falstaff
Where Are The Six Pieces Of Wood In A 727?
Thu Aug 28, 2008 11:27 pm
I was reading an article about flying the 727 in the new issue of Airways and there was a mention of there being six pieces of wood in a 727. Where are the pieces of wood and what are they used for? Do other modern jetliners have any wooden parts?
My mug slaketh over on Falstaff N503
tdscanuck
RE: Where Are The Six Pieces Of Wood In A 727?
Thu Aug 28, 2008 11:47 pm
Quoting Falstaff (Thread starter):
I have no idea, but I'd strongly suspect there's at least some balsa-core composite somewhere in there.
Tom.
DeltaGuy
Thu Aug 28, 2008 11:59 pm
Flight Engineer's table! Big grin
DeltaGuy
wedgetail737
Fri Aug 29, 2008 12:04 am
Sometimes there would be plywood in the cargo bay.
Some of the older floor panels were made from two sheets of aluminum, with a balsa wood core.
rampkontroler
Fri Aug 29, 2008 12:10 am
The article reads:
"There is no better way to learn systems and procedures than instructing. But it's important to remember that just because you know the thread diameter and metallurgy of the four bolts that secure the engines to the fuselage, your students don't. Jokingly inquiring about the only letter that doesn't appear on a factory-stamped engineer's panel, or how many pieces of wood there are on a 727 is fine. But we've all suffered through instructors who lecture simply to hear themselves speak."
I assume that's the wood reference you were talking about, and I would like to know the answer as well. All I can picture is maybe a dowel inside of some tubing somewhere, if indeed he wasn't just joking!
cal764
Fri Aug 29, 2008 12:11 am
Quoting DeltaGuy (Reply 2):
Ya, but a FE would object to anything other than Oak or anything else about 10X heavier than balsa....Would add the smallest amount of glamor, no?
1. Fly to Win 2. Fund Future 3. Reliability 4. Work Together CO: Work Hard, Fly Right...
Acey559
Fri Aug 29, 2008 1:17 am
The bathroom floors on DL planes (including the E170s, I believe) have wood floors!  Smile
Viscount724
Fri Aug 29, 2008 1:21 am
Quoting Acey559 (Reply 6):
I doubt it. Possibly wood-grain vinyl floor covering. I've seen that on several aircraft.
Acey559
Fri Aug 29, 2008 1:39 am
Quoting Viscount724 (Reply 7):
Right, I was being a little facetious.  Wink
KL808
Fri Aug 29, 2008 1:58 am
If im not mistaken the part under engine number 2 where the aircraft can skid on when it over rotates is made out of wood. I think I read this somewhere that even the original B747's had these.
Drew
AMS-LAX-MNL
aogdesk
Fri Aug 29, 2008 3:20 am
Perhaps its between the legs of the captain? (the control column.....get your mind outta the gutter!!!)  Wink
The compressible tail skid on a B727 is definitely NOT made out of wood.....at least all of them that I'm not familiar with.
critter
Fri Aug 29, 2008 3:44 am
If I am not mistaken......I believe that there are several phenolic wood cable guides in the main gear wheel wells. These guides keep the control cables from rubbing and fraying on other metal structures.
critter
roseflyer
Fri Aug 29, 2008 3:53 am
Quoting Aogdesk (Reply 10):
Nope, that's a magnesium casting.
spacecadet
Fri Aug 29, 2008 4:00 am
Come on, everybody knows it's the engine pylons  Smile
Yep, solid basswood!
acidradio
Crew
Fri Aug 29, 2008 4:11 am
Does the crash axe in the cockpit have a wooden handle? There's one of the 6!
Ich haben zwei Platzspielen und ein Microphone
777den
Fri Aug 29, 2008 4:13 am
nose gear door core
wing fence core x2
FE table top
main gear inspection port covers in cabin x2
 Smile
aogdesk
Quoting RoseFlyer (Reply 12):
Nope.....that was pure sarcasm.... Wink
I was going to go with the phenolic pulleys and fairleads too........and then I remembered that those sturdy JT8 fan blades are made of the finest teak.........seriously.  Wink
Ken777
Fri Aug 29, 2008 4:17 am
Quoting Acidradio (Reply 14):
And maybe the inserts that hold the bathroom tissue roll in place.  Smile
777den
Fri Aug 29, 2008 4:18 am
crash axe is metal handled
aaa
777den
Fri Aug 29, 2008 4:19 am
the list i posted is the common answer, the nose gear doors and wing fences are balse wood cored the other 3 are plywood
crownvic
Fri Aug 29, 2008 4:41 am
While not on the 727, many years back, I was around a 707-321 that was being broken up in ACY and I found it interesting that on this particular a/c, the entire ventral fin on the aft belly fuselage was mostly made of wood...
