phxpilot
What If You Had A Giant Fan?
Tue Jul 01, 2008 7:28 pm
In an effort to mimic the epic conveyor belt topic, what if the airport placed a giant fan at the end of the runway? Of course the fan would need to be about 300 feet in diameter in order to cover the largest wingspans, plus a little extra. It must also be capable of producing ~160 knots by the time the airflow got to the airplane. Aircraft performance is all about relative wind so theoretically, even if the airplane was stationary, with enough relative wind it should be able to fly.  biggrin
Feel free to discuss amongst yourselves.  box
KELPkid
RE: What If You Had A Giant Fan?
Tue Jul 01, 2008 7:31 pm
What would happen once you flew outside the fan's airflow? Talk about wind shear...  Wow!
bond007
Tue Jul 01, 2008 7:41 pm
Quoting KELPkid (Reply 1):
Well, it's simple. You attach the fan, via a long piece of 'something' to the front of the airplane. That way, when the airplane lifts off the ground, so does the fan ... but wait ... when the plane moves forward, so does the fan .... I've got it  Smile
...hmmmm ... now the fan's moving, so the relative airflow is .......
Jimbo
cdekoe
Tue Jul 01, 2008 7:52 pm
Sooo... does the fan in your example blow... or suck?  Yeah sure
We can't solve problems by using the same kind of thinking we used when we created them.
WPIAeroGuy
Tue Jul 01, 2008 7:56 pm
You would have a giant air-blender and nice splattering of birds, bugs, and remnants of those poor souls who attempted a go-around.
-WPIAeroGuy
bond007
Tue Jul 01, 2008 7:59 pm
Quoting WPIAeroGuy (Reply 4):
... or attempted to land opposite direction!
Jimbo
GST
Tue Jul 01, 2008 8:01 pm
Lets ssee...maybye, if we take the fan, make it smaller, and attatch it to the front of the plane?
Soku39
Tue Jul 01, 2008 8:03 pm
300' diameter fan? Well something like this would happen when you got to 310' AGL. Stall, Crash, Done.
I like GST's idea much better.
The Ohio Player
Mastropiero
Tue Jul 01, 2008 8:06 pm
I´d say "it" would hit the fan pretty quickly.....
David L
Tue Jul 01, 2008 8:26 pm
That would depend on how steep the speed gradient was between the "core" air and the surrounding air. If the gradient was shallow enough for the aircraft to accelerate to flying speed as it left the core airflow, it would be OK. However, wouldn't that defeat the purpose of the fan, since the aircraft would have to accelerate from zero to flying speed at some point, anyway?
Quoting GST (Reply 6):
That's just ludicrous. It'll never happen.
KELPkid
Tue Jul 01, 2008 8:53 pm
Quoting Bond007 (Reply 2):
As I recall, since shortly after Orville and Wilbur and Glen Curtis, that's how we've been flying  Smile (well, except for guys like Dick Rutan, who, in the name of not doing things the conventional way, still insist on the same prop, erm, fan, placement as the Wright Brothers used...)  Wink
I recall that my instructors Cessna 172-180 (172 with a Great Planes 180 HP engine conversion, using the climb prop) and Horton STOL craft kit could almost be hung on the prop...you could hold it with zero indicated airspeed and stall horn bleating like a tortured sheep and the engine at full throttle. You could keep it there until the oil and cylinder head temeratures started to climb rather high... Big grin
bond007
Tue Jul 01, 2008 9:15 pm
Quoting KELPkid (Reply 10):
LOL .... very good, so we have  Smile
Jimbo
dw747400
Tue Jul 01, 2008 10:16 pm
Never could get a C172-180 to hang on the prop (but we have a cruise prop, maybe that makes enough of a difference), but try it in a C172-210 (aka T-41C)--easily sit with the airspeed on 30 knots, 20+ degrees nose up, and hold level flight.
