flymad
Cabin Pressurisation Question
Sun Mar 23, 2008 6:12 am
Hi guys, first time I'm posting on Tech/Ops. I'm not in aviation, just an avid enthusiast.
On the main forum is a discussion about a F9 A320 that had problems with pressurisation in-flight and one of the comments was that pax in the rear of the a/c felt the effects more than those in the front. The question I posed there was why would this be? As I said there, I would like to be educated. Can anyone help?
RE: Cabin Pressurisation Question
Sun Mar 23, 2008 1:58 pm
Quoting Flymad (Thread starter):
No physical reason for this, the pressure exerted on the inside of a pressure vessel is equal.
Jetlagged
Sun Mar 23, 2008 4:33 pm
Possibly a problem with air quality rather than cabin pressure. It's possible some parts of the cabin might get more recirculated air rather than fresh air.
FredT
Sun Mar 23, 2008 5:10 pm
I assume that the A320, the specifics of which I am not familiar with, like most other aircraft has the valves regulating the cabin pressure at the rear of the cabin.
If so, the comment is not implausible. The air in the cabin has a mass which is not insignificant. For the air pressure in the front of the cabin to drop due to the regulating valve acting up, the air in the front of the cabin has to expand. The gas law, pV=nRT. If the air in the frontmost meter of the cabin is to expand by 20%, it has to push all the air in the rest of the cabin 20 cm aft. This means accelerating the mass of the air in the rest of the cabin. This acceleration will not by any means be instantaneous. This will slow the expansion down and with it the rate of pressure drop.
Thus, pressure spikes will be evened out somewhat. If someone cares to crunch the numbers, go ahead. I have no idea if this evening out is enough to make a significant difference on the degree of discomfort felt. The effect will be more noticeable the more abrupt the pressure changes are next to the valve.
If there's discomfort due to audible effects of the valves acting up, that discomfort will decrease rapidly with increasing distance from the source of the noise.
/Fred
LongbowPilot
Sun Mar 23, 2008 5:14 pm
I am by no means a expert on here but do know, from prior ramp experiance, that the pressure relief valves on MD-88s are in the rear of the cabin. So it would make sense there could be a pressure differential in the aircraft between the front and rear if it were not sealing properly.
I have also sat in the aircraft during a rapid de-pressurization of the aircraft. The effect was actually pretty neat, with a "fog" coming from the back to the front in a couple of seconds. I could be wrong, but that might explain the reasons.
-Attack
Jetlagged
Sun Mar 23, 2008 5:48 pm
Quoting FredT (Reply 3):
Surely not. The air in the frontmost meter of the cabin (assuming this was indeed where all the air inflow is) is not constrained in any way and the increased pressure will be distributed along the cabin at the speed of sound, more or less. Also air inlets to the cabin are distributed throughout it's length, not concentrated at the front.
Because the air is flowing through the cabin towards the rear there will be a slight pressure gradient along it. But if cabin pressure is increased by 1 psi that increase will be the same along the cabin. So pax at the rear will, generally speaking, experience the same cabin pressure and pressure fluctuations as those at the front.
As I hinted in my first reply air quality at the rear may well be very much worse, and that coupled with an 8000ft cabin altitude might make things worse back there.
FredT
Sun Mar 23, 2008 10:03 pm
Quoting Jetlagged (Reply 5):
Surely not.
Jetlagged,
surely. You cannot argue with physics. The effect is there, exactly as I described. If any pressure change would propagate through the cabin instantly (or, for that matter, at the speed of sound), you either have to explain why the gas law does not apply (i e how the pressure can drop without the air expanding) or how the inertia of all the air in the cabin can be ignored (enabling instant expansion).
The question is not if the effect is there, as described, but if it is significant enough to be the cause of the subjectively experienced differences in the OP.
I am aware of this but it is insignificant in the situation discussed, which clearly pertains to a valve acting up.
Movement of a fluid is not linked to a pressure gradient. Acceleration in a fluid is. If the pressure is lower at the back of the cabin, the pressure difference will exert a force on the air in the cabin, which will accelerate towards the aft of the aircraft until the mass flow has equalized the pressure and equilibrium is restored. If there's a constant inflow (a source) at the front of the cabin and a constant outflow (a sink) of an equal mass of air at the rear of the cabin, equilibrium and a constant pressure throughout the cabin will only be reached if there is a flow from the front to the rear equalling the in- and outflow.
Rgds,
/Fred
ex52tech
Mon Mar 24, 2008 9:58 pm
I have been wondering if the pax. were feeling uncomfortable due to cabin temperature problems, and was it brought up as a pressurization problem, when it was actually a trim air problem.
