Analog
Flickering Lights On Ground Power
Wed Mar 26, 2008 3:59 am
Last week I was on a CO 735 that had the most awful, seizure-inducing flickering cabin light. One of the bulbs was going bad (I assume). The flicker stopped when we pulled away from the gate. Why is this?
I assume that the flicker stopped when the aircraft stopped using ground power. Is this because ground power is at 60Hz and power generated on board is 400Hz? Or is it related to voltage (ground power or APU vs. generators on the engines)?
This wasn't the first CO 73x that had this problem. The previous one (733) flickered at the front of the F cabin where the FAs work. I can't believe that the FAs can live with this. If I were an FA I'd make damn sure to bitch and moan until these things were fixed. Sorry, I would bring this to the attention of the appropriate persons in an effort to resolve this maintenance issue.
tdscanuck
RE: Flickering Lights On Ground Power
Wed Mar 26, 2008 4:21 am
Quoting Analog (Thread starter):
It sounds like a bad ballast in lamp (I'm assuming it was a fluorescent). Could be that ground power was just flaky enough to throw it off but aircraft power was OK.
Ground power is 400 Hz too (plus or minus some tolerance).
Tom.
Bartonsayswhat
Wed Mar 26, 2008 5:15 am
yeah ground power constantly fluctuates, be it from bridge power or a diesel GPU. APU power is much more consistant, which is why most of the fmc updating is done on the APU, as a power surge can wipe out the whole thing, or so i've been informed. also does anyone know, just as a plane arrives or leaves the gate, when it is switched from GEN/APU to GPU the lights flick once?
Wed Mar 26, 2008 8:05 am
Depoending on the condition of the GPU connected at that time.Its difficult to tell from here,but I presume the GPU could have had a voltage fluctuation issue.
regds
MEL
Airbus_A340
Wed Mar 26, 2008 10:21 am
Quoting Bartonsayswhat (Reply 2):
On the Airbus the Ground Power Control Unit (GPCU) produces what's called a 'reference frequency' used by the Ground Control Unit to provide sycronisation for No-Break-Power-Transfer (NBPT).
In English, that means u don't get the lights flickering or horrible 'clunk' sounds when you change from GPU to APU or APU to engine Gens, or vice versa that you would find on other older aircraft.
Usually APU is turned on about 20 minutes before departure, and turned off after pax have disembarked, unless it's a quick turnaround.
[Edited 2008-03-26 03:30:11]
People. They make an airline. www.cathaypacific.com
Dalmd88
Wed Mar 26, 2008 2:20 pm
Even relatively new ground power units can cause all sorts of strange happenings. Here in BOS our new terminal has new units at every gate. We frequently get calls in the morning about systems not testing correctly. The standard answer is switch to apu power and run the test again. If it is still a problem call back and will send someone out. I think the 737NG tends to have the most issues with flakey ground power.
Analog
Wed Mar 26, 2008 2:52 pm
Quoting HAWK21M (Reply 3):
It was only 1 bulb out of many, though I guess "bad" power may well bring a marginal bulb/ballast over the edge.
Mon Jan 18, 2016 9:12 am
Quoting Analog (Reply 6):
In that case look more like a Bulb/Ballast issue ....
ZaphodHarkonnen
Mon Jan 18, 2016 9:38 am
I would have thought the power would have been transformed for the lights and other internal systems, something like 120V or 240V AC. Or do all the lights and such run off the standard power bus? I'm not including flight management stuff in that as I'm sure that has its own power requirements.
shamrock137
Sat Jan 23, 2016 11:20 am
Usually the transition from aircraft to ground power will cause a flicker or two.
Quoting Airbus_A340 (Reply 4):
I noticed the opposite, the A320 had a very audible clunk in the cockpit and front galley when transiting from aircraft to ground power.
Time to spare? Go by air!
glen
Sat Jan 23, 2016 4:38 pm
Quoting Shamrock137 (Reply 9):
The A330 and A340 have No-Break-Power-Transfer (NBPT), but the A320 does not and therefore has the clunk and short darkening. On the 330/340 you have smooth power transitions.
"The horizon of many people is a circle with zero radius which they call their point of view." - Albert Einstein
shamrock137
Sat Jan 23, 2016 4:54 pm
Quoting glen (Reply 10):
Interesting! Now that you mention it I never noticed a transition on the larger Airbuses, I always assumed it was because the APU was started before boarding.
Edit* I also didn't realize this thread was 7 years old! HAWK21M is the champion of resurrecting old threads haha.
[Edited 2016-01-23 08:56:45]
fr8mech
Sat Jan 23, 2016 5:49 pm
Quoting ZaphodHarkonnen (Reply 8):
Really depends on the electrical architecture of the aircraft. Been a long time since I worked pax aircraft but, I seem to recall that the PSU lighting was 28VAC...and, I suspect that would vary by aircraft type.
The typical aircraft (not B787 or A350, as I understand, they are a little different electrically), there are a few different voltages:
-120VAC
-28VAC
-5VAC
-28VDC
-5VDC
It all runs at 400hz, except the DC stuff, of course. Anything requiring a different frequency, would change the frequency after the electricity makes it to the unit.
As for the issue the OP asked about, I suspect a marginal ballast. A 737-500 should be able to handle some frequency/voltage fluctuations without too much trouble. Newer technology aircraft have a harder time dealing with these fluctuations. Regardless of aircraft age, we will always put an aircraft on APU power if the electronics are exhibiting issues on pre-flight.
Let me add the standard disclaimer: while aircraft design tends to be consistent, within the regulations, there is variation based on manufacturer philosophy and customer preference.
[Edited 2016-01-23 09:51:58]
CanadianNorth
Tue Jan 26, 2016 9:01 pm
Was the cabin cold (first flight of the day after sitting outside on a cool night type deal)? Around here it's pretty normal when you power up a cold 737 the cabin lights will usually misbehave in a variety of ways, but once the heat has been on for a while and things warm up it seems 99% of the time the lights smarten up and work fine for the rest of the day.
Could also be as mentioned before a bad light or ballast, or a getting ready to be bad light or ballast combined with a GPU that's on the upper or lower end of tolerances. GPU power usually works fine enough but I have noticed over the years that APU power generally does seem more stable and consistent. Should all in theory be an even 120v 400 hz regardless of APU generator, engine generator or GPU, but as with most things there is a +/- tolerance.
HS-748, just like a 747 but better!
Mon Feb 29, 2016 6:53 am
Quoting Shamrock137 (Reply 11):
I guess when some thread is interesting & worth a contribution it does get resurrected ..... Maybe Im guilty of this
But on a serious note....there are some fantastic discussions on this forum, which are very educational & when read one does feel the need to add to it.Thats why I believe the Tec/Ops forum should never archive threads ever.
Quoting CanadianNorth (Reply 13):
Just curious does it apply to todays LED lights too
shamrock137
Mon Feb 29, 2016 4:29 pm
Quoting HAWK21M (Reply 14):
Agreed, this is my favorite forum on the site.
Not that I have noticed, although most of the aircraft I am familiar with don't use LED cabin lighting, just LED reading lights and galley lights. However they don't seem to run into the same issues as the florescent lights in the cold.
Users browsing this forum: packcheer, TailDragging and 2 guests
