landgreen
The Economics Of RJ Vs Prop
Mon Jul 07, 2008 8:14 pm
From reading the Boyd aviation hot flash every Monday I hear alot of RJ bashing, but I'm not quite clear on why an RJ is that much more expensine than a Dash 8 or ATR 72 assuming they both have 50 seats. Sure, the RJ burns 1000kgs/2200lbs vs 700KGS/1500LBS Per Hour but it also takes 10 percent longer on a 1 HR leg. Maybe the Boyd group could jump in and list the reasons !
Cheers/Greg
Rbgso
RE: The Economics Of RJ Vs Prop
Mon Jul 07, 2008 8:23 pm
Taking your figures, a 1 hr trip on an RJ will burn 2,200 lbs of fuel. That same trip will take 1.1 hours on a prop and burn 1,650 lbs of fuel, or 550 lbs less, despite a longer trip time. That is a 25% reduction in fuel cost per trip, which is significant.
landgreen
Mon Jul 07, 2008 8:25 pm
...ok so that's $250 bucks. Divide that by 50 seats and you get $5/seat. Gotta be more to it than that...no ?
Greg  Smile
kcrwflyer
Mon Jul 07, 2008 8:32 pm
Where did you get your fuelburn statistics?
Arrow
Mon Jul 07, 2008 8:37 pm
Quoting Landgreen (Reply 2):
Yes. Multiply that $5 a seat (your figure -- I'm not sure it's right) over several flights a day, seven days a week, over a large route system -- and it suddenly becomes a big number. Call someone at Horizon, which is well on its way to becoming an all-Q400 fleet, and ask them. I'm sure they're not getting rid of their RJs on just a whim. Also, keep in mind that the Q400 does this with 76/78 seats, not 50.
Never let the facts get in the way of a good story.
landgreen
Mon Jul 07, 2008 8:39 pm
ATR 72 off the WEB and CRJ from experience.
I'm not saying everyone is wrong, I'm only trying to fully understand it, thats all.
I think the Q400 burn is a little higher than an ATR too.
Greg
[Edited 2008-07-07 13:41:26]
[Edited 2008-07-07 13:43:31]
kcrwflyer
Mon Jul 07, 2008 8:51 pm
Quoting Landgreen (Reply 5):
Greg
Arrow has a pretty good point. 25% savings multiplied over a massive network = millions and millions of dollars. There are also other costs, like maintenance and leases, which are higher on RJ's.
legacy135
Mon Jul 07, 2008 9:09 pm
This stands correct on short hops, up to an hour or so. If flights become longer, the Turboprop becomes significantly slower and then the RJ still will be the more economic choice. Here we also have to consider, that an operator normally wants to do a number of flights per aircraft/day (in Europe we normally want to do 4 return flights a day at least) to keep it ops running. If a turboprop fleet goes on longer flights, the number of flights possible will risk to drop below economic. This even happens with a Q400, although for sure, the Bombardier can do longer flights over the ATR and still be economic, as it's simply the faster aircraft.
Legacy135  Wink
MMEPHX
Mon Jul 07, 2008 9:11 pm
I'm not sure of the weight of Jet fuel per gallon but gasoline is around 6lbs/gallon. So assuming:
6/lbs gallon
$3/gallon (roughly the price most US majors paid last quarter)
85% LF on 50 seats.
The cost per revenue passenger for fuel would be
RJ: 2200/lbs / 6 x $3 / 43 (50 * 85%) = $25.58 per person
Q400 1650/lbs / 6 X $3 / 43 = $19.19 per person
(if we figure 85% of 76 seats in Q400 the cost drops to $12.69 per person.)
Either way the Q400 looks a lot cheaper on fuel burn basis, and if an airline could replace 2 RJ runs with one full Q400 then the savings really start to add up. Over a year if each aircraft made 6 roundtrips per day carrying 43 passengers with a delta of $6.39/passenger:
$6.39 x 43 x 12 (segments) x 330 days (allow for maintenance/down days) = $1,088,089 PER AIRCRAFT more expensive per year.
