UltimateDelta
Low Door On L-1011?
Sat Apr 19, 2008 5:10 pm
Hi, everyone. Recently I checked out a book on the L-1011 from my library. In all the pictures of the starboard side, there appears to be a door just ahead of the wing root. What's up with that, and what is it for? Thanks for any info.
Midwest Airlines- 1984-2010
57AZ
RE: Low Door On L-1011?
Sat Apr 19, 2008 5:50 pm
Tristars had a lower level galley. The lower level door swung up and in and was routinely used for galley service.
"When a man runs on railroads over half of his lifetime he is fit for nothing else-and at times he don't know that."
474218
Sat Apr 19, 2008 6:05 pm
The small door on the starboard (right) side of the L-1011, just forward of the wing root, is called the S-2 door, it provides access to the "mid electrical service center" (MESC) and opens inward. The S-2 door is in the fuselage under the fuselage to wing fairing, there is a hinged panel in the fairing that allows access to the door.
N587NK
Sun Apr 20, 2008 8:57 am
On the -100 series the galley was a lower deck galley where all catering supplies are located. Its the galley service door. the -500 series had FWD and AFT galleys on the main deck.
pilotboi
Sun Apr 20, 2008 5:27 pm
Quoting N587NK (Reply 3):
I see the AFT one, but no the FWD one:
Photo © Sunbird Photos by Don Boyd
474218
Sun Apr 20, 2008 9:39 pm
The galley door is further forward and higher on the side of the fuselage than the S-2 Door. The S-2 door is in the same location on both the -1 series and -500's. The main reason for the S-2 door is for access to the mid electrical service center and to allow for removal and replacement of the battery.
Big version: Width: 1029 Height: 1358 File size: 286kb
This picture shows the location of the S-2 (pressure) door and the fairing door.
474218
Sun Apr 20, 2008 11:50 pm
Quoting 474218 (Reply 5):
411A
Mon Apr 21, 2008 1:29 am
Quoting Pilotboi (Reply 4):
You won't find a galley service door on -500 series airplanes, as there arent' any...maindeck galleys are serviced from the maindeck, via the pax entry doors.
In addition, some long body TriStars don't have any galley service doors either, as some came equipped with no lower galleys.
BA -200's come to mind.
Customer option.
474218
Mon Apr 21, 2008 3:26 am
Quoting 411A (Reply 7):
Correct!
Not correct!
All long body L-1011's were delivered with below floor galleys, there were no options. BA had Lockheed develop a series of service bulletins (called the Sunset Three Mod) that removed the below floor galley and extended the forward cargo compartment into the area vacated by the below floor galley. New galleys were located in the main cabin. When this modification was accomplished the galley door was deactivated and skinned over. Below are two photos of the same aircraft, pre and post mod. These modifications were accomplished several years after delivery.
Photo © Marlo Plate - Iberian Spotters
Before modification, galley door is clearly visible.
Photo © Mark Durbin
After modificaton door skinned over.
411A
Mon Apr 21, 2008 3:35 am
Quoting 474218 (Reply 8):
Not correct!
Opps, I stand corrected!
Now, regarding pax entry doors, some L1011 standard body airplanes were delivered with large rear entry doors, which were fully electrically operated, and allowed a max seating capacity of...400.
I wonder if 474218 will agree with this?
474218
Mon Apr 21, 2008 3:49 am
Quoting 411A (Reply 9):
I agree. But 400 seats required 10 abreast seating with 30" seat pitch, not really my idea of comfort.
Tristarsteve
Mon Apr 21, 2008 7:32 am
Yes all the BA L1011 had this option. Look at the picture in post 8. They were used when the aircraft was flown in a charter config from LGW by BAs Charter airline (called BA Airtours or Caledonian amongst other names). I think they had 398 seats.
474218
Mon Apr 21, 2008 3:06 pm
Quoting TristarSteve (Reply 11):
Court Lines (model 193K), British Airways (193N) and British Air Tours (293C) all had eight (8) type A doors. Total of 19 aircraft.
To sell aircraft in the 70's it was common for the manufactures to build aircraft in many different configurations. Another example of this is the Pan Am (193Y) and LTU (193J) -500's which do not have a C-3 cargo door.
point8six
Mon Apr 21, 2008 9:13 pm
BA 's charter subsidiary -British Airtours- had 393 seats: 16 hours from LGW to LAX via BGR. Cheap, but not my idea of fun!
ReidYYZ
Tue Apr 22, 2008 12:50 am
474218, as always a wealth of Tristar information. But,
Quoting 474218 (Reply 12):
what occupied the C3 cargo area? Extra LD3?
474218
Tue Apr 22, 2008 1:32 am
Quoting ReidYYZ (Reply 14):
The C-3 is for bulk cargo only. The Pan Am and LTU -500's had a removal panel in the C-2 aft bulkhead and they manually loaded the C-3 through the C-2 door. Since the panel was on the right hand side they they had access to the C-3 untill the last LD-3 was loaded in the C-2 compartment.
Thank you for the kind words, I spent over half my line working with the TriStar in many different capacities.
ReidYYZ
Tue Apr 22, 2008 1:55 am
WG had the ex-PSA machines, and to save money (on the cost of LD3 containers) the owner had the cargo loading equipment removed from the C2. The bags were hand-bombed in.
And up to the end in '90, the lower lounge still had the retro-bogie-dance-party wall paper. That was fun to see.
To have the C3 door was a great thing especially when the C2 door elex were out of service and you didn't want to fight the panels to hand crank from outside.
Reid
Quoting 474218 (Reply 15):
I spent over half my life working with the TriStar
your basement/garage/home office must be filled with all kinds of neat things.
Users browsing this forum: 7673mech, Apprentice, ARNPEK, CARST and 18 guests
