Either can use permanent magnets or an electromagnets to supply the reactive field. Large generator/alternators almost always use an electromagnetic field. In an automobile, generator often implied the old heavy permanent magnet DC generator, and alternator is typically meant to imply a three-phase AC generator with an externally supplied field current -- hence you can't push start a car with an alternator without a least a trickle of electric current from the battery (at least this used to be the case -- now days with integrated starters/alternators and all sorts of hi-tech doodads my info may be dated). Also, with advancements in alloys, very powerful permanent magnets are now possible -- for example some hybrid cars have permanent magnet motor/generators.
KELPkid
Thu Feb 28, 2008 8:10 pm
Quoting NoWorries (Reply 22):
I don't know that you could bump start a vehicle with a generator with a completely dead battery, either. The spark has to come from somewhere  Wink My old '64 Ford F-100 did have an electric ignition...
dl757md
Thu Feb 28, 2008 9:20 pm
They run out of fuel just as easily as twins and they have flamed out for other reasons like volcanic ash. Is there a design requirement that is specific only to twins that addresses dual engine failure?
DL757Md
Thu Feb 28, 2008 9:31 pm
Quoting Dl757md (Reply 24):
No.
tdscanuck
Thu Feb 28, 2008 10:55 pm
Quoting Pilotboi (Reply 20):
I got VFSG's off a Dec-2007 787 maintenance orientation...not sure if that's what will stick when it finally delivers but it seems to be current for now.
Tom.
Thu Feb 28, 2008 11:33 pm
Or perhaps giant flywheels? Big grin
Users browsing this forum: jnj561 and 1 guest
