Xerses
747-400 Mtow Differences
Wed Jun 18, 2008 5:01 pm
The 747-400 Airport planning document gives max take off weights of 800,000lb to 875,000lbs. Why are there different reported weights? Is the structure different? I know the domestic version has smaller tires and the SP actually has a shorter MLG bogey.
Is there a database/spreadsheet that compares the differences for 747s?
PhilSquares
RE: 747-400 Mtow Differences
Wed Jun 18, 2008 6:08 pm
Quoting Xerses (Thread starter):
On the 744, it's just an issue with paperwork. If you want the 875,000 weight, you pay more. If not, you don't pay any extra. There are no structural differences at all between the gross weights. The same was true on the 747-200A/B.
Fly fast, live slow
point8six
Wed Jun 18, 2008 7:50 pm
Some -400's (BA's 'lites') were delivered without stab. tank capability and had a lower MGTOW. Aware of Japan's 'domestic' version, but I thought the 'SP' was a Classic version? Also 400F's have the lower( as for 'Lite') MGTOW as they do not use a stab. tank.The latest 400ERF has a MGTOW of approx 915000lbs.
Caryjack
Thu Jun 19, 2008 12:04 am
MTOW, right?
Quoting PhilSquares (Reply 1):
the gross weights
Quoting Point8six (Reply 2):
a MGTOW
We went from MTOW to MGTOW. What's the difference please?  confused
Cary
Viscount724
Thu Jun 19, 2008 12:17 am
The 744D also lacks the wingtip extensions and winglets. It has the same wingspan as the 741/742/743, about 16 ft. less than other 744 models. The wintip extensions and winglets can be added to the 744D if a carrier wanted to use it in longhaul operations.
Xerses
Thu Jun 19, 2008 2:37 am
Thanks for the info on the Domestic, but I'm mostly interested in the plain old -400. The 747-400 Airplane Characteristics for Airport Planning document (D6-58326-1) found on the boeing web site gives several Max Design Takeoff Weights for the regular 747-400 on page 10 of 800,000lbs, 833,000, 850,000, 870,000 and 875,000. PhilSquares says its for people to just pay more. Does anyone have a reference that supports that? I was wondering if it was due to internal arrangements that shifts the CG and thus limits the Max weight. Or perhaps there are slightly different wing or gear structural components. My final thought was that a lower placarded MTOW and MLW may give more cycles on the gear and airframe.
My flight sim is way out of date, I was wandering if anyone with newer versions or add ons has different 747-400 that have MTOW like those above?
Anyone else have a good theory or a quote from a coffee table book?
I saw one interesting side note in "http://www.airliners.net/aircraft-data/stats.main?id=100", It mentions, "The -400ER incorporates the strengthened wing, body, and landing gear of the -400F" which in turn is quoted from The International Directory of Civil Aircraft by Gerard Frawley.
That indicates to me that there are some differences between the 747-400 and 400F but that is interesting because those two aircraft have the same MTW, and MTOW but the -400F has MLW that is 36,000 lbs greater than the 400. That makes me go hmmmmmmm.
Cary, I believe MTOW and MGTOW are the same thing. It depends on the company. I think that manuals giving generic info like the one I mention above actually calls it the Maximum Design Take Off Weight, but in actual flight manuals it just says Maximum Takeoff Weight. Gross is an older term, I've heard people refer to an aircraft's MGW (Max Gross Weight) or just max gross but what they mean is the maximum weight that you can begin to fly. Another term for the same thing is Maximum Weight at Brake Release.
Thu Jun 19, 2008 2:42 am
Quoting Xerses (Reply 5):
As you say F has strengthened wing, gear and body. The max take off weight will be the same. You can just take less fuel. However you can land with heavier payload.
MarkC
Thu Jun 19, 2008 2:46 am
Same with the engines. If you wanted PW4060's instead of 4056's, you would have to pay for the extra 4000 pounds. Its the same engine except for the program plug.
Xerses
Thu Jun 19, 2008 3:02 am
Is that how you get more MTOW by having higher rated engines? I did see in the 747-100 airplane characteristics document that the the MTOW seemed to be tied directly to the version of the JT9, but the 5 weights I stated before are the same for the PW4056, CF6-80C2B1, and the RB211-524G2 engines.
Is there a book or paper available that talks specifically about the differences like the the wing and gear on the F?
tdscanuck
Thu Jun 19, 2008 3:08 am
At least part of it is the different engines. Different thrusts give you different MTOW's.
The struts and nacelles are different depending on whose engine it is.
I'm sure there is, but I've never seen one publicly available.
I'm not aware of any aircraft whose MTOW is caused by a CG limit...you can always rearrange the same payload weight to move the CG.
Tom.
Flighty
Thu Jun 19, 2008 4:03 am
Who has the most capable 744s in existence? 875k weights and so on? Does UA? NW?