yegger
Fri Aug 29, 2008 5:15 am
There was a wooden piece that was used to lock the handle of rear cabin door (from the inside) to the rear stairs. This was used so that it was difficult to enter a parked/out of service/overnighting B727 aircraft (you couldn't simply walk up the stairs and go in) from the ground without using a lift truck or other vehicle to access the main doors.
727forever
Fri Aug 29, 2008 6:03 am
Quoting KL808 (Reply 9):
Nope sorry. It was definately metal.
On the door to the fuel dump panel there are two little wooden strips on the inside of the door that when slammed closed push all of the dump switches closed. I can also confirm that the Engineers table top was wood.
That's 3.
727forever
727forever
frmrCapCadet
Fri Aug 29, 2008 6:26 am
I have seen parts made for a modern fighter made from wood - it appeared to be a spacer to go between several other parts. I am totally guessing as to it function.
Fri Aug 29, 2008 6:35 am
Where was this Article printed.
Its tough to believe,considering the Fire resistant capabilities needed for Commercial Airliners.
Only thing could be the Six Chocks for the Three Landing gears if carried on board  Smile
regds
MEL
Jet-lagged
Fri Aug 29, 2008 7:36 am
The wood paneling?
hypersonic
Fri Aug 29, 2008 7:40 am
Are you implying that there might be Captains out there who have 'got wood' whilst flying?
LOL (mind definately in rude mode !!)
nema
Fri Aug 29, 2008 8:45 am
Yep, that was my first thought, i remember early 747 documentaries saying that wooden planks were fitted under the tail area in case of tail end drag on the runway when taking off steeply. I also assumed it wasnt just for the 747. Having said that i often looked for something like this and could never see anything suggesting that there was wooden planks built in there.
Around 1990 ish, i was sat in the rear section of a Pan Am 747 taking off from Miami and we seemed very very late gaing airspeed and rotating, i heard a rather unusual scraping sound at that rotating point and wondered if we were on the 'planks' so to speak. It was odd that only just after leaving the ground we were immediately above the lighting posts at the end of the runway.
There isnt really a dark side to the moon, as a matter of fact its all dark!
falstaff
Fri Aug 29, 2008 1:15 pm
Quoting HAWK21M (Reply 24):
The USA,
The author had flown as FE, FO, and captain, on Orion, RC, and NW 727s.
Quoting Rampkontroler (Reply 4):
According to the article the answer to that is "J".
Moose135
Fri Aug 29, 2008 2:51 pm
Quoting NEMA (Reply 27):
I wouldn't be surprised if they attached wooden skid plates during test flights, especially for something like minimum unstick speed tests.
Fri Aug 29, 2008 3:13 pm
Quoting Falstaff (Reply 28):
The USA,
Didn't the Author mention the location.Is there any way the autor could be contacted?
regds
MEL.
SlamClick
Fri Aug 29, 2008 3:23 pm
well...
Quoting Moose135 (Reply 29):
IF it was actually wood that was used it was only for the VMU tests. I've seen film of Boeing products actually having their tail dragged on the runway by flight test crew. Something disposable was likely used and that material never showed up in the production models.
skid
Quoting 727forever (Reply 22):
Been a while since I've been around the 727 but it seems like there was a replaceable wear plate at the lower end of the tail skid but that it might have been phenolic.
The actual compression member up inside the skid is a roll of "cardboard" wrapped very tightly and laquered into a single solid piece. It is about the size and shape of a roll of paper towels and stands on end. If the skid strikes the ground it compresses this material endwise. I've seen one shortened about half an inch by such contact but the event did many thousands of dollars in structural damage where the skid is mounted. They are not foolproof. I was told the one I was looking at came from a -100 which must be pretty hard to get a tailstrike on.
Anyway, we seem to have a winner - as usual being ignored by one and all:
Quoting 777DEN (Reply 15):
nose gear door core
wing fence core x2
FE table top
falstaff
Fri Aug 29, 2008 9:40 pm
Quoting HAWK21M (Reply 30):
regds
He mentioned various locations while flying 727s for RC and NW in the USA.