When I worked line maint. on A320s we had some pressurization problems that revolved around dried up and brittle O rings, that are used to seal the slip joints on the pac. plumbing in the pac. bay, leaking so badly that the cabin altitude could not be maintained.
Quoting LongbowPilot (Reply 4):
I don't think I have ever seen one of those open and then stay open.
"Saddest thing I ever witnessed....an airplane being scrapped"
tdscanuck
Tue Mar 25, 2008 4:34 am
Quoting FredT (Reply 6):
The effect is real, but it's *tiny*. Airflow velocities inside the cabin are very low, much less than Mach 0.3, which is where compressibility starts kicking in. One of the properties of low speed flows is that you need extremely small pressure gradients to cause very large velocity gradients. Conversely, small velocity gradients (like you have in an aircraft cabin) are caused by very very very small pressure differences. I'd be pretty shocked if the fore-aft pressure differential was detectable by humans.
Keep in mind that weather systems live in the same type of speed environment...60 kph winds are caused by minuscule pressure differentials.
Tom.
Analog
Tue Mar 25, 2008 4:47 pm
Quoting Tdscanuck (Reply 8):
For steady-state I agree.
What about transient & periodic variations? Is there a potential mechanism for an oscillation in cabin pressure? If the control system (ECS) has some sort of limit-cycle, either because of the use of hysteresis, or because of some issue with the outflow valve, or something else, the pressure oscillations might be more significant in the rear (or front) of the aircraft.
Note: I'm presenting this as a question (Can this happen?), not to say that this does happen.
tdscanuck
Wed Mar 26, 2008 12:17 am
Quoting Analog (Reply 9):
I've never heard of it myself, but I don't see any reason it couldn't happen. The pressure vessel is a nice shape to set up a standing wave if you were unlucky enough to hit the right frequency, although the resonant frequency of an air column that long would be way below the threshold of hearing...maybe enough to feel though. Our bodies can react to sound frequencies lower than ones we hear.
Tom.
avioniker
Wed Mar 26, 2008 7:42 pm
Quoting Tdscanuck (Reply 10):
You are all dancing around the issue. There is a variable that must be considered i.e. the laws of Depletion and Replenishment. There is most indeed a wave effect in a cabin experiencing any fluctuation in the outflow valve and it will be most measurable or noticable at the points of termination or change of the wave. In an 80 that's at the rear.
In the case of an outflow valve suddenly opening the pressure in the rear of the aircraft must decrease before the flow can start from the front. Same rules apply.
Splash some water in a bowl or look at one of those lava wave machines and you'll see what happens.
[Edited 2008-03-26 12:44:32]
FredT
Wed Mar 26, 2008 8:26 pm
Interesting discussion with some knowledgeable participants!  Smile
Certainly. Detectable by the sensitive human ear, which will detect very tiny pressure variations as sound? Possibly.
That's true, and you are right in pointing out that it is also completely irrelevant as the velocities involved will be nowhere near those required for compressibility to be anything of a factor.
But when we have a dump valve acting up, the pressure gradients will be very significant.
I must also admit that I fail to understand which velocity gradients you are talking about. I'm concerned with the pressure gradients and resulting accelerations.
Oh, it most certainly would be. At the instant of the valve opening, the pressure at the valve will be that of the ambient atmosphere but the pressure in the rest of the cabin will be whatever the pressurization altitude dictated. That's a noticeable difference if ever I saw one.
However, that is again not the subject of the discussion. The facts are
1) The pressure will drop significantly in the entire cabin rather abruptly
2) This will be easily noticeable by anyone on board
The question is if an increasing distance from the valve will make the pressure drop less abrupt to such a degree that the discomfort experienced will lessen.
That's a totally different setting, and I wouldn't say that the speed environment is the same either. Remember that the Coriolis forces are the result of moving air around on a rotating sphere where the rotational speed varies from 0 to almost 1700 km/h.
I see a need for visualizing what is going on better.
The cabin of an A320 is 27.5 m long with a diameter of 3.7 meters. Let us assume a cylindrical cross section of the same diameter for the sake of this discussion. Assume an atmosphere inside the fuselage equal to the ICAO standard atmosphere at 8000'. That's 752.6 hPA and 0.963 kg/m^2.
Cut the air inside the cabin one meter from the forward bulkhead and replace the air behind with a moveable piston. Let this piston have the same weight as the air behind the 1 m cutoff point. Volume times density gives us a mass of 285 kg. Anyone surprised?
