Nicoeddf
B744F/BFC Upperdeck Use
Sun Jun 15, 2008 2:12 pm
Hey there,
just saw the "new" Kalitta 747 Freighter, which is a converted ex-Malaysia aircraft.
Of course, as ex-pax airplane, it has its normal length 747 upperdeck and i wonder what it is used for? Parcels? Bulk freight?
Thanks  Smile
PhilSquares
RE: B744F/BFC Upperdeck Use
Sun Jun 15, 2008 2:23 pm
Quoting NicoEDDF (Thread starter):
IIRC, the on the conversion the upper deck is from the aft of the upper deck doors forward. The upper deck is used for any freight, either bulk or parcel.
Fly fast, live slow
Tod
Mon Jun 16, 2008 3:37 pm
If the conversion was done by Boeing then the u/d floor ends aft of the doors. The forward portion will have a lav, a galley and overhead stow bins. It can also include seats and/or bunks depending on the customer configuration.
Tod
Tue Jun 17, 2008 1:34 am
So basically you can stack higher under the back of the hump.
wn700driver
Tue Jun 17, 2008 3:48 am
Yet another plane I would love to see a Mike Badroke drawing of.
Base not your happiness on the deeds of others, for what is given can be taken away. No Hope = No Fear
Nicoeddf
Tue Jun 17, 2008 7:31 am
Thanks guys for the answers  Smile
Tod
Tue Jun 17, 2008 1:41 pm
Quoting Starlionblue (Reply 3):
Once you get past the upper deck floor beams your got more headroom all the way back.
Tod
Flyer732
Wed Jun 18, 2008 9:49 pm
Actually, I've never seen any cargo go upstairs on our 744CF. We have 12 lie flat seats, a galley, a lav and a bunk area with two beds. The area right behind the exit doors upstairs is empty. The flooring has been removed and there is a door there. At the top of the ladder to the upper deck, there is a door that acts as the smoke barrier that prevents fumes and smoke from entering from the main deck should there be a fire or leak of any hazmat.
Hope that helps...
Nicoeddf
Wed Jun 18, 2008 10:18 pm
Quoting Flyer732 (Reply 7):
Thanks, but why so many lie flats?
Are the freighters flying so long rotations to be in need of so many rest area?
Flyer732
Thu Jun 19, 2008 1:56 am
It is a former MH aircraft, and to put in different seats would have required a recertification of the aircraft with new seats...whereas if we just left the MH seats on it, no new certificate was needed. How they came to the number that we have, I don't know...
However, I can say that on some of the flights I've seen 4 pilots in the cockpit, 2 mechanics, one loadmaster and two other pilots in the cabin, so the seats are being used.
Big version: Width: 1024 Height: 683 File size: 389kb
Theres a shot of what the cabin looks like.
Xerses
Thu Jun 19, 2008 2:43 am
forgive my ignorance, but what does "B744F/BFC " refer to? a Boeing 747-444? What's BFC? Is there a list somewhere that gives all these terms?
tdscanuck
Thu Jun 19, 2008 3:09 am
Quoting Xerses (Reply 10):
A 747-400F is a 747 built as a freighter by Boeing. A 747-400BCF is a "Boeing Converted Freighter". It began life as a 747-400 passenger aircraft and then was converted to a freighter using Boeing modifications.
A reasonable overview is here:
http://en.wikipedia.org/wiki/Boeing_747-400
Tom.
AA737-823
Sun Jun 22, 2008 1:40 am
No, you can't.
The flight control cables travel through the upper deck floor, and are not repositioned. The aft half of the upper deck cabin isn't furnished with anything, to save the weight.
JAL's 744-BCF aircraft have 12 business class seats upstairs, and a galley just aft of the exit doors. aft of that is just a wall, with blowout doors.
But you don't get any more headroom.
Qantas744er
Sun Jun 22, 2008 3:18 am
Quoting Flyer732 (Reply 9):
Man you guys are really lucky that you got to keep those new MH Business class seats!
Other 74F operators are not as lucky  Silly
Is the AVOD still powered during flight?
Leo  Smile
You live and you die, by the FMA
SA7700
Sun Jun 22, 2008 7:55 am
a Boeing 747-444?
The first 4 (444) refers to the specific series - in this case the 747-400. The last two 4's is the designated customer code, which was introduced by Boeing in order to identify the first owner of the plane. In this case 44 = South African Airways.
When you are doing stuff that nobody has done before, there is no manual – Kevin McCloud (Grand Designs)
Mon Jun 23, 2008 12:51 am
Quoting AA737-823 (Reply 12):
I see. Thanks.
Flyer732
Mon Jun 23, 2008 9:25 am
Quoting Qantas744ER (Reply 13):
The TV's are still there, but they do not work. The system was taken out during the conversion. So its just like any other freighter in our fleet, except the seats are much nicer, and there is loads more room.
Users browsing this forum: E2 and 3 guests
