kl5147
Small Window/hole At Martinair 767
Fri Aug 22, 2008 5:02 pm
This item has maybe discussed before, but I did not find any results in searching the forums.
After seeing this pic of the Martinair retrojet (B767 PH-MCL) I noticed a small window (hole) just left of the front maindeck door on the right side of the aircraft. (half in the read cheat-line).
A search in the database showed me that more boeing 767's they have a similar window/hole too.
Photo © Andreas Fietz
Photo © Alejandro Ruiz
Can anybody tell me what the purpose of this window/hole is?
Thankz
Bart
"The world is just a click away!"
avt007
RE: Small Window/hole At Martinair 767
Fri Aug 22, 2008 5:44 pm
I am going to make an educated guess and say it's a light, probably an emergency light for the slide.
kl5147
Fri Aug 22, 2008 7:10 pm
Quoting Avt007 (Reply 1):
it's a light
I guess you are right.
I have noticed it on these Delta and Britsh Airways 767's on the left hand side too.
Photo © Patric Borg
Photo © Paul Markman
Mender
Fri Aug 22, 2008 10:38 pm
It is indeed the emergency escape slide illumination light. It is activated at the same time as the cabin interior emergency lights, ie,. when a/c power is lost. You'll also find a similar light for the overwing escape slide (if the aircraft is fitted with overwing exits, not all 767's have them)
If you look carefully at this photo http://www.airliners.net/photo/Air-I...C_&prev_id=1370871&next_id=1369166
Below the second window aft of the overwing exit you can see the overwing slide light. I know the photo is taken from a long distance but it is comparable in size to the one by the forward exit.
You can also see door slide lights on the fuselage of 757's
Sat Aug 23, 2008 9:25 am
Emergency Evacuation area illumination lights.They normally cover the Area of the escape slide to provide Battery electrical supply,as in an emergency at night,one would need lighting to exit on the slides & evacuate.
regds
MEL
kl5147
Sat Aug 23, 2008 9:45 am
Thank you all. It seems my question is answered.  bigthumbsup
Bart
Users browsing this forum: 817Dreamliiner, chornedsnorkack, Stitch and 1 guest
