smokint
MD-90 Cruising Altitude
Sun Aug 10, 2008 4:38 am
Greetings aviators,
I fly out of SLC on DL frequently, many times on the MD-90. I notice we always seem to cruise in the FL290-330 range. Is this due to this type's wing? If so, is this limiting as far as weather, turbulence avoidance, etc?
Thank you for your time,
Robert
IAHFLYR
RE: MD-90 Cruising Altitude
Sun Aug 10, 2008 3:21 pm
The cruising altitude is determined by many different items such as length of segment, winds, aircraft weight, turbulence, possible vertical restrictions ATC may put in place for certain routes from a particular city, as well as other variables which others in this forum are more versed than myself.
smokint
Sun Aug 10, 2008 5:35 pm
Thanks, IAH, but it seems to me that this aircraft type is always in the lower flight levels, e.g. :
http://flightaware.com/live/aircrafttype/MD90
I fly a lot of RJ's as well and even the anemic CRJ-100 will fly to FL350 on shorter routes.
Seems I remember something about this plane having a "relatively" small wing, could that be true?
Thanks again.
AA737-823
Mon Aug 11, 2008 12:21 pm
Quoting Smokint (Thread starter):
Lucky you.
Yes.
The MD-90-30 (which ended up being the only MD-90 series ever built) got a nose stretch over the MD-80 (heavier) and a tail stretch (heavier) and also new engines (far heavier). Not to mention more avionics (heavier), and new VSCF generators (lights, but they never work, so kind of a moot point).
So it's far heavier.
And they didn't change the wing from the MD-80 at all.
The MD-80 isn't a particularly great cruiser, to start off with... long routes with high fuel loads typically start to cruise at 29000, then climb bit by bit along the way. I myself have experience this many times, typically on AA's MD-82 and even the -83, which has uprated Pratt JT-8D-219C engines over the MD-82's -217s.
The MD-90 is a great aircraft to fly on, in my opinion, and as solid as the rest of the overbuilt Douglas line.
But its wings are its weakest point.
smokint
Mon Aug 11, 2008 4:14 pm
Thanks AA737,
I like flying it because it has the 2 + 3 seating and seems very quiet.
Is it much of a disadvantage to be stuck in the lower FL's?
FlyASAGuy2005
Tue Aug 12, 2008 11:04 am
OK so here's my question. What's the official service ceiling of the MD-90?
What gets measured gets done.
KingAir200
Wed Aug 13, 2008 1:24 pm
Quoting FlyASAGuy2005 (Reply 5):
I can't say for sure, but I think it is 37,000 feet.
PGNCS
Wed Aug 13, 2008 3:40 pm
37,000 feet.
It generally cruises a bit lower than a comparable MD-80, but has much better takeoff and climb performance up to somewhere in the 20's (exactly where depends on weight and temp).
Oykie
Fri Aug 22, 2008 11:52 am
The benefit with that small wing is that the wing loading per square feet is much higher and that makes the plane more stable in turbulence than it's competitors.
Dream no small dream; it lacks magic. Dream large, then go make that dream real - Donald Douglas
AAR90
Fri Aug 22, 2008 4:12 pm
FL410.
Quoting AA737-823 (Reply 3):
A 4% increase in maximum takeoff weight is not normally considered "far heavier." Especially when you consider the MD90 had a 50% increase in thrust.
Quoting PGNCS (Reply 7):
It generally cruises a bit lower than a comparable MD-80...
IF true, it is not due to the design of the plane or its operating economics. When comparing MD80 vs. MD90 operating the same route, the MD90 will normally operate at higher altitudes for longer periods of time --climbs faster, cruises faster, descends quicker-- but for such a comparison to be valid it must be made comparing the same route, same weather conditions and similar payloads. Bottom line is that with no artificial limits (primarily ATC or company issues) the MD90 wants to fly higher, faster and farther than any MD80.
Viscount724
Sat Aug 23, 2008 1:53 am
37,000 feet.
Quoting AAR90 (Reply 9):
FL410.
Excerpt from FAA Type Certification Data Sheet for DC-9/MD-80/MD-90/B-717:
Maximum Operating Altitude
35,000 ft. (DC-9-11 thru DC-9-51)
37,000 ft. (DC-9-81, -82, -83, -87, MD-88, MD-90-30 and 717-200)
AAR90
Sat Aug 23, 2008 2:53 am
Thanks for the update Viscount. Not sure when FAA reduced the max altitude, but when I flew it we were regularly at FL410 for the hour long intra-CA flights. Perhaps a "standardization" move ala B757 --which used to have a max altitude of FL42.5, but FAA reduced that in a "clarification" to the charts. As with the MD90... nothing changed on the plane except the official limit.
MD-90
Sat Aug 23, 2008 5:13 am
Quoting AAR90 (Reply 11):
How long did it take to climb to FL410?
smokint
Sat Aug 23, 2008 7:34 am
Hmmm, I fly the MD90 quite a bit and I've never been above FL340 in it (as a passenger, of course).
AAR90, are you saying this is just due to Delta policy?
On FlightAware, MD82's seem to have a wider range of cruising altitudes and are usually higher than at least the Delta MD-90's
AAR90
Sat Aug 23, 2008 4:20 pm
Quoting MD-90 (Reply 12):
Around 15-16 minutes. When we flew this high the cruise portion was very short... perhaps 10 minutes. Then it was a long gliding descent. If we didn't get the high altitude quickly enough, we'd get stuck underneath WN 737s and then ATC would require us to fly slow to stay behind them.  Sad
Quoting Smokint (Reply 13):
I haven't got a clue as to Delta's policies... I am AA and was flying ex-QQ MD90's.
There are a lot of reasons used in choosing a cruising altitude... fuel consumption is but one. Whenever we were trying to catch up to published scheduled times we would choose high 20's/low 30's for max ground speed (least time enroute) and there were many times I choose 16-17k just to avoid turbulence near SBA --which is almost always there on N/S coastal routes, but much less at low altitudes. The difference in fuel cost (back then) wasn't very much at all.
MD-90
Sun Aug 24, 2008 6:28 am
Quoting AAR90 (Reply 14):
Now that definitely makes sense.
PGNCS
Fri Aug 29, 2008 5:09 pm
FL410.
Not in our limitations section, nor on the FAA type certificate; it is FL 370.
[Edited 2008-08-29 10:14:19]
Users browsing this forum: a7ala, AAairplane, dlednicer, Yahoo [Bot] and 22 guests
