liffy1a
Hand Flying (Auto-Pilot In-operable) Question
Mon Apr 21, 2008 4:15 pm
I have an uncle that is a retired pilot. One of his aircraft types was the DC-8. He told me that on many occasions he would have to hand-fly the aircraft as the auto-pilot was in-operable, between himself and the first officer taking 15 minute turns as being the Pilot Flying. He flew cargo DC-8's so passenger comfort was not exactly a priority. My question is basically to pilots, does your airline allow aircraft to go up if theres no auto-pilot?
wilco737
RE: Hand Flying (Auto-Pilot In-operable) Question
Mon Apr 21, 2008 4:20 pm
Quoting LIFFY1A (Thread starter):
Yes, it is allowed! BUT: it reduces the maximum allowable duty time a lot! Because it is more exhausting than using autopilot! You are not allowed to fly within RVSM airspace anymore! Means: below FL280 or above FL410! So it will cost a lot of extra fuel... You are not able to fly autmated approaches and landings (of course, how without autopilot) means: no CAT II/III anymore... But according to the MEL it is allowed...
WILCO737 (MD11F)
 airplane
Soku39
Mon Apr 21, 2008 4:22 pm
Yes you can fly without an autopilot, as long as the autopilot is a MELable (minimum equipment list, this lets you fly with non essential, and non type certificated items inoperable) item at your airline, and for that aircraft.
However as RVSM (reduced vertical seperation minimums) in Class A airspace are starting to be introduced. You would not be able to use those airways as use of the autopilot is required.
So the answer is, yes, if the autopilot is a MELable item, and you are not in RVSM airspace, an airliner can have an inoperable autopilot, and still be dispatched for flight.
The Ohio Player
aogdesk
Mon Apr 21, 2008 4:40 pm
Make sure to note the look on the flight crews faces when you mention that the A/P is MEL'd. You'll get anything from a slight grunt to a full fledged whine..........understandable when its a long flight, quite annoying when its a 30-45 min hop.  Wink
Flighty
Mon Apr 21, 2008 4:53 pm
I don't even like long car trips without cruise control. An airplane takes considerably more work...
tb727
Mon Apr 21, 2008 5:03 pm
Depending on the individual airplane I fly, sometimes it's easier to hand fly since the autopilots are about 40 years old and a little finicky. Some of them rock though and will fly an ILS down to the bottom not that we let it, it's hard to watch it and not do it for me. It sucks but I've done 6 leg/4000 mile days with no autopilot, it's no big deal. You just can't look out and sight see as much.
Our MEL if I recall, has the autopilot as a 120 day item. These particular aircraft aren't RVSM'd but I am pretty sure if they were the A/P has to be working to go above FL280 in the US.
[Edited 2008-04-21 10:07:30]
wilco737
Quoting Aogdesk (Reply 3):
 crazy  my face if I hear the A/P is inop! But actually I only had it once!!! 1815 flights and only one time was the A/P inop!
Was on the B737, never on the MD11 though...
WILCO737 (MD11F)
 airplane
pilotpip
Mon Apr 21, 2008 5:42 pm
Hand flying all day, at altitude sucks. It can be done, but it's not very efficient for the reasons listed above. With fuel getting so expensive it's not very practical to fly a jet in non-RVSM airspace all day in the US. Happens a lot on the 145 and sounds like it happened a lot when the 170 was new.
That said, I like hand flying when the workload is low. We've had that discussion already though.
DMI
liffy1a
Mon Apr 21, 2008 6:59 pm
Thanks for the replies. Would it be a more uncomfortable ride for the passengers if the auto-pilots in-op?
wilco737
Mon Apr 21, 2008 7:06 pm
Quoting LIFFY1A (Reply 8):
Well, depends how smooth you can control! But usually it's a little bumpier and less comfortable...  Wink
WILCO737 (MD11F)
 airplane
aviopic
Mon Apr 21, 2008 7:35 pm
There is no simple Yes or No to this question.
First of all there is the MMEL(Manufacturers Minimum Equipment List), on top of that there might be Airline restrictions.
Then It depends on A/C type, configuration and what part of the system is failing.
The auto pilot is not a single box but consists out of many parts working together like Flight Control and Augmentation computers, Servo's, Actuators etc.....
