Cubsrule
190 Cargo Door Operation
Mon Apr 07, 2008 8:07 pm
I watched a US ramper have a really hard time getting the cargo door shut on a 190 last night... Eventually, he pulled the beltloader he was standing on away, reached into the cargo compartment, and retrieved some sort of pole with a hook which he used to grab onto the door and shut it. Is that pole standard equipment, or is it a US thing? And are the doors that hard to close, or was he just having trouble because he was (giving him the benefit of the doubt) new to working on the aircraft?
longhauler
RE: 190 Cargo Door Operation
Mon Apr 07, 2008 11:33 pm
Yes, the pole is just beside the cargo door inside the cargo hold. One for each door.
If he was having trouble closing the door, it is because he did not unlock/unlatch the door from the open position. It sounds like he figured it out .... as you use the "pole" to do just that!  Smile
B6JFKH81
Tue Apr 08, 2008 11:07 pm
We call that the shepherd hook. It goes into an eye hole to twist and unlock the door, then pull it shut.
EMBQA
Wed Apr 09, 2008 12:43 am
Quoting B6JFKH81 (Reply 2):
J...!!! We call that a 'Pimp Cain' Mack Daddy..!! Now do your Fat Man-Happy Dance
[Edited 2008-04-08 17:51:58]
B6JFKH81
Wed Apr 09, 2008 7:01 pm
Quoting EMBQA (Reply 3):
HAHAHA!! I forgot about calling it the Pimp Cain!  rotfl   rotfl   rotfl
...and just for you I did the fat boy happy dance.  bouncy
Goldenshield
Wed Apr 09, 2008 10:51 pm
Any pictures of said implement? It seems to me that if Embraer did a good enough job of shrinking the design of the A320, they could've at least done a similar setup with the cargo doors (although, having to lay on one's back to open/close the door, a la the 320, would be awkward.)
EMBQA
Wed Apr 09, 2008 11:59 pm
Quoting Goldenshield (Reply 5):
It looks just like a walking cane....and about the same size too. When the door fully open a latch on the upper hinge helps hold the door open. To close the door you insert the cane hook into the latch and twist to unlock. Pull down until you can grab the handle, stow the cane.. close and lock the door.
Why over design it...? Its a simple system that works..........If you want to do some digging.. when jetBlue first got their E190, A.net member 'Candais'....( I think that right) posted some pictures of the Ramp Crew getting train on its use.
[Edited 2008-04-09 17:01:34]
B6JFKH81
Thu Apr 10, 2008 10:34 pm
Quoting EMBQA (Reply 6):
The A320 door is definitely more complex as (IIRC) they are hydraulically driven which would require actuators and stuff which not only increases the complexity of the door system but adds weight and MX costs.
mrocktor
Wed Apr 30, 2008 8:03 pm
Since we had to multiply all the A320 dimensions by 0.6, we ran out of engineering capability and had to use a simpler door. Sorry.
/sarcasm
More respect for other people's work is in order.
Goldenshield
Wed Apr 30, 2008 10:40 pm
Quoting Mrocktor (Reply 8):
Easy there. I never said it was a BAD design.
EMBQA
Thu May 01, 2008 12:01 am
Quoting Goldenshield (Reply 9):
Don't worry too much...it's a Latecoere design......not EMB
B6JFKH81
Thu May 01, 2008 5:16 pm
Not too much in common with the A320. The fuselage on the E190 is a double bubble design which is completely different than the A320.  wink
Goldenshield
Thu May 01, 2008 6:12 pm
Quoting B6JFKH81 (Reply 11):
I know they are both clean-sheet designs. I was just playing on the running joke that everyone calls it a "Baby Bus."
Thu May 01, 2008 6:41 pm
Quoting LongHauler (Reply 1):
Is this similiar to the B737 cargo door open position latch.
regds
MEL
B6JFKH81
Thu May 01, 2008 10:27 pm
Quoting Goldenshield (Reply 12):
Ah, gotcha. I never heard it called that.
Users browsing this forum: FlyingJhawk, WholaLottaLove and 4 guests
