AT
Spoilers On Take Off?
Wed Apr 30, 2008 5:31 pm
I have been watching a number of videos on the likes of jetvideos and flightlevel350.com and have noticed a number of cases where the spoilers on the wing seem to rise (though not fully) during takeoff.
Why is this? Isn't the sole purpose of the spoilers to kill lift upon landing? If so, that seems counter productive.
voodoo
RE: Spoilers On Take Off?
Wed Apr 30, 2008 5:35 pm
Gust/ cross-wind effect dampening?
` Yeaah! Baade 152! Trabi of the Sky! '
767driver
Wed Apr 30, 2008 5:39 pm
On most large aircraft, spoilers are also used to assist the ailerons in turns. Therefore, if you turn right, the right aileron will raise along with several of the spoiler panels on the right wing. Since you would have right aileron in during a crosswind takeoff (xwind from the right), this would explain the spoiler action you are seeing in the videos
N160LH
Wed Apr 30, 2008 5:44 pm
Almost certainly spoilerons...
Not a big fan of Wiki, but its quick an easy....
http://en.wikipedia.org/wiki/Spoileron
-0LH-
"I do alright up in the air, its down on the ground that I tend to mess up..."
pilotpip
Wed Apr 30, 2008 7:56 pm
The spoilers would be up a bit if the pilot were adding proper crosswind correction.
DMI
PhilSquares
Thu May 01, 2008 12:20 am
Quoting Pilotpip (Reply 4):
From the 744 FCTM Limit control wheel input to
that required to keep the wings level. Use of excessive control wheel may
cause spoilers to rise which has the effect of reducing tail clearance. All of
these factors provide maximum energy to accelerate through gusts while
maintaining tail clearance margins at liftoff.
A properly executed x-wind takeoff should be accomplished without spoiler activation. Generally, there is enough lateral control using just ailerons alone. On the 744, at low speeds or with the flaps out of the up position, both inboard and outboard ailerons will be available.
Fly fast, live slow
474218
Thu May 01, 2008 1:18 am
On most large transport aircraft additional roll control is required when the flaps are extended. Therefore spoilers are mixed with the ailerons to provide this roll control. When the control wheel (or side stick) is moved to input aileron movement spoilers on the up aileron wing also move. Normally this movement is on a one to two basis (5 degree aileron would equal 10 degrees spoiler). Spoilers on the down aileron wing remain stowed. Without this feature roll control would be very sluggish as the lift created by the flaps cancels out some of the ailerons effectiveness. When the flaps are fully retracted this function is nulled as is the outboard aileron on some aircraft.
OPNLguy
Thu May 01, 2008 1:38 am
Quoting AT (Thread starter):
Keep in mind that there are ground spoilers and flight spoilers.
http://www.b737.org.uk/flightcontrols.htm#Spoilers_/_Speedbrakes
PhilSquares
Thu May 01, 2008 3:03 am
Quoting 474218 (Reply 6):
That's why on the Boeings you have inboard and outboard ailerons. The outboard ailerons are locked out with flaps retracted or at a higher speed.
Fly fast, live slow
767driver
Thu May 01, 2008 11:55 am
Quoting PhilSquares (Reply 5):
The 767/757 FCTM says the exact same thing, however "excessive control wheel deflection" is not defined. In a strong crosswind, I do what is necessary to keep the wings level, but I'm sure there is slight spoiler activation. It's not excessive, but it does exist.
The 757 is more susceptible to spoiler activation during a strong xwind takeoff since we don't have inboard ailerons.
Spoiler activation on a 767-300 during t/o..
http://jetvideos.net/video/view.php?id=371
[Edited 2008-05-01 05:16:26]
PhilSquares
Thu May 01, 2008 1:14 pm
Quoting 767driver (Reply 9):
Excessive control wheel deflection is defined as continuous spoiler activation. On the 400 with the outboard aileron unlocked, there is usually enough of control authority to do a cross wind takeoff with no problems.
Fly fast, live slow
point8six
Thu May 01, 2008 1:47 pm
Control-wheel deflection should only be sufficient to keep the wings level during a cross-wind take-off. Even max. cross-wind should not require control-wheel deflection that extends the spoilers significantly. The tendency is often to deflect the wheel according to the reported wind, rather than deflect it to counter the wing-drop caused by the actual wind, thereby inducing a degree of 'over-controlling'.
767driver
Thu May 01, 2008 2:31 pm
Quoting Point8six (Reply 11):
Exactly. The key word here is "significantly". Spoilers (at least on the 767/757) will be slightly extended during a strong xwind.
474218
Thu May 01, 2008 2:41 pm
Quoting 767driver (Reply 12):
What make the spoilers extend during a strong cross wind and do they extend asymmetrically?
767driver
Thu May 01, 2008 2:57 pm
Quoting 474218 (Reply 13):
They extend as a function of aileron displacement. As you turn the yoke, the ailerons move along with proportional extension of the spoilers. Example, you turn the yoke to the right, the right ailerons will first move up, then the more you turn the yoke, the spoilers on the right wing will begin to extend to aide in turning the airplane (creating more drag on the right wing)
474218
Thu May 01, 2008 3:22 pm
Quoting 767driver (Reply 14):
I said that exact same thing in reply 6, but people kept talking about cross wind takeoffs and got me confused. The only reason the spoilers are up on a cross wind takeoff (or landing) is because the ailerons (aileron) on the same wing are up.
Also the up aileron/spoiler takes away lift and the down aileron creates more lift, both effect the drag. It is the differential lift that aids in turning, not drag.
vc10
Thu May 01, 2008 5:26 pm
Quoting 474218 (Reply 15):
I always thought there was a thing called differential aileron where the up going aileron moved more than the down going aileron, so there was less drag on the down going aileron side [ sorry about all the downing and uping]
littlevc10
474218
Thu May 01, 2008 9:05 pm
Quoting Vc10 (Reply 16):
While some aircraft may have differential aileron travel, none of the on the aircraft I worked on (Lockheed/Douglas/Convair) did. On all of them aileron travel was the same on th up wing and the down wing.
Users browsing this forum: PlaneCookies and 1 guest
