rj777
A380 Callsign- Heavy Or Super?
Wed Apr 30, 2008 3:35 pm
I remember hearing a while back that the A380's callsign was going to be considered SUPER. Did this happen or is it still just HEAVY?
baw217
RE: A380 Callsign- Heavy Or Super?
Wed Apr 30, 2008 3:41 pm
It is a classed as "Super", but I have not heard super being used by any London ATC, whilst the A380 has been serving London.
EXAAUADL
Wed Apr 30, 2008 3:48 pm
So obviously this mean even greater spacing behind a A380?
tjwgrr
Wed Apr 30, 2008 3:50 pm
When I was listening to ATC (Chicago & Cleveland centers) the Airbus A388 demonstrator was designated as Lufthansa #### "super"
Direct KNOBS, maintain 2700' until established on the localizer, cleared ILS runway 26 left approach.
71Zulu
Wed Apr 30, 2008 4:16 pm
First arrival at JFK, 19 Mar 2007
http://mp3space.com/stream.php?id=49083
Clickable links only please!
smokeyrosco
Wed Apr 30, 2008 4:24 pm
Which call sign does SQ use?
John Hancock
JohnJ
Wed Apr 30, 2008 5:04 pm
Used the "super" designation on the visit to Hartford as well.
Lexy
Wed Apr 30, 2008 5:09 pm
Visit to CVG was "Airbus 202 Super"
Nashville, Tennessee KBNA
FlyHoss
Wed Apr 30, 2008 5:11 pm
Quoting Smokeyrosco (Reply 5):
SQ uses "Singapore" as their call sign. Here's a link to a list of call signs starting with "s":
http://atcmonitor.com/callsigns.html#s
Note that the call signs are on the left with the company name on the right.
A little bit louder now, a lil bit louder now...
baw217
Wed Apr 30, 2008 5:16 pm
"Singapore xxx"
Its rare to hear the "Heavy" or "Super" tag, outside of North America, here in the UK, you may hear it a few times a day, but thats about it!
cloudyapple
Wed Apr 30, 2008 5:17 pm
Quoting BAW217 (Reply 1):
The wake suffix is a peculiarity for the US. Most of the rest of the world, including NATS, do not suffix their callsigns. It does next to nothing and clogs up the R/T.
A310/A319/20/21/A332/3/A343/6/A388/B732/5/7/8/B742/S/4/B752/B763/B772/3/W/E145/J41/MD11/83/90
N766UA
Wed Apr 30, 2008 5:29 pm
It's "super." Or, more correctly, "supaahhh."
AustrianZRH
Wed Apr 30, 2008 5:44 pm
Quoting 71Zulu (Reply 4):
Love that line: "LH8940 Super, just be advised that they'd LIKE you to taxi down 31L!"  rotfl   rotfl
WARNING! The post above should be taken with a grain of salt! Furthermore, it may be slightly biased towards A.
futurecaptain
Wed Apr 30, 2008 6:19 pm
That is odd that ATC would call it "super" since that term is not a standard aviation term. Heavy, large, and small are the only classifications of aircraft. No super.
Maverick623
Wed Apr 30, 2008 6:38 pm
Quoting Futurecaptain (Reply 13):
ATC classifications are based on the maximum gross takeoff weight of an aircraft, which is supposed to determine the strength of the wake turbulence it generates, which determines minimum separation criteria.
Until the A380, the largest minimum separation required was 4-8 minutes behind a heavy depending on aircraft type. The FAA decided that the A380 needed greater separation mins (6-10 minutes), and hence created a new category of airplane called "Super".
"PHX is Phoenix, PDX is the other city" -777Way
cloudyapple
Wed Apr 30, 2008 6:39 pm
And you call yourself a future captain. Check you facts before you make firm statements next time.
The proper (ICAO) wake categories are Super, Heavy, Medium and Light. Some countries have different categorization like Super, Heavy, Upper Medium, Lower Medium, Small and Light for the UK. Your categorization only applies in the US. And the world is a little bit bigger than that.
[Edited 2008-04-30 11:51:05]
futurecaptain
Wed Apr 30, 2008 7:32 pm
Quoting Cloudyapple (Reply 14):
I thought the above replies established that adding "heavy" or "super" to a callsign was more of a US issue than around the world. You yourself even wrote "Most of the rest of the world, including NATS, do not suffix their callsigns." So I wrote my response to the "super" suffix as taking this issue to be for the most part an American thing. In which the FAA AFAIK has not added a "super" category of aircraft.
Quoting Maverick623 (Reply 15):
Can you find a source detailing the FAA changing the categories and adding "super?" The word is used on A.net quite alot but I don't think officially the FAA has decided what to do when the plane starts flying here regularly.
I did find this...
http://www.faa.gov/airports_airtraff...ons/at_notices/media/N7110.478.pdf
Interm procedures for the route proving flights and promotional flights. ATC was to use "super" in the callsign but this notice is coming to an end and we will have to see what happens. Maybe we will still be required to call it "super" in the US. Maybe it will just be "heavy." I don't think we know yet.
flexo
Wed Apr 30, 2008 8:27 pm
What about the AN-225, is that treated as "Super" or as a regular heavy?
Thu May 01, 2008 1:55 am
I though "Heavy" was only used in North America anyway.
Blackbird
Thu May 01, 2008 4:15 am
What weight do you have to mass in at MTOGW to have a Super rating?
lowrider
Thu May 01, 2008 7:53 am
Quoting N766UA (Reply 11):
LOL, that was the first thing that came to my mind.
