miamix707
CAD Software In Aircraft Repair
Tue Jun 10, 2008 5:08 am
Anyone who uses CAD to make drawings and draw parts in repairs of commercial aircraft and if so, which program specifically?
dl757md
RE: CAD Software In Aircraft Repair
Tue Jun 10, 2008 5:22 am
As an AMT I don't use it but Delta's engineering department uses Autocad for engineering drawings.
miamix707
Tue Jun 10, 2008 4:40 pm
Quoting Dl757md (Reply 1):
Seems like good 'ol AutoCAD is the standard then. Sorry, but what's AMT stand for?
Tod
Tue Jun 10, 2008 4:44 pm
Quoting MIAMIx707 (Thread starter):
When the repairs/parts are part of an ongoing mod it happens.
We use CATIA (good) and CADRA (sucky).
Tod
jetmech
Tue Jun 10, 2008 5:47 pm
Quoting MIAMIx707 (Reply 2):
Aircraft Maintenance Technician.
Regards, JetMech
miamix707
Tue Jun 10, 2008 6:08 pm
Quoting Tod (Reply 3):
oh I thought CATIA was mostly used by Boeing or Airbus when designing the airplane
Quoting JetMech (Reply 4):
 thumbsup
FredT
Tue Jun 10, 2008 7:16 pm
Quoting MIAMIx707 (Reply 5):
Kinda makes sense to use the same CAD tool for initial design, redesigns, repairs, rebuilds and everything else though, doesn't it? FWIW we used CATIA when I was employed by an OEM, and it wasn't Airbus or Boeing...  Smile
roseflyer
Tue Jun 10, 2008 7:19 pm
I use CATIA, but it's not for repair. It's for initial design.
Yes CATIA is used by Boeing, but V5 CATIA is also useful for much smaller applications. It's far more powerful than AutoCAD or Solid Edge (which I've used elsewhere), but can be used. In the end, drawings are drawings, and it is not important what their source is if they accomplish their job.
sunrisevalley
Tue Jun 10, 2008 11:15 pm
Quoting RoseFlyer (Reply 7):
Is there any compatibility between any of these systems? I would have thought that if a part was designed on a particular system and it became necessary to modify it in the field it would be desirable to do it on the system on which it was originally designed.
tdscanuck
Wed Jun 11, 2008 12:39 am
Quoting SunriseValley (Reply 8):
Converters exist to go between formats, and there are some "universal" formats, but there are hazards with all of them. All other things being equal, it's nice to work in the original system.
However, it would probably take an act of god to get an OEM to give up the full CATIA model for a part, so I doubt you're going to have the original file to work with anyway.
Tom.
miamix707
Wed Jun 11, 2008 1:19 am
Which releases of AutoCAD would work with 1GB RAM on my Vista laptop? I used to work with an older version that required little memory.
I will mostly be creating 2d views not 3d
Anyone use Unigraphics? Supposedly also used on the auto/aircraft industry
Good question, is the output of all these .dwg files?
sunrisevalley
Wed Jun 11, 2008 2:29 am
Quoting MIAMIx707 (Reply 10):
I use V14 , my files are pretty small and it works very well with a Celeron processor and a gig of RAM. I found a file on the internet that allows V14 to work under Vista.
Tod
Wed Jun 11, 2008 7:19 pm
Nope
Alot of conversions require an interium step between using .dxf or .iges
Tod
miamix707
Thu Jun 12, 2008 2:30 am
Quoting SunriseValley (Reply 11):
You know back then when I saw the R14 had changed the position of the buttons, etc I didn't really like it and kept using 13
Quoting Tod (Reply 12):
I had no idea
Users browsing this forum: masi1157 and 1 guest