CFI--Certfied Freakin Idiot
GST
Tue Jul 01, 2008 10:35 pm
Quoting Dw747400 (Reply 12):
But your airspeed wont really be 30kts though will it? Your pitot wont be pointing at the airflow, and so the ram air pressure will be waaay down. God knows what the static port will be reading if you dont have a pitot static tube...
wingscrubber
Tue Jul 01, 2008 10:49 pm
What if you only fly on very windy days!!!??*%*%&$@!! Big grin That's kinda like having a big fan...
http://www.youtube.com/watch?v=7_dgrBevUOw
Or what about a big fan like this??
http://www.youtube.com/watch?v=51yVbEb_bLo
Resident TechOps Troll
Wed Jul 02, 2008 9:00 am
Im thinking.......High RVR on the Runway on days of fog due to the fan  Smile
regds
MEL
vzlet
Wed Jul 02, 2008 12:19 pm
Quoting Phxpilot (Thread starter):
For safety, efficiency, and consistency of results, the giant fan would have to be enclosed, perhaps in some sort of a tunnel...
"That's so stupid! If they're so secret, why are they out where everyone can see them?" - my kid
flyf15
Wed Jul 02, 2008 2:22 pm
If you can have a fan blow 160kt air at a plane, as long as that is above the normal rotation speed, you could sit there facing into the fan with the parking brake set, rev of the engines, pull back, and you would take off vertically.
I've seen this happen (on a smaller scale). We had a Helio Courier based at an airport near my house a while back. With winds of 30-40kts down the runway, he could park at the end of the runway, run the engine up, and take off vertically and then continue to climb vertically until deciding to make a turn. Even though ground speed was zero, his true airspeed was 30-40kts, enough for a plane like the Courier to fly apparently. Pretty cool to watch.
baroque
Wed Jul 02, 2008 3:02 pm
It might be easier to have the plane roll down a steep hill. Mind if the wind changed you might have to move the hill - which might not be so easy.  Wink
GST
Wed Jul 02, 2008 3:08 pm
Quoting Baroque (Reply 18):
not so...just build a round hill so from the top you can roll the plane in any direction.
WPIAeroGuy
Wed Jul 02, 2008 4:02 pm
I posted a while ago about sloped runways. Two parallel runways with opposite slopes. The far end of the "landing" runway would be above the height oft he taxiways allowing planes to roll to their gates, and the take off runway would start lower than the heigh of the taxiways and be sloped down. Energy that would normally be lost to braking would simply be used landing uphill, and then the plane could roll to the gate. After pushback, the plane could roll downhill to the runway. It would get rid of expensive tugs and wasting fuel taxiing, and less brake wear during landing could offset the increased break and tire wear of turning on slopes.
-WPIAeroGuy
nighthawk
Wed Jul 02, 2008 4:57 pm
How about shrinking the fan down, reversing it and strapping it to the wings so that it pushes the plane forward instead?
... oh wait...
KELPkid
Wed Jul 02, 2008 5:05 pm
Quoting Nighthawk (Reply 21):
... oh wait...
Wouldn't that be kind of a sucky idea?  eyebrow
Quoting Cdekoe (Reply 3):
Depends on which side of the fan upon which you stand  silly
WESTERN737800
Wed Jul 02, 2008 7:10 pm
Somone should try setting up a big fan. It could be another Airport movie in the making.
Bring back Western Airlines!
KELPkid
Wed Jul 02, 2008 8:01 pm
In a more practical matter, I would hope you could shut the fan off while the aircraft was taxied onto/off of the runway, as I'd hate to taxi a Cessna onto the active while fighting a 150 knot crosswind. Heck, I'd hope the speed was variable, as a 150 knot headwind would be getting up near Vne in the 172  Wink
bond007
Wed Jul 02, 2008 8:30 pm
Quoting KELPkid (Reply 24):
Well it's obvious ... 3 clicks, 5 clicks, or 7 clicks for the PCF.
As always, rule of thumb, click again on final so it doesn't time-out... that might be bad.
