sampa737
How Long Can A Plane Actually Last?
Mon Aug 11, 2008 2:03 pm
With stories of metal fatigue and other problems, just how long can a plane last with continual commercial use? I ask with reference to another post regarding the DC-8s of UPS but thought it better to begin a new topic.
NWAs DC-9s have been around forever. How long could FedEx use their MD-11s, DC-10s and 727s?
NWADC9
RE: How Long Can A Plane Actually Last?
Mon Aug 11, 2008 2:09 pm
As long as it's maintained to pristine condition, until it crashes.
Doesn't EAA still have their Trimotor flying around?
I convert Jet A and 100LL into noise.
jamincan
Mon Aug 11, 2008 2:10 pm
AFAIK, DC-3s are still being used in the Arctic, but I'm not certain how old they actually are.
kappel
Mon Aug 11, 2008 2:15 pm
It depends on how much the airline is willing to spend on maintenance. An aircraft can technically fly for a very long time, like the DC9's mentioned and of course the DC3, although the DC3 does not have a pressurized cabin.
Usually, after about 25 years it is no longer economically viable to operate an aircraft, due to MX costs and most likely a replacement aircraft that has been developed that uses less fuel.
There are exceptions of course. NW has operated the DC9 for a long time, because the extra maintenance and fuel costs were offset against the fact that they are owned and paid for. However, I believe they have now reached a point that they need to be replaces (thanks to current fuel costs). Thus they are speeding up phasing them out.
L1011,733,734,73G,738,743,744,752,763,772,77W,DC855,DC863,DC930,DC950,MD11,MD88,306,319,320,321,343,346,ARJ85,CR7,E195
Dalmd88
Mon Aug 11, 2008 2:45 pm
It all comes down to how much money do you want to throw at it. If you can find the parts or better yet get approval to make the parts any airplane can fly forever. Of course after a point it might become a George Washington Axe. We had to replace the handle and the blade but it is the same axe George used to chop down the cherry tree.
YZFOO7F
Mon Aug 11, 2008 2:48 pm
Buffalo Airways of Hay River, Northwest Territories in Canada still operates many old DC-3s and C-46s.
Photo © Karl-Heinz Morawietz
Photo © Sibille Regis
The respective years of manufacture for these two birds are 1942 for the DC-3 and 1945 for the C-46.
Promise me you'll always leave the ground
N867BX
Mon Aug 11, 2008 3:02 pm
This is sort of like asking how many licks it takes to reach the center of a tootsie pop. The world may never know.
bmacleod
Mon Aug 11, 2008 4:20 pm
Depends on good maintenance and preservation (AC has a Lockheed 14 for hertigae purposes).
NWA has managed to hold on to their DC-9s for over 40+ years mainly due to extensive maintenance.
In Africa, 707s are still flying though the safety of these dinosaurs is highly questioned.
UPS still operates DC-8s though these have been re-engined with more efficient engines...
"What good are wings without the courage to fly?" - Atticus
manfredj
Mon Aug 11, 2008 4:56 pm
Weren't these old birds built with heavier materials thus increasing their useful life? I would speculate that the newer the airplane, the more composites and what not are used. Doesn't carbon fibre break down over time? (naturally)
I think the 737, MD-90 Etc are the last of the older gen building style and therefore have a longer life than its competition.
757: The last of the best
vv701
Mon Aug 11, 2008 5:53 pm
Quoting Kappel (Reply 3):
I believe that "the DC-3 does not have a pressurized cabin" is the key phrase. I do not think that national aviation authorities would allow the DC-3 to fly in their countries today if it had a pressurised cabin. I believe the dangers of metal fatigue with a pressurised aircraft are likely to limit its likely life to between 25 and 30 years depending on the cycles it has completed
prebennorholm
Mon Aug 11, 2008 6:55 pm
Quoting Sampa737 (Thread starter):
Technically any plane can last forever. You just exchange all parts which fail due to wear, corrosion, fatigue or whatever reason.