The truth lives in one’s mind, it doesn’t really exist
EMBQA
Mon Apr 21, 2008 8:43 pm
Auto Pilot is an MEL items. Pilots hate it because it actually makes them work......
wilco737
Mon Apr 21, 2008 8:46 pm
Quoting EMBQA (Reply 11):
You say I don't work? how did you know that  bigthumbsup
But I doubt any airline will send the aircraft airborne on a 12 hour long haul flight without autopilot! On short haul no big deal Happened to me as well, one day (4 flights) without A/P! it was actually fun... But sure it is more work than with the autopilot... Big grin
WILCO737 (MD11F)
 airplane
EMBQA
Mon Apr 21, 2008 9:02 pm
Quoting WILCO737 (Reply 12):
I didn't say it would be fun.... Hand flying an MD-11 over the pond would suuuuuuuuuuuck. I had the chance to hand fly once on a ferry flight. The one thing I learned fast was not to do is chase the HSI.
[Edited 2008-04-21 14:07:30]
point8six
Mon Apr 21, 2008 9:09 pm
Flew a B747-200 (pax version) manually most of the way from overhead Little Rock to London, after all 3 a/p's failed in the cruise. We took 20 mins each through the night and finished the flight with a practice Cat 3b autoland - the a/p re-engaged during descent! Not something I would like to do too often- very tiring but not too much deviation from crz alt. Strangely enough, no complaints from the stewardesses.  Wow!
wilco737
Mon Apr 21, 2008 9:48 pm
Quoting EMBQA (Reply 13):
YOU BET!!!! The good old bitch  cloudnine
On short haul it was ok! Sometimes I did a whole flight without A/P just for the fun of it! (if it wasn't in RVSM) and only on really short flights! Was fun Big grin
WILCO737 (MD11F)
 airplane
tb727
Tue Apr 22, 2008 2:00 am
Not if I am flying
Quoting Point8six (Reply 14):
My neighbor flew for Tower Air back in the day and said they regularly had to fly JFK-Tel Aviv with all 3 A/P's inop and have to hand fly the whole flight.
I forgot about my crappiest flight just about ever with no autopilot. YIP-CYYT-LPAZ-LEPP-LPAZ-CYYT-BGR-JAX-YIP in a Learjet 36. That was a long 2 days down low under RVSM with a lot of water under us.
[Edited 2008-04-21 19:03:42]
speedbird2263
Sun Apr 27, 2008 12:52 am
Quoting Tb727 (Reply 16):
in a Learjet 36
To think I thought my 16hr weekend trip awhile back KTMB-KTLH-KPDK-KTLH-KMLB-KTMB in a 1972 C172 without auto-pilot and half the trip time in IMC was something of a major accomplishment  silly .
Straight'n Up 'N Fly Right Son
stratosphere
Tue Apr 29, 2008 3:21 am
Quoting Tb727 (Reply 5):
WOW 120 days? The 2 US airlines I have worked for it is a 10 day item MAX.. In the case of nwa you would be hard pressed to get a pilot to take a DC-9 autopilot on MEL unless it was the roll mode only that was inop or some other fragment of the autopilot system like heading select. If it was the pitch channel FORGET IT. In fact this item is one of a few items that are in the pilots union contract like the APU or Autopressurization that can be refused..It used to piss me off when the capt would refuse an autopilot on a real short leg like MEM-BNA and leave a plane load of pax at the gate. I guess hand flying and having to manually trim would be work but I guess I understood it better when a pilot told me his main reason he would not take an aircraft with an inop A/P was the fear of "busting altitude". However, mechanics do not have the option of refusing a task like the pilots do. You think I like going up in a cherry picker to work on the tail in a driving rain? The only thing we can take issue with is if it was unsafe in some way..i.e high winds etc..
tb727
Tue Apr 29, 2008 3:39 am
Quoting Stratosphere (Reply 18):
When my dad was a mechanic at NW he had a DC-9 Captain refuse a DTW-FNT flight because the A/P was MEL'd. I think he ended up throwing a part at it and cleared it and let him figure out if it worked in the air. It's a 50 mile flight! I think the Captain was just trying to get home a little early not doing the DTW-FNT-DTW trip at the end of his day.
PhilSquares
Tue Apr 29, 2008 4:25 am
Ours is C, 10 days too, but you can't enter RVSM airspace with it MEL'd. So, it gets fixed ASAP.
Fly fast, live slow
thegreatchecko
Tue Apr 29, 2008 4:48 am
Yes, and the first thing I do is declare a preemptive emergency on the ground before departure, then I cry, and then change my pants because of the shock to the system that an inop autopilot causes.
Okay, so I'm a turboprop pilot, it's a pretty darn big one at that, but I have no problem flying with an INOP autopilot. The previous job had me doing 2.5 to 3 hour legs hand flown because we had no autopilot. Was it tiring, yeah, and it added some difficulty, but it was doable.