Before anyone jumps up and down, these are all theoretical numbers based on my assumptions, input your own assumptions, the overall answer will remain the same. A better comparison would be a CRJ700 vs Q400, that would give a better seat to seat comparison but I'm willing to bet there is a similar cost differential, maybe not quite as wide.
MMEPHX
Mon Jul 07, 2008 9:28 pm
Quoting Legacy135 (Reply 8):
Even at 2 hours the Q400 is still very economical gas wise (4400/lbs vs 3300lbs for the equivalent distance) however, time does start to become more of a factor as we start looking at adding 12-15 minutes to a journey and that can add up over a day and may start impacting number of missions per day and crew hours etc. that add to the overall cost of operations.
One thing I didn't take into account was that a Q400 with only 43 people on board would likely need even less than 1500lbs/hr, still that only serves to widen the gap, hence does anyone know the fuel burn of a CRJ700 per hour for a side by side ~70 seater comparison?
panam330
Mon Jul 07, 2008 9:34 pm
Quoting MMEPHX (Reply 7):
Maybe not, but it's obviously wide enough for Horizon to dump their jets, as mentioned above. Plus, you factored Q400 loads at 43. Using the 85% of 76 seat figure, which you also provided, would be more appropriate. After all, CO is effectively replacing many ERJs with Q400s. Figure the additional revenue on the extra 26 seats over the ERJ-145 on top of the much lower fuel costs, and you have quite the winning combination.
CRJ900
Tue Jul 08, 2008 12:22 am
A shame scope clauses doesn't allow 76-seat CRJ700 and 90-seat CRJ900 flying. I'll bet the economics will be a lot better then...?
European carriers Air Nostrum, MyAir, Air One and AtlasJet fly 90-seat CRJ900s. I wonder if BBD has asked those carriers how economical they are in daily ops, so they can eventually use it in their marketing.
Come, fly the prevailing winds with me
Bravo1Six
Tue Jul 08, 2008 1:07 am
Quoting CRJ900 (Reply 11):
They would have a pretty good idea of what the numbers are, and it does factor into marketing and sales campaigns albeit without identifying the specific operators (i.e., X load factor over X route segment assuming X fuel price, X ticket price, X labour cost, etc.). Remember that a lot will be said about the economics of the aircraft prior to sale, so an operator is often willing to share the actual numbers in order to validate the numbers shown to them during the campaign.
[Edited 2008-07-07 18:13:58]
ttango
Tue Jul 08, 2008 1:26 am
Let's not leave out acquistion costs.
A new 50 seat XRJ runs near $20mm. A new Q is less than 10mm, right?
Used RJs are depressed and probably run close to the most expensive props. B1900s, however, can be had for close to nothing.
Bravo1Six
Tue Jul 08, 2008 1:34 am
Quoting Ttango (Reply 13):
I don't think anyone is building 50 seat RJs anymore. BBD certainly isn't.
A brand new Q is quite a bit North of 10 million.
LAXintl
Tue Jul 08, 2008 1:42 am
Try mid 20's.
Many consider the Q400 overpriced particularly when the ATR series is about 30-40% less.
(suppose it goes to explain that ATR in '07 had a record year in orders and sits on a 4 year delivery backlog!)
Flighty
Tue Jul 08, 2008 2:00 am
Quoting LAXintl (Reply 15):
Try mid 20's.
I was gonna say. A Q400 is surprisingly close to the cost of a new 737-700. They are both highly advanced (and expensive) planes to buy new.
Bravo1Six
Tue Jul 08, 2008 2:01 am
Quoting Flighty (Reply 16):
Huh? List price of a 737-700 is in the mid-50s.
AirWillie6475
Tue Jul 08, 2008 4:21 am
Will UA ever use the CRJ9 for their UAX side now that they're reducing mainline flying and adding UAX flying?
Users browsing this forum: crazyplane1234, Starlionblue and 11 guests