It's a question about economics, comfort and noise.
A lot of planes have "died" due to noise, not least because the EU ruled against converting old fuel guzzlers with hush-kits making them barely legal noise wise and even more fuel guzzling.
It makes little sense to spend a lot of money on maintenance of a fuel guzzler, especially if you cannot fly it to a lot of places due to noise regulation.
That doesn't harm the DC-8-7x which is the only really successful re-engined old jet airliner with modern, fairly fuel efficient and noise compliant engines.
B727 also had some success with the 727-100 converted with 3 x RR Tay, and the the 727-200 converted with 2 x JT8D-2xx plus a hush-kitted center engine. I think that ends the story of successful re-engining.
With the very high number of 737-200s produced it may puzzle me that nobody ever attempted to put a low powered JT8D-2xx under their wings. Maybe it just proved wiser economy wise to sell them to less noise sensitive places on this planet and hush-kit or scrap the rest. Or maybe such a conversion called for extensive wing stucture modifications.
MMEPHX
Mon Aug 11, 2008 7:51 pm
many factors as mentioned:
1) How many pressurization cycles has the frame endured.
2) How much time/money do you want to spend on maintenance
3) How much are you prepared to spend on fuel
4) How can you support obselete technology.
5) How well built was the frame in the first place
NW DC9's are an anomaly unlikely to be repeated in aviation. Started with a very solid, well built frame, (some may argue over engineered) NW was prepared to invest in updating/maintaining them (remember they did look in the early 90's at replacing them) and they have the staff that knows how to maintain them. The aircraft is relatively simple compared to todays current generation of computer driven aircraft.
Like most things today, aircraft seem to be designed with much more of definitive life span in mind, so that once it reaches the milestone, while it may be technical feasible to maintain or upgrade the frame, the financials make it difficult to justify.
DeC
Mon Aug 11, 2008 8:07 pm
"How Long Can A Plane Actually Last? "
As long as you maintain it.
DEC
rampart
Mon Aug 11, 2008 8:18 pm
Quoting Prebennorholm (Reply 10):
Weren't KC-135s re-engined in the same way? (IIRC, 707s were tested in the same way, but ended up not commercially available)
-Rampart
jetjeanes
Mon Aug 11, 2008 8:21 pm
In theory forever. A felow told me they can replace everything but the planes shadow if they want to. Im sure there are older planes than the dc-3 but there has to be a point where cost
i would think would be worth it
i can see for 80 miles
GeorgeJetson
Mon Aug 11, 2008 8:59 pm
Perhaps the Super DC-8s that UPS currently flies are what the DC-9s are to Northwest! Douglas (and McDonnell Douglas) built some awesome aircraft that were very durable and that stood the test of time. Although the company has been long gone, many of their aircraft are still flying, including some DC-3s from long, long ago!
Meet George Jetson
LGAUAOK
Mon Aug 11, 2008 9:58 pm
Do any domestic (US) 727 passenger planes still fly and with who? I think it would be fun to buy a ticket and go for a ride!
N867BX
Mon Aug 11, 2008 10:13 pm
Quoting LGAUAOK (Reply 16):
Champion Air flew charters but ceased operations earlier this year. I'm not aware of anyone else other than the occasional private jet.
WESTERN737800
Mon Aug 11, 2008 10:33 pm
I read when NWA retired the DC-10 that at least one of the frames had something like 130,000 hours total time. Thats pretty impressive. Good maintenance is the key to long aircraft lifespans.
