khenleydia
Question On Wing Design...
Sun Mar 30, 2008 8:15 am
I have wondered about this for a long time and I decided to actually post my question. Not sure of the right words or ways to explain it, so it makes it hard to look for duplicates too.
Examples:
Photo © Duncan Monk
Photo © Artur Jarosz - Warsaw Aviation Photography
Two different planes, but I want to focus on a certain part of the wing. Looking at where the Engine Mount (?) attaches to the wing... The question is this. With the KC-10, there is a rather large 'lip' that sticks out over the Engine Mount. The 757 has one too, but not as big. Thinking of airflow, why not smooth that design so air passes over it easier? I understand you want air under the wing, but I would imagine that these 'lips' disrupt the airflow a bit. Good or bad??
KhenleyDIA
Missed an 'N' in the title. Bad keyboard.
[Edited 2008-03-30 01:16:26]
Why sit at home and do nothing when you can travel the world.
FredT
RE: Question On Wing Design...
Sun Mar 30, 2008 8:57 am
When the leading edge slats (the moveable surfaces you see deflected downwards in the pictures) come up, that lip will be perfectly integrated with the rest of the wing. Redesigning it to be smooth with the slats extended would mean it would not be smooth with the slats retracted and hence hamper the aerodynamics in the region of flight where it will really cost you.
Rgds,
/Fred
spencer
Sun Mar 30, 2008 11:34 am
Quoting KhenleyDIA (Thread starter):
In fact most of the lift, or a great percentage of it, comes from air passing over the upper surface of the wing. The greater distance the airflow has to travel over the top surface, as opposed to the lower surface (due to the shape of the wing) results in a faster airflow on top, leading to a lower pressure region, producing lift. From the images you've linked there looks to be a greater area above the "lip" than below.
Spencer.
jetmech
Sun Mar 30, 2008 12:17 pm
I think the engine pod and pylon in general will disrupt the airflow around that region of the wing. Many commercial airlines have strakes on the sides of the engine cowls to help remedy this situation. You can see these strakes on the picture of the DC-10.
IIRC, these strakes general powerful vortices which help to re-enrgise the sluggish flow around this region. This makes it much more likely that the airflow will remain attached to the region of the wing behind the pylon. I believe that this is most important for high angle of attack operations such as rotation on take off. I'm not too sure of the importance of the strakes for cruise conditions.
You can just see the vortice coming off the cowl strake upon rotation in these videos.
They are much clearer in these photos.
Photo © Lasse Kaila
Photo © Belgium Air Force Sgt. Dirk Voortmans
Photo © Tim de Groot - AirTeamImages
Photo © Javier Guerrero - AirTeamImages
Regards, JetMech
tdscanuck
Sun Mar 30, 2008 6:48 pm
You're always going to have some airflow disturbance where the pylon joins the wing because of the abrupt changes in surface normals. So the question becomes...where do you want your disturbed air going? The top surface of the airfoil is far more sensitive to separation and disturbed flow than the bottom, so you want to keep you "dirty" airflow under the wing, not over it. I suspect that's why the slight overhang on the leading edge. In cruise, that probably puts your stagnation point entirely above the pylon and your dirty air would all go under the wing.
The 777, which was done with considerably more advanced CFD codes than the DC-10 or 757 has the same thing, so I would guess that it's not worth smoothing it out:
The 737, interestingly, does not, but I suspect that's due to the very tight ground clearance requirement:
Photo © Matthew Wallman
Tom
ex52tech
Sun Mar 30, 2008 9:07 pm
Quoting JetMech (Reply 3):
Because the nose cowls are interchangeable on the DC10, if you mount the strake in the wrong place, especially on the inboard side of the nose cowl it will cause a vibration, and oscillation that gets worse with speed. So they do effect more than low speed high angle of attack on a DC10 anyway.
"Saddest thing I ever witnessed....an airplane being scrapped"
jetmech
Mon Mar 31, 2008 1:02 am
Quoting Ex52tech (Reply 5):
I see. I actually remember one of the boys having to remove a strake from the cowling of a 767. Perhaps it was for the same reason? Do you know if it is possible for the DC-10 to operate without one or both of the strakes?
Regards, JetMech
khenleydia
Mon Mar 31, 2008 6:38 am
Thank you all for your answers! They were very helpful!
JetMech, thanks for the pictures and the videos. I have seen that first hand, but still always good to have it explained, at least so I can say I have some idea, even if I can't say that I 'know' all about it.
Again, thanks!!
KhenleyDIA
ex52tech
Mon Mar 31, 2008 4:20 pm
Quoting JetMech (Reply 6):
I would think that they could continue on if they lost one, I don't have access to the MEL anymore to check. I do know that they cause a lot of raised eyebrows if placed wrong.
Users browsing this forum: 67ponajrad, gloom, Joordyy023 and 3 guests