Max Q
Thu Jun 19, 2008 5:48 am
Must be QF with their 910,000lb -400-ER'S
Qantas744er
Thu Jun 19, 2008 2:01 pm
Wrong, depending from airline, but for example atlas air have the max available MTOW on all their 74F's of 875,000Lbs. The 74F can have the same MTOW options like the 744 just without the stab tank.
Leo
Quoting Flighty (Reply 10):
I wouldnt directly say most capable, as airlines buy their planes adapted to their needs. This is a main factor on engines choices etc.
But if you want to know some 875k operators:
UA
NW
SQ on their 744 (their 74F have 870k)
5Y
PO
CX
NH
and the list goes on...
You live and you die, by the FMA
Caryjack
Thu Jun 19, 2008 7:00 pm
Thanks Tim. You're off to a good start with interesting and informative posts. I'm looking forward to reading many more. Welcome to A.net.
Cary
tito
Thu Jun 19, 2008 10:07 pm
Quoting Qantas744ER (Reply 12):
UA
NW
5Y
PO
CX
NH
Just FYI, CX 400F's are 870k MTOW
[Edited 2008-06-19 15:12:46]
Xerses
Thu Jun 19, 2008 11:34 pm
Where do you find info like who are the 875k operators? is there a document? a web source?
Xerses
Fri Jun 20, 2008 12:07 am
Are all of United's aircraft 875k?
tdscanuck
Fri Jun 20, 2008 1:07 am
Quoting Xerses (Reply 15):
Probably not. There are web sources where you could find which ones were delivered as 875k but, since there are Service Bulletins out there to switch it around, it would be impossible to know which ones are currently 875k without contacting each individual operator and asking them. There is no central database to tell you the current SB status of any particular aircraft.
Tom.
Qantas744er
Fri Jun 20, 2008 2:15 am
Quoting Tdscanuck (Reply 17):
Tom.
http://www.buchair.com/JPAF.htm Book gets updated every year with aircraft registration data from 99% of the countries, so the MTOW data for most aircraft is correct!
This is my main source. Not always correct but personal knowledge is always available too.
Well it aint hard to find out about 870k or 875k since these changes are not simply made from day to day basis, and knowing a UA pilot in this case would be enough if regarding UA for example.
Quoting Xerses (Reply 16):
Correct and since delivery.
In some countries like the the UK the CAA has a online register giving you a lot of info when you enter the UK reg.
Like current MTOW, Hours, etc.
Have a good one  Smile
tdscanuck
Fri Jun 20, 2008 5:21 am
Quoting Qantas744ER (Reply 18):
They're seriously polling every operator every year to find out which SB's they've done? And the operators actually supply this data reliably?
Tom.
Qantas744er
Fri Jun 20, 2008 4:24 pm
Quoting Tdscanuck (Reply 19):
Tom.
It is done by certain people that handle their countries data, this info does not need to come directly for the operator as some countries provide this information for the public. So its around 99% correct as during the the year some aircraft receive MTOW changes...
Leo  Smile
dispatchguy
Fri Jun 20, 2008 5:07 pm
That is standard industry wide.
When I dispatched at a BAe146 operator a long time back, we had one airplane (N632AW, a B146-100) that had the authorization for a 15kt tailwind takeoff in the Airplane Flight Manual and the Operations Specifications, and only at Aspen Airport (KASE). We had a specific appendix to the AFM with the specific performance charts for that condition.
I asked why the reasons for only one airport and for only one airplane. Company didnt want to pay for the engineering work to have it done and approved for the rest of the -146 fleet.; especially for 3 variants of the fleet, for the engineering work would have to be done for each individual variant.
Most basic Boeing AFMs (regardless of aircraft type) limit takeoff field elevation to 8400-8500ft, but yet Boeing airplanes operate daily down in South America with some field elevations well above 10K. Those carriers paid for the additional engineering work to have higher field elevations approved and put into the AFM.
Nobody screws you better than an airline job!
Viscount724
Sat Jun 21, 2008 12:28 am
I think the hours shown in the UK CAA registration info is only since the C of A was last renewed so it's often not very useful. For example, for the following BA 744, the hours are as of December 2004. The C of A expires this August.
http://www.caa.co.uk/application.asp...detailnosummary&fullregmark=G-CIVK
However the UK registration info does seem more informative than the equivalent FAA data. The UK info includes MTOW and even photos of the aircraft, with links to a list of updates to the flight manual etc.
This is an example of the FAA registration info for a UA 744.
http://registry.faa.gov/aircraftinquiry/NNumSQL.asp?NNumbertxt=198UA
tdscanuck
Sat Jun 21, 2008 1:05 am
Quoting Qantas744ER (Reply 20):
Must be different than in the US. As far as I know, there's no requirement for operators to report SB incorporation to the regulators here.
Tom.
Users browsing this forum: Adispatcher, flipdewaf, WyomingWind and 1 guest