Assume that the valve will instantly drop the pressure at the rear of the cabin to the equivalent of 12000' altitude in the standard atmosphere. That's 644.4 hPa and 0.849 kg/m^3.
Visualize this 285 kg piston with 1 m of 752.6 hPa in front and 644.4 hPa behind. Now you have a situation reminding of what we have in the cabin when the dump valve opens, albeit rather simplified.
For the pressure at the front of the cabin to instantly drop to 644.4 hPa, as it did at the valve, the volume ahead of the piston would have to instantly increase equivalent to moving the piston from 1 m from the bulkhead to 1.13 m.
Is it likely to have this 285 kg piston instantly accelerate to infinite velocity, jump 13 cm aft and instantly decelerate to a standstill, or will it in fact accelerate slower and act as a damper on the pressure reduction?
The initial pressure drop (i e the fact that the pressure is dropping, not the magnitude of the drop) will propagate throughout the entire cabin, starting at the valve, at the speed of sound. The rate of pressure drop will however decline with increasing distance from the valve.
/Fred
MD11Engineer
Wed Mar 26, 2008 10:45 pm
Even then, while the outflow valve is indeed located at the rear end of the pressure hull, the airflow through the passenger cabin (due to cabin floor and liners) runs from the aircon outlets on top of the cabin downwards to grilles at foot level on the dado panels. From there the air is routed around the cargo hold liners and aft to the outflow valve.
If there was a measurable pressure gradient in the cabin, (beside the one causing the circulation of air from the aircon ducts to the grilles), it would be in vertical direction.
Jan
Quoting FredT (Reply 12):
I have been carrying out pressure runs on A320s after D-checks to verify the operation of the positive overpressure valves and could not feel any difference in pressure. The only indication that the valves had opened was the ECAM message.
Jan
tdscanuck
Thu Mar 27, 2008 12:27 am
Quoting Avioniker (Reply 11):
snip...
I'm not dancing around the issue...the point is that the pressure drop due to opening the valve is so small as to be meaningless.
Any time you have a pressure gradient in a fluid with part of the fluid stationary, you have a velocity gradient, or else you're not at steady state. Given the typical dimensions of a fuselage you hit steady state very quickly, so if you're got a pressure gradient in the fuselage you're going to have a velocity gradient too.
At the valve, there is a huge pressure differential. But that drops off *extremely* fast as you move away from the valve. Anywhere in the cabin I would expect functionally constant pressure.
No, it won't. If you crank the outflow valve full open it's going to very quickly go sonic and choke (some aircraft actually use sonic chokes in place of the outflow valve). It takes a very tiny pressure difference to get that to happen in the immediate vicinity of the outflow valve, so the instantaneous drop in overall cabin pressure will be small.
I doubt it, but I'm willing to be proven wrong.
This assumption is invalid, which is where the rest of the example goes wrong. The valve will instantly drop the pressure at the valve outlet to ambient. The pressure loss across the valve is huge, so the pressure drop even small distances inside the cabin is small. The example you're positing is as if the tail fell off the aircraft and opened the whole back of the fuselage to ambient at once. Obviously, that would cause a huge pressure differential and noticable effects.
The area of the outflow valve compared to the area of the cabin is very very small. As a result, the velocity in the cabin to support even very fast flows in the valve is very very small. This means the pressure gradient in the cabin is very very very very small. It's only in the immediate vicinity of the valve (we're talking inches here) that you're going to pick up significant velocities and pressure gradients.
Tom.
Jetlagged
Thu Mar 27, 2008 2:44 pm
Fred,
In an aircraft cabin, the volume of air is constant. Pressure changes are related to changes in air mass. Less air in the cabin means less pressure and vice versa. The outflow valve controls pressure by allowing more air out or keeping more air in. At steady state the airflow into the cabin equals the airflow out of it.
Ask yourself this, how did the front section of the cabin in your example get pressurised? If it was by a piston acting on a fixed mass then pressure and volume would be directly related, but in an aircraft cabin pressure increases because of excess air inflow into the cabin. So the mass of the air has increased too. Pressure waves propogate at the speed of sound. The mass of air in the cabin is basically stationary, so accelerating it in the manner you describe is not significant and the pressure throughout the cabin will change at almost the same time.
Regarding pressure differences along the cabin, any air flow though a tube will resuilt in some pressure loss along it. That is the pressure difference I was referring to.
The fact that air inflow is distributed along the cabin [u]is/u] significant, because it means some air inflow is very close to the outflow valves. In other words the source of the pressure increase (air inflow) is not concentrated at one end of the cabin.