Call me crazy, but I enjoy hand flying my aircraft. Am I going to hand fly an ILS in low IFR on raw data just for fun? No, but I'm pretty confident I could do it if I had to. Of course, every aircraft is different and some lend themselves to hand flying more than others. However, as professional pilots we should be able to hand fly our planes without really getting all bent out of shape.
Last I checked most of us got into this to fly, not to program an FMS and monitor a computer. If I wanted to do that I could go work at the nearest nuclear plant and I'd probably get paid better.
Checko
[Edited 2008-04-28 21:50:59]
"A pilot's plane she is. She will love you if you deserve it, and try to kill you if you don't...She is the Mighty Q400"
tb727
Tue Apr 29, 2008 8:09 pm
Quoting TheGreatChecko (Reply 21):
I just had a guy they wanted me to train on the Falcon and he was one of those guys that had 2 type ratings but couldn't fly his way out of a bag. NO basic instrument skills. I had to start over on everything with him. I caught him cheating every time we were doing an approach in good weather. The one day I finally just flat out asked him if all he has ever done is fly an A/P and FMS, the answer was of course yes. That guy didn't make it and went on to jump ship at a couple more operators in a couple of months, he also seemed to be one of those the grass is greener on the other side kind of guys.
We do raw data stuff to the bottom all the time, why, because that's all we have, lol! I wouldn't trust a Lear FD further than I could throw it, they like to make up a phantom approach into a smoking hole 2 miles short of the runway and the only good Falcon FD's we have are on the ex-FedEx airplanes, all 2 of them on line right now, even then I am constantly weary of what it is gonna do next. They all work ok, maybe I am still not used to using them even after 4000 hours. Some day it will be nice to watch the plane do it, but I am glad to be getting a strong foundation for when that doesn't work that one day I really need it.
saab2000
Tue Apr 29, 2008 9:00 pm
In my 4 years at my current company I have had the A/P deferred on two occasions. Both times we were lucky to have good weather with little turbulence. I am a huge autopilot junkie and normally have it on by 2000 feet AGL or so and thought it would be tough, but it's really not. At least not with the flight director, which is part of the autoflight system and gives commands electronically to the pilot, be it the person or the autopilot.
In both cases the other pilot and myself briefed the flight and how we would handle things a bit differently than normal, but really it was not a big deal. The first time was about 3 years ago on a longish (2 hours or so) flight and the most recent time was from CLT-HSV, not a very long flight, about 1 hour.
However.....
I did say that I probably would not have accepted the airplane if the weather had been poor. But saying that and doing it are two different things.
BTW, the autopilot is smoother than I am....  Big grin
smrtrthnu
liffy1a
Wed Apr 30, 2008 12:59 pm
Another question, when pilots are doing their type rating, how much training do they do with the auto-pilot in-op?
saab2000
Wed Apr 30, 2008 1:55 pm
Quoting LIFFY1A (Reply 24):
I cannot speak for other carriers, but at my own there is a fairly small amount of hand flying done, and for the most part training consists heavily of understanding and using the automation. That is ultimately the bread and butter of daily life at an airline.
Obviously, we have to do a number of each type of approach by hand, including single-engine approaches and go-arounds, but there is also plenty of A/P usage as well. Knowing your automation and the potential hazards of it is very, very important.
Also, in the US we are required to demonstrate stalls and steep turns and these too are hand-flown. We do two 180 degree turns at 45 degrees of bank as well as stalls and recoveries in various configurations.
I would say about 25% of the type-rating training was hand flown, only because some approaches need to be done so and the CRJ has no autoland capability.
smrtrthnu
tb727
Depends on the plane. I never even looked at it on my type ride. Any monkey can fly a plane with an autopilot. It was briefed however by my DE on my lower than standard ILS that I could use anything available to me, FD or A/P, I opted for the raw data, why change after years of doing it the same way, especially on "The Ride".
longhauler
Wed Apr 30, 2008 1:56 pm
A lot more often than on the line. Makes sense, why watch the simulator "flying itself".
At AC, it is always the Captain's final decision whether to take an aircraft with the A/P or A/T inop.
Two examples:
YOW-YYZ, clear day, 43 minute flight and the F/O was willing, no problem, we took the aircraft back to where Maintenance said it would be fixed.
YYZ-LGA, bad weather day. LGA airport was closed, we had a YYZ alternate and 2 hours of holding fuel ... the A/P was inop, we refused the aircraft.