Jimbo
GST
Wed Jul 02, 2008 9:28 pm
Quoting WPIAeroGuy (Reply 20):
You dont need 2 in opposite slopes, just look at CVF. Take off downhill, land uphill.
baroque
Thu Jul 03, 2008 4:47 am
The old runway at the Porgera gold mine in PNG had such a steep slope that taxying up was at a fairly high throttle setting. I have a photographs somewhere, it must have been about 1 in 12 ish. Takeoff downhill happened quite suddenly and straight over a very deep valley.
They moved to a nearly level runway, but I don't think they had any problems with the steep one.
The biggest problem was the time they accidentally resurfaced one of the nearby roads with some of the high grade ore with visible gold instead of the usual overburden. It certainly showed how to get a road excavated in double quick time.
phxpilot
Thu Jul 03, 2008 5:40 am
I'm glad I started this topic 'cause I love the replies. You guys are WAY too funny!  rotfl
MissedApproach
Thu Jul 03, 2008 1:01 pm
Well, it's not nearly as slick as a conveyor belt or giant fan, but what about circular runways?
http://www.time.com/time/magazine/ar...171,842350,00.html?promoid=googlep
http://technology.newscientist.com/c...circular-runways-for-airports.html
Strange that no one seems to have tried this out, maybe at a smaller regional airport.
Can you hear me now?
GST
Thu Jul 03, 2008 4:39 pm
KELPkid
Thu Jul 03, 2008 6:10 pm
Quoting MissedApproach (Reply 29):
Actually, if you research the term "aerodrome", I think you'll find that it refers to a grassy, more or less circular takeoff and landing area (that disappeared as we figured out runways were just a better way of doing things  Wink ).
bond007
Thu Jul 03, 2008 7:11 pm
The thought of missed approaches, go-arounds, and aborted take-offs is quite frightening, especially with 6 aircraft using the 'circle' at the same time  Smile
Jimbo
KELPkid
Thu Jul 03, 2008 7:25 pm
Quoting Bond007 (Reply 32):
Jimbo
Just make 6 circles  idea
But then how do you designate them?  Wink
Wonder what you'd do for an instument approach, a big NDB in the middle of the circle Big grin ?
bond007
Thu Jul 03, 2008 7:36 pm
Quoting KELPkid (Reply 33):
Circle to land!
Jimbo
Mir
Thu Jul 03, 2008 7:42 pm
Sounds good. But why stop at just one? Why not have two fans, one for each wing? Or even two per wing if the airplane needed a lot of lift to get off the ground?
-Mir
KELPkid
Thu Jul 03, 2008 8:09 pm
Quoting Mir (Reply 35):
-Mir
Why would you ever want to do that? Just imagine what would happen if one fan failed and the other kept going, you'd have to specially train each and every pilot to deal with just that scenario. I don't think you could let just normal pilots fly a multi-fanned plane. Not to mention all the problems associated with assymetry when one fan quits...(I hear pilots can get awfully hot and start sweating when that happens!). Next thing you know, the airlines will only want to hire pilots with only lots and lots of multi-fanned time, but the lawyers will sue the makes of multi-fanned planes because they are a little trickier to fly than the single-fanned kind, making the multi-fanned ones exhorbitantly expensive to fly around  Smile
Should you design it so the fans rotate in the same direction, or in opposite directions?  eyebrow
flexo
Thu Jul 03, 2008 8:48 pm
Quoting KELPkid (Reply 36):
I would have to vote "4 fans 4 all aircraft" here!
GST
Thu Jul 03, 2008 10:38 pm
Or you could put one fan on the front, and another on the back!
You could even put a small aquafan on the bottom and make plane's long tube thing waterproof, then you will have the option of landing, or "watering" for a swim to break up the monotony of a long flight.
jetlife2
Mon Jul 07, 2008 4:32 pm
Quoting GST (Reply 38):
Ours aren't 300', but they're pretty big. They both go the same way.
My views are not necessarily the views of the GE Company
Users browsing this forum: B6JFKH81, DeanBNE and 3 guests