FredT
Sun Mar 30, 2008 8:46 am
If anyone reading this but the three of us still haven't made up his or her mind, please speak up. If not, I think it is time to agree to disagree and let this thread die.
While theoretical discussion is fun, I think the practical point made by MD11Engineer is more interesting than all the theory. The plenum chamber and flow restriction of the cargo bay/dado grilles as described, if the arrangement is similar in the A320, should dampen out any sudden pressure changes enough for theoretical effects such as those discussed here to be effectively masked.
Quoting Tdscanuck (Reply 14):
Yes, the assumption made is similar to the rear of the fuselage dropping off, and that is not the real life situation. However, that's the beauty of an illustrative example as opposed to, say, a true-to-life calculation (which I'm still offering anyone the joy of making). You can make representative assumptions, say assume an instant pressure drop rather than the more realistic "very sharp pressure drop", to make it clear to the casual reader that e g, as in this case, the inertia of the air in a closed volume is a factor in the rate of pressure drop throughout the volume.
And steady-state conditions are exactly what we are not discussing here.
Jetlagged,
we're not talking about how the cabin gets pressurized. Completely different process over a much longer time span.
1) We are not talking steady state.
2) We are talking very short time spans, where cabin air inflow will not be a factor as the volume over this time span will be completely insignificant.
Quoting Jetlagged (Reply 15):
Which means moving mass around, hence inertia. My point exactly.
You just stated (correctly) that a pressure drop will mean a reduction of the mass of air in the cabin. In a depressurization, just how do you propose that a mass of air equal to the mass reduction will get to the outflow valve while being stationary?
Jetlagged
Sun Mar 30, 2008 2:12 pm
Quoting FredT (Reply 16):
Jetlagged,
I disagree, the mechanism for pressure change is the same, whether over the long term or short term.
1. We were talking basically steady cabin pressure, with small fluctuations due to the outflow valve acting up. You said a 20% change in pressure at the front would require a large movement of air aft first. Very true, but a 20% pressure change is huge, and would be obvious to the flight crew on ECAM as a cabin altitude change and a cabin vertical speed indication. If you scale your pressure fluctuation back to something realistic then the amount of air movement necessary is correspondingly very much smaller.
2. Very short time spans? You talked about a 20% pressure reduction in the front section. Was that In a short time span too? There'd be a few ears popping as a result of that. In the short space of time you speak of the outflow valve cannot do much to local pressure at the rear of the cabin. If it were a large change over a long period of time you would be tlaking about a failure of the entire system, not some minor fluctuation.
You aren't moving the entire mass of cabin air around very much, otherwise you'd feel the air moving while sitting in the cabin. Inertia is barely relevant to this scenario.
Now you introduce rapid depressurisation, which I had not talked about, to discredit what I said. I have always had the greatest respect for you and your posts, but moving the goalposts around like this is silly.
FredT
Sun Mar 30, 2008 2:39 pm
Quoting Jetlagged (Reply 17):
No, we were not. I was talking about very abrupt pressure changes (spikes) due to a dump valve opening or similar major malfunctions at altitude. I see now that the OP does not mention anything about how abrupt the pressure changes were.
As we have apparently been talking about completely different things, small wonder we've been unable to reach any kind of consensus!
Cheers!
/Fred
Jetlagged
Sun Mar 30, 2008 11:58 pm
Quoting FredT (Reply 18):
Easily done. Now it all makes sense.
Mon Mar 31, 2008 8:31 am
window blow out at Altitude.
regds
MEL
FredT
Mon Mar 31, 2008 5:06 pm
Quoting Jetlagged (Reply 19):
Now let us argue about who was the first to misinterpret and thus responsible for picking up the tab for the first round of conciliatory malt-based beverages...  Wink
Jetlagged
Mon Mar 31, 2008 8:12 pm
Quoting FredT (Reply 21):
Would that be Ovaltine or the hard stuff (Horlicks)?
twal1011727
Wed Apr 02, 2008 12:29 am
Quoting Ex52tech (Reply 7):
The positive and negative pressure relief valves on the MD88s are located fwd of the left wing.
The outflow valve and ground pressure dump valve (the big hole with the rotating door) is located under the left engine
just in front of the rear lav service panel.
KD
Analog
Wed Apr 02, 2008 1:01 am
Quoting Jetlagged (Reply 22):
MMmmmmm beer.
Jetlagged
Wed Apr 02, 2008 3:02 pm
Quoting Analog (Reply 24):
MMmmmmm beer.
I think Fred might have had something more "Scottish" and "spirited" in mind, and I'd go along with that idea.  Smile
Users browsing this forum: 744lover and 1 guest