Depends on the day.
liffy1a
Wed Apr 30, 2008 2:12 pm
Quoting Saab2000 (Reply 26):
Whats an acceptable loss or gain of altitude during this turn?
saab2000
Wed Apr 30, 2008 2:26 pm
Quoting LIFFY1A (Reply 28):
+/- 100 feet is acceptable, but it is not really good form. +/- 50 feet or less would be greatly preferred. The issue is that when you enter the turn you need to pitch up about 2 degrees and also increase power slightly. More drag in the steep turn. So it is not only altitude that needs to be kept steady, but speed too.
It sounds like an easy manoeuver, but ultimately it is a bit tricky. The key is to set the pitch and power early and then not to move the hands even one millimeter!!! Too much correction and suddenly you can be climbing or descending a lot.
smrtrthnu
PGNCS
Mon Sep 28, 2009 2:50 am
Quoting Tb727 (Reply 19):
I can't address the MEL philosophy of NWA DC-9 Captains, but I have flown the DC-9 and other aircraft many times without the autopilot. Like others mentioned, there are RVSM issues without it as well as approach minimum changes that may be dictated by lack of autopilot(s).
As far as the NW DC-9 Captain not wanting to do a FNT turn, I wouldn't critique his decision unless I knew the entire story: was it day or night? What was the WX at DTW and FNT? What was the WX enroute? Were there thunderstorms around? Was the FO inexperienced? Were they on their 5th or 6th leg of the day? Was it an OE? Were there other MEL's, etc., etc.?
Saying it's a 50 mile flight doesn't mean it's an easy flight.
Mir
Mon Sep 28, 2009 4:19 am
Quoting PGNCS (Reply 30):
 checkmark  A 50 mile flight is likely to be more difficult than a 200 mile flight - a lot of things need to be done in a very short amount of time.
-Mir
tb727
Mon Sep 28, 2009 1:54 pm
Quoting Mir (Reply 31):
I'm not doubting that. Windsor to Detroit in a 727 is all a-holes and elbows when you don't have a short leg checklist apparently.
This thread is pretty old but it kind of corresponds to what I am doing now in training. Back in 135 I would hand fly everything in the sim. If we even thought about using the A/P or FD, it would be failed. Now in 121, I get in and keep hand flying and the instructor tells me welcome to 121, over here we use the autopilot unless I don't want you on it, then I'll fail it. Until then, use it. Nothing necessarily wrong with either, just an interesting observation.
CosmicCruiser
Mon Sep 28, 2009 3:29 pm
To add to what WILCO737 said there's another thing to keep in mind. It's not the fact that hand flying "makes you work" but that it has one pilot TOTALLY absorbed in flying leaving the other pilot to do EVERYTHING. Not something that is very smart if you're flying into a busy int'l terminal or a small GA airport. Too, your chances off an alt. violation increases greatly. As WILCO said the MD-11 is VERY sensitive up high. We are told that a pilot can hand fly anytime it is feasible. Obviously a high density airport with a noise sensitive SID is not one.
calpilot
Mon Sep 28, 2009 3:30 pm
Auto pilot (s)
What many here have failed to mention is that most modern aircraft have more than one A/P. Large Boeing airplane come with 3 of them, the B737 2 of them. It is very rare indeed to see all the systems on deferral.
wilco737
Mon Sep 28, 2009 3:55 pm
Quoting CALPilot (Reply 34):
That is true. But it happens. I remember a day where we had to fly 3 flights all manually because something was wrong with the autopilots...
Quoting CosmicCruiser (Reply 33):
Just remember, if you are flying manually, then you are no longer RVSM approved  Smile
At airport like ORD, JFK and it is busy, I leave the autopilot on very long or engage it pretty early. Then we can both look out for other traffic, listen very carefully to ATC. So many airplanes and then you need to be highly alerted.
wilco737
thegreatchecko
Wed Sep 30, 2009 5:50 am
While this is true, they often need all their air data sources to be working correctly and every one of the servos to work as well. So, if one air data computer isn't working, the flight director took a dump, or one of the autopilot servos isn't working, it is quite possible that while the autopilots could still work in the event of an airborne failure, the whole system could be deferred once the plane gets on the ground.
Checko
CanadianNorth
Tue Oct 20, 2009 6:33 pm
Airline I work for:
B737s regularly use RVSM airspace so the autopilots are almost always working.
HS748s haven't had an autopilot system installed for years, so the pilots are on their own to steer and play with the trim wheels there. However most hawker flights are an hour or less.
CanadianNorth
Way to go, nice and slow, never late, 748!
Users browsing this forum: Flow2706, Horstroad, StereoTechque and 2 guests
