B727LVR
FAA Ruling On Center Fuel Tanks
Thu Aug 14, 2008 7:47 pm
This may have been discussed already, but I came across a link on the FAA's ruling on center fuel tanks for certain Boeing and Airbus aircraft. In some retrospects this ruling is a lil bit late, but is for the best. Are there any words on the airlines complaining aout the costs or effectiveness of the system?
Here is the link....
http://www.airdisaster.com/news/article.php?id=29
I'm like a kid in a candy store when it comes to planes!
tdscanuck
RE: FAA Ruling On Center Fuel Tanks
Thu Aug 14, 2008 11:37 pm
Quoting B727LVR (Thread starter):
It's not just Boeing and Airbus...it's all FAA-certified aircraft with tanks that meet the profile (greater flammability exposure than an unheated aluminum wing tank).
There are, literally, thousands of pages of comments from virtually every major airline in response to the original proposed rule. They're basically universally negative, except the cargo pilots group (they want it on freighters too) and the families of TWA800 group (no surprise).
Tom.
B727LVR
Fri Aug 15, 2008 2:14 pm
Quoting Tdscanuck (Reply 1):
I'm not too surprised that the reports would be negative. What did surprise me was the fact that the freight haulers would not be required to have the system installed. I believe I would be asking for it to be installed as well if I were those pilots. I know the report said the costs were the reason for them not to be installed in the freighters, but there has to be a better one than that. Forgive me if I sound a little blunt, but that says that freight pilots aren't worth the cost to keep them safe, and I don't agree with that. Correct me if I am wrong, but I believe that the system they are refering to is similar to the one installed in the 737's currently.
jhooper
Fri Aug 15, 2008 4:01 pm
Quoting B727LVR (Reply 2):
Yea, we freightdogs are expendable  bomb
Last year 1,944 New Yorkers saw something and said something.
tdscanuck
Sat Aug 16, 2008 2:04 am
Actually, there doesn't. The cost/benefit calculation used by the FAA for rulemaking is pretty clear and the flammability reduction just barely squeaks over the line (even from the very optimistic FAA stance) for passenger operations...the likely number of deaths in freighter operations is far far too low to meet the cost/benefit hurdle.
To be equally blunt, that's how the laws are made. Suppose the cost to keep them safe was $100 billion per airplane...obviously, that's too high and nobody would do it. Suppose it was $0 per airplane...then everyone would do it. People can (and do) fight a lot about where the line is but you can't deny that the line exists.
Sort of. The system that Boeing will use is very similar to the existing one. However, the FAA rule doesn't actually specify what system you have to use, just how effective the system (whatever you use) has to be. OEM's are free to use whatever system they like to meet the performance requirements of the rule.
Tom.
XT6Wagon
Tue Aug 19, 2008 8:46 am
Quoting Jhooper (Reply 3):
Yup. Currently 2 people is seen as not very worth getting worked up over.
200? Gets a bit more attention.
That said, I'd suspect that the FAA will look at it more/again when
A. passenger adoption brings the real cost to the table for review and if its cheap enough....
and/or
B. a freighter has an "issue" with this problem.
Sad to say though freighters just don't kill enough people to make anyone care much about them outside of the potential victums which again isn't much at all compared to the millions of passengers, stockholders, etc.
Users browsing this forum: BreninTW, haydenschool and 1 guest