Quoting Cloudyapple (Reply 10):
You might want to reconsider that. The following is from a Nov 2007 revision to the ICAO PANS-ATM.
4.1 Regarding radiotelephony procedures for air-ground voice communication channel changeover,
when so prescribed by the appropriate ATS authority, the initial call to an ATC unit after a change of
air-ground voice communication channel shall contain the following elements:
» Designation of station being called;
» Call sign, and for aircraft in the heavy wake turbulence category, the word "Heavy";
» Level, including passing and cleared levels if not maintaining the cleared level;
» Speed, if assigned by ATC; and
» Additional elements, as required by the appropriate ATS authority
4.2 For aircraft being provided with aerodrome control service, the initial call to the aerodrome control
tower shall contain:
» Position; and
Proud OOTSK member
twinotter
Thu May 01, 2008 7:05 pm
Quoting Futurecaptain (Reply 16):
The FAA issued a temporary procedure prior to the A380 promotional flights. It read in part:
The A380 is in the “Heavy” aircraft weight category. However, wake vortices generated by the A380 are more substantial than those of other aircraft in the Heavy wake turbulence category, thus requiring special designation (“Super”) and additional wake turbulence separation during certain segments of flight. The A380 may therefore identify itself as [call sign] “Super” in radio communications with air traffic control.
The notice identifier was N JO 7110.464 if you want to google it.
futurecaptain
Thu May 01, 2008 7:20 pm
Quoting TwinOtter (Reply 21):
Yes, and I see it was a temporary procedure. That notice ended 1 year ago. AFAIK the FAA never created a new "super" category of aircraft so while the A380 may dictate extra spacing for other aircraft its callsign should simply be "heavy."
747luvr
Thu May 01, 2008 7:28 pm
If I was an ATC controller I'd say..... "Singapore XXX Fatty, you are cleared for takeoff, after you loose some weight."  box
Blackbird
Thu May 01, 2008 7:37 pm
I thought the airliner that generated the worst wake turbulence was the MD-11?
pilotntrng
Mon May 26, 2008 2:14 am
Quoting Blackbird (Reply 24):
757 takes the title for worst wake
Booooo Lois, Yaaaa Beer!!!
BWilliams
Mon May 26, 2008 4:31 am
Thanks for posting this.. very interesting to hear the Whalejet coming in.
On a humorous note, I've never heard that ground controller (starting around 10:30) so excited, in all the time I've listen to LiveATC at JFK.  Wink
Regards, Brad Williams
jacobin777
Tue Jun 10, 2008 7:42 pm
When the A380 came to SFO, it too had the callsign of "super".... yes
"Up the Irons!"
Zkpilot
Wed Jun 11, 2008 7:38 am
I understand that the 748I will also take on the Super designation as it is larger than the 744 heavy.
57 types. 38 countries. 24 airlines.
Dreamflight767
Sun Jan 17, 2016 4:35 am
Hey Crew:
What is the prefix on the flight progress strip for the super.
i.e. it's H/TYP for a heavy.
Thanks.
Whiteguy
Sun Jan 17, 2016 7:16 am
You hear the call sign followed by "Super" every initial call up in the U.S. and Canadian ATC. They fly to the U.S. pretty regularly already....
speedbird128
Sun Jan 17, 2016 1:07 pm
Quoting Whiteguy (Reply 30):
This thread is over 7 years 7 months old - FutureCaptain ejected a while back as his username is no longer active...
A306, A313, A319, A320, A321, A332, A343, A345, A346 A388, AC90, B06, B722, B732, B733, B735, B738, B744, B762, B772, B7
LONGisland89
Sun Jan 17, 2016 7:09 pm
Quoting Dreamflight767 (Reply 29):
The prefix is still "H/A388." The A380 is in the heavy weight class. Super is just used in radio communications.
Dreamflight767
Mon Jan 18, 2016 12:24 am
Thanks much. I thought so but I remember thinking/seeing it was a "J".
Mon Jan 18, 2016 12:56 am
"Super" and "Heavy" are used in Australia as well, at least by ATC. Most crews don't seem to bother.
Quoting LONGisland89 (Reply 32):
"A380" also has its own ICAO wake turbulence separation category.
Heavy behind Heavy 4 NM
Medium behind Heavy 5 NM
Light behind Heavy 6 NM
Light behind Medium 5 NM
Heavy behind A380 6 NM
Medium behind A380 7 NM
Light behind A380 8 NM
DocLightning
Mon Jan 18, 2016 1:42 am
At all ATC feeds I've listened to in the U.S. (JFK, LAX, SFO) have used the "Super" suffix on the A380.
-Doc Lightning-
-Carl Sagan
speedbird128
Mon Jan 18, 2016 4:43 pm
Quoting Dreamflight767 (Reply 33):
ICAO *is* a J to designate a Super.
H for Heavy
M for Medium
L for Light.
speedbird128
Mon Jan 18, 2016 4:45 pm
Quoting Starlionblue (Reply 34):
Forgot one there buddy
And Super following another Super has no wake separation, only radar minimum separation.
LONGisland89
Mon Jan 18, 2016 7:03 pm
The .65 still has the verbiage how the FAA has not rendered a final determination in support of the "J" indicator. Any idea when they'll get around to making a decision?
Users browsing this forum: 77west, aeropix, AirlineCritic, Armadillo1, qfvhoqa and 6 guests
