Longitude
Cabin Pressure Altitude
Sat May 03, 2008 4:27 pm
Hello,
Can somebody tell me which cabin pressure altitude should be estabilished during a flight according to FAR? Is it different in Europe?
Thank you!
Tod
RE: Cabin Pressure Altitude
Mon May 05, 2008 3:42 pm
Jetlagged
Mon May 05, 2008 5:01 pm
Quoting Tod (Reply 1):
8,000 feet per 14CRF25.841
"Not more than 8,000 ft". It can be, and usually is, less than that.
Tod
Mon May 05, 2008 5:05 pm
Quoting Jetlagged (Reply 2):
My experience is that wide body international flights usually run in the 5600 - 6800 range where US domestic flights seem to average between 7000 - 8000.
Tod
Jetlagged
Mon May 05, 2008 7:40 pm
Quoting Tod (Reply 3):
It mostly depends on the aircraft type and the cruise altitude. Typically aircraft of a given type cruise at the same cabin differential pressure. So the cabin altitude will vary according to cruise altitude assigned. If you know what cabin diff press the CPC sets you can work out what the cabin altitude will be.
On older aircraft where cruise altitude is entered manually a higher cruise altitude than actual can be entered if required.
Users browsing this forum: EricAY05 and 2 guests