Bring back Western Airlines!
flyPBA
Mon Aug 11, 2008 11:12 pm
Boeing still has their B247 that is in flyable condition
flymia
Tue Aug 12, 2008 12:25 am
Pretty long. I still see DC-3s flying in and out of MIA and OPF. I think this question will be answered when the last NW DC-9 is retired in 2025 when its replaced by a 737-3000 or A420  Wink
voar
Tue Aug 12, 2008 12:37 am
The Cessna 350 and 400 (formerly Columbia 350 and Columbia 400) are certified with an unlimited airframe life limit by the FAA, so time will tell how many of these will be flying in the future.
tonystan
Tue Aug 12, 2008 1:00 am
Airliners tend to be built to withstand a certain number of "cycles". A single cycle would be a complete take off - pressurisation - landing. Once the aircraft reaches a certain number of cycles the aircraft must go in for certain maintenance checks (like your 5k, 20000k, 30000k checks for your car) and when it is coming to the end of its life cycle it is usually retired. However if an aircraft can be maintained well enough it may continue to fly. However the older the plane gets the heavier and more costly the maintenance becomes. Before 9/11 and the Concorde crash there were plans to extend the operational life of the aircraft so that it could continue to fly for another 10-15 years.
My views are my own and do not reflect any other person or organisation.
SNAFlyboy
Tue Aug 12, 2008 2:25 am
It would appear that, while an aircraft could be maintained for an incredibly long period of time theoretically speaking, the age of the aircraft is proportional to the amount of money you're willing to throw at it! In the end, possibly even the amount of time you're willing to spend working on it...
Hmm...what do you guys think? Could we make a nice parabolic curve with a graph of Cost vs. Age and watch the costs skyrocket?
I kid, of course.
~SNAFlyboy
[Edited 2008-08-11 19:28:44]
kanban
Tue Aug 12, 2008 2:27 am
had a Boeing model 40A fly in several weeks ago built in 1925.... true it crashed and has been restored
Tue Aug 12, 2008 7:26 am
There are actually still aircraft from the 1910s flying. Mostly it's just hops along the (grass) runway on days with little wind and clear skies. But they are flown. Just very very carefully.
Tue Aug 12, 2008 8:31 am
An aircraft can last as long as it is "Economically" viable to be mantained.
regds
MEL
Dalmd88
Tue Aug 12, 2008 12:37 pm
I think the beat all is going to be the USAF with the B-52. The surviving fleet was built in 1961/1962 and currently is looking at a retirement date of 2040.
MD11Engineer
Tue Aug 12, 2008 3:55 pm
Quoting Jamincan (Reply 2):
AFAIK, the last DC-3 (C-47) were built in 1946.
Jan
Viscount724
Wed Aug 13, 2008 9:17 pm
Quoting Bmacleod (Reply 7):
Interestingly, NW has only been a DC-9 operator for slightly less than 22 years, when they merged with Republic Airlines in October 1986 and inherited Rebublic's large DC-9 fleet which originated with their various predecessors. NW never bought a new DC-9. After the Republic merger, NW bought many more used DC-9s from various sources. I think their last used DC-9 arrived as late as 1996.
The same thing applied to NW's large DC-10-30 fleet, all acquired used in the 1990s, although they previously operated their own factory-delivered DC-10-40s.
Wed Aug 13, 2008 9:50 pm
Quoting Viscount724 (Reply 29):
Their frequency of checks may not be very spaced out I guess.
regds
MEL
SEPilot
Wed Aug 13, 2008 10:49 pm
Quoting Rampart (Reply 13):
Yes, they were. They did not offer them commercially because they wanted to sell new 757's.
As to the DC-3's, after the war Douglas was concerned about the number of C-47's that were entering civilian service with unknown or uncertain histories, and they took one that they knew had been heavily used and did the same destructive tests on it that they had originally done for certification. They were absolutely astonished when the old plane's wing spars failed at a considerably higher load than the original test had. They puzzled over it for a long time, but ultimately discovered that aluminum when stressed repeatedly to a fairly low percentage of its yield actually work hardens and becomes stronger. However, when the stress is only slightly higher it starts fatiguing, which is what happens to pressurized aircraft. Therefore it is unwise to rely on this effect, but it relieved Douglas of their worry about old C-47's flying.
Users browsing this forum: Apprentice, N809FR and 1 guest
