UltimateDelta
What Panel Is This?
Tue May 13, 2008 10:47 pm
Hi, everyone. Just a few days ago, I was in Atlanta and in a picture I took of a 767 taking off, I noticed a small panel that stuck out from the fuselage above the windows near the wing. Here is a cropped photo. Does anyone know what this is here for? Thanks for any info you have.
Big version: Width: 416 Height: 314 File size: 28kb
Fuselage panel, N180DN
Midwest Airlines- 1984-2010
futurecaptain
RE: What Panel Is This?
Tue May 13, 2008 11:11 pm
Chemtrail generator. And now that you found it the men in black suits are going to come haul you away.
EMBQA
Tue May 13, 2008 11:33 pm
Looks like a sheet metal repair doubler
474218
Wed May 14, 2008 12:06 am
Quoting EMBQA (Reply 2):
I agree, you can see the first layer (thinner layer) next to the skin and the second (thicker layer) on top.
zanl188
Wed May 14, 2008 12:17 am
Quoting 474218 (Reply 3):
Whatever it is appears on the left side of this aircraft too... and from what I see in the photo database it looks to have been there for a while...
edit: Further checking of the photo database reveals a number of Deltas 767-300s have this feature. I'll guess it's some sort of sat antenna. Perhaps offset to the side of the fuselage to improve the view of the sat during turns.
Photo © Gerry Hill - WorldAirImages
[Edited 2008-05-13 17:25:05]
[Edited 2008-05-13 17:26:19]
474218
Wed May 14, 2008 1:17 am
ZANL188:
I checked the photo's too and did see it on several 767-300. I can the doubler and something on top but now I have no idea.
SFOMB67
Wed May 14, 2008 5:32 am
It's a radio antenna. Satcom I believe. We had trouble with them a few years ago , the mounting screws that went into pocket nutplates were too long and pushed the nutplates loose in the fuselage.
[Edited 2008-05-13 22:46:04]
Dalmd88
Wed May 14, 2008 6:38 am
Quoting Sfomb67 (Reply 6):
Correct, it is a SatCom antenna. Each plane has on on each side. The SatCom satellites are in geosyn orbits over the equator so by putting one on each side there is always one antenna facing the sat while the airplane crosses the North Atlantic. This system is pretty much required to fly these routes now. Planes that are equipped with SatCom and GPS/IRU can fly with less separation on the NATL tracks than those that use the old HF and only IRU set up.
Francoflier
Wed May 14, 2008 10:11 am
It looks like a band-aid...  Smile
Quoting DALMD88 (Reply 7):
I would have thought the 767-300 came equipped with those out the factory... Was it an option back then?
boeing767mech
Wed May 14, 2008 8:14 pm
Interesting configuration for the satcom antenna's. Our fleet has the turtle shell type of satcom antenna's. I never knew there was two different types.
David
Never under-estimate the predictably of stupidty
AAH732UAL
Wed May 14, 2008 8:54 pm
Quoting Francoflier (Reply 8):
Simple, b/c things change over time and the 767 is old but great technology. Like when most 767s and prolly this 767 came out, datalink was just a twinkle in someones eye. Now Datalink/Satcom are the norm on most any airplane going into non-radar or HF areas.
Just like the FMC's can/have be updated w/ the option of GPS MMR and etc. Things change overtime ALL the time.
Like back in the early days of the 767-200 I think the plane had to be flown in raw data in the terminal area for ILS or NPA(Non-percesion approach). Now only the PNF has to watch RAW data at the FAF on in if the procdure is LSKable or from the IAF if the approach has been built by hand on a NPA only while for ILS both pilots can be in MAP.
Examples like that are the reason this feature was not factory fresh.
I mean WAAS is the next big thing and only the 787 and A380 can get WAAS/LPV fresh out of the factory and I say that b/c in a few years there will be a lot of new "PATCHS" showing up on airplanes when this stuff starts to really become the norm in commercial aviation.
[Edited 2008-05-14 14:02:38]
DME/DME RNP0.3 NA -Escalators don't break---- they just become stairs!
SFOMB67
Wed May 14, 2008 10:04 pm
i'm sure it was BACO installed on the -300's, -200's didn't have it. Probably an option that was ordered.
474218
Wed May 14, 2008 10:50 pm
If you check the photo data base the panel seems to only be on the international airframes.
DL_Mech
Thu May 15, 2008 11:38 pm
Quoting Boeing767mech (Reply 9):
DL has the turtle shell on 777's and 764's.
The flat plate Satcom antennas are on most 767ER's (not 1701-1708) and were on some former A-310's (035-043) MD-11's and one L-1011
Photo © AirNikon
This plane is built to withstand anything... except a bad pilot.
Tod
Fri May 16, 2008 3:46 pm
777 came from the OEM with either one sat antenna array on top or a set on each side.
Customer option.
Tod
Users browsing this forum: MO11, SEQU and 1 guest
