Aircraft Fuel Burn Rate?
Fri Apr 04, 2008 3:47 pm
What is the fuel burn rate per hour (or even minute) for A320, 738, and A332 aircraft during taxi-out and also when during a holding pattern before landing? And how would that rate compare to that when in normal cruise? Anyone any idea?
Any approximate figures would be great! Thanks!
flyf15
RE: Aircraft Fuel Burn Rate?
Fri Apr 04, 2008 6:36 pm
I can't tell you for those types, but I can give you approximate numbers for the CRJ-200... it'll at least give you an idea of the ratios.
Approximate total burn pounds / hour
Taxi: 700 (Both engines and APU)
Takeoff: 6000-7000 (depending on temperature, elevation, reduced/full thrust, etc)
Climb: 6000-3500 (reducing as as altitude increases)
Cruise: 2500-3000 (depending on altitude/weight/etc... subtract 500 for long range, add 500 for high speed)
Holding: 1800-2400 (depending on altitude/speed)
Normal descent: 1500
Idle descent: 600
Approach: 2000 (fully configured)
MarkC
Fri Apr 04, 2008 8:37 pm
From memory, a 100" 4000 on an A330 burns 2,200 pounds at idle, and I want to say 15,000 at takeoff, but that could be off. I can find out Monday.
Rick767
Fri Apr 04, 2008 10:23 pm
Assuming sea level, ISA conditions:
A320 with CFM engines - about 270kg/hr (600lb/hr) per engine at idle (taxy)
A320 with V2500 engines - about 330kg/hr (730lb/hr) per engine at idle
A330 with RR Trent 772 engines - about 820kg/hr (1,800lb/hr) per engine at idle
Cruise fuel burn depends on so much, environmental conditions, cruise speed, altitude, weight, etc... but ballpark with a decent passenger load (total burn rates):
A320 - c.2,700kg/hr early in the flight (heavy) reducing to 2,300kg/hr before descent (lighter)
A330-200 with RR Trent 772's - c.6,100kg/hr early in the flight (heavy) reducing to c.5,400kg/hr before descent (lighter)
Holding pattern at typical landing weights (again decent passenger load assumed) will be roughly:
A320 - 2,200kg/hr (total)
A330-200 - 4,600kg/hr (total)
Hope that helps.
wilco737
Sat Apr 05, 2008 12:50 am
On the 738 we used an everage fuel flow of 2400kg/hr during cruise. Sometimes it was more, with heavy aircraft, lower altitudes, sometimes it was higher, with lower weight and higher altitude...
WILCO737 (MD11F)
 airplane
rsbj
Sat Apr 05, 2008 3:10 pm
A guide I use is weight/lb per hour at optimum altitude and LRC. The A320 (with CFM's) is 26.8bs per lb of fuel per hour, the 737-800 with winglets is 28.3. I don't know about the A330, though I can ask pops who flies them for US. It should be close to the 767-400, which is 34.3. I believe the best ratio is the 777NG at around 37.5, though I haven't had an opportunity to see the numbers for myself.
My method has a lot of flaws, but I find it useful nonetheless.
I fly really fast and take a lot of chances.
JonathanDavis
Mon Apr 07, 2008 8:51 pm
I kinda remember HA's 717 jet, I used to work as a load planner for HA in OGG, and I told remember every single fuel burn, but it was something like this
taxi: 500
one-way OGG-HNL, 30minute flight was: 2200 total
and taxi again: 500
the 2200 was the total flight from takeoff,climb,cruise,descent,final
i say not bad, of couse if you had the perfect Center of Gravity for balancing that 717 can save some fuel
Users browsing this forum: ANDY3, strfyr51 and 1 guest