474218
Fri Aug 29, 2008 11:09 pm
Wood floorboards would never pass the required "burn thorough test". Will maybe if they were wet with ...
EMBQA
Fri Aug 29, 2008 11:35 pm
Not wood...just a poly laminate look a like.
tdscanuck
Sat Aug 30, 2008 2:13 am
They were a lot laxer on the 727 than they are now. Also, things outside the pressurized shell and contained (like landing gear door cores) aren't really an issue.
As far as I know, that's just for flight test.
I saw a documentary once that said it's a really thick oak plank.
Tom.
Sat Aug 30, 2008 9:36 am
Quoting Falstaff (Reply 32):
Was an Email/Ctc printed on the Article?
Quoting EMBQA (Reply 34):
I too found it surprising if wood was used on the floor.
regds
MEL
fsnuffer
Sat Aug 30, 2008 2:05 pm
The pilot and copilot's golf clubs in the hold
[Edited 2008-08-30 07:05:51]
atlturbine
Sun Aug 31, 2008 11:35 pm
The only thing I know for sure is the main landing gear down lock inspection hole cover in the mid cabin area. I do not recall what kind of wood it was made from.
To the World you might be One Person but to One Person you might be the World
Mon Sep 01, 2008 7:14 am
Quoting Atlturbine (Reply 38):
Thats true on the B737.
regds
MEL
Mon Sep 01, 2008 9:26 am
Quoting Fsnuffer (Reply 37):
Yeah but even woods are made of metal or composite nowadays.  Wink
Triebwerk
Wed Sep 03, 2008 2:55 am
What about the 6 pencils in the cockpit? They're a wood and graphite composite.  Smile
twal1011727
Thu Sep 04, 2008 10:26 pm
I was shown the 2 pieces of wood on a Delta MD88. They were on the control columns were they go thru the cockpit floor. It is approximate horseshoe shaped and tapered near the front and approx 3/4 to 1 inch thick on the back. I wouldn't be suprised if the B727 had it there too.
KD
mayor
Fri Sep 12, 2008 2:25 pm
Quoting Yegger (Reply 21):
We had that, too, in SLC but we made it ourselves and it definitely wasn't an actual part of the air craft and wasn't supposed to stay on board, although it did get left on there, accidently, sometimes. We finally attached a "remove before flight" flag to it and that seemed to correct the problem.
[Edited 2008-09-12 07:46:56]
"A committee is a group of the unprepared, appointed by the unwilling, to do the unnecessary"----Fred Allen
EcuadorianMD11
Mon May 25, 2009 8:02 am
Tiger Woods + family on a jaunt?
Presumably travelling business class...........
Ecuadorian MD11
A lot of people need to be offended on a regular basis I always felt, and I�´m the very boy to do it! - Billy Connolly
CosmicCruiser
Mon May 25, 2009 8:07 am
I believe there was a piece of wood on the GEN reset panel (if I even remember that correctly) on the aft CB panel for the F/E. I remember this question from school but all I remember is the table top, the nose gr. door and that panel.
JETPILOT
Mon May 25, 2009 12:06 pm
The nose wheel brake consists of 2 blocks of 4X4 wood blocks in the wheel well ceiling. When the gear is retracted the tires rub against the wood blocks slowing the tire.
Can't believe no one mentioned them!
zanl188
Mon May 25, 2009 3:18 pm
Quoting SlamClick (Reply 31):
I've had a book since I was a kid called "747 Story of the Boeing SUPER JET" copyright 1970
Latter half of the book describes testing and early service entry.
Pg 205 talks about the VMU tests: "On its underbelly in the extreme tail is a ten foot long maple beam - like a keel on a boat - with a steel plate on the underside"
On the same page there's a pix of Jack Waddell inspecting the steel plate. I'd scan and include but I don't have my new scanner working....
On the next page an observer describes the VMU test thus: "When she rocked back on her tail, it looked like the runway was on fire. A thousand Fourth of July sparklers touched off at once!". Sounds like steel to me...
TimePilot
Mon Jun 15, 2009 2:17 am
Does the 727 use wood-burning engines? 6 pieces would be hard for international flights though, I think.
What about in the galley, for special smoked meats or something?
Sun Jun 21, 2009 8:45 am
Quoting JETPILOT (Reply 46):
Was the brake snubbing pads of wood.However I thought the B727 had NLG brakes.
regds
MEL.
Users browsing this forum: Flow2706, TNST3B and 3 guests
