ALexeu
Hydro-systems On Aircraft
Sun Sep 07, 2008 2:08 pm
Hi,
I have to do an aviation college project about hydro-systems on aircraft (which includes systems not only related to hydraulics). As Google didn't give me any specific info, I would like to know if you have any info about general use of hydro-systems on aircraft. Links or any info is welcomed.
Thanks in advance,
Alex
roseflyer
RE: Hydro-systems On Aircraft
Sun Sep 07, 2008 3:05 pm
What are you referring to as a Hydro-System? If you are asking anything about hydraulics, I can help you out since I'm an engineer who works on designing and testing hydraulic systems for the 737.
MD11Engineer
Sun Sep 07, 2008 3:45 pm
Do you mean ATA chapter 38, which is water / waste (potable water systems and toilets)?
Jan
fr8mech
Sun Sep 07, 2008 4:48 pm
Look at the fuel systems on high bypass turbofans. Fuel is used to move actuators and valves.
Sun Sep 07, 2008 6:22 pm
Are you referring to Hydraulic systems ie ATA Chapter 29?
This is a good link for the B737.
regds
MEL
wingscrubber
Sun Sep 07, 2008 7:23 pm
If by hydro you mean liquid, then that would encompass drinking water systems, sewage systems, liquid chemical anti-ice systems, oil lubrication systems and as already mentioned, fuel systems.
Obviously the biggest and most complex hydro-system is the hydraulics, which is generally responsible for flight controls and landing gear retraction/extension/steering and braking.
Resident TechOps Troll
ALexeu
Sun Sep 07, 2008 10:41 pm
Thanks for replies, but the problem is that I am not sure what exactly to look for. As you all said, apart from hydraulics the only systems for a/c are water/sewege etc. I will have more info about it tomorrow hopefully.
Quoting HAWK21M (Reply 4):
That's were I tried to find at the first place, but I didn't find anything (apart from hydraulics). My second project is related to pneumatics, but I already have information's about it.Thanks anyway.
Regards, Alex
tdscanuck
Sun Sep 07, 2008 11:24 pm
Quoting AlexEU (Reply 6):
Go here:
http://www.smartcockpit.com/
And go to My Aircraft > Aircraft of your choice > Systems
Tom.
ALexeu
Mon Sep 08, 2008 8:32 pm
What is the difference between pneumatic and hydraulic system on aircraft?
Quoting Tdscanuck (Reply 7):
Go here:
Great link ! I didn't know it was free
Think of the brighter side!
That made my day! Welcome to my r/u list.
Regards, Alex
tdscanuck
Mon Sep 08, 2008 9:11 pm
Quoting AlexEU (Reply 8):
Pneumatic = pressurized air
Hydraulic = pressurized liquid (typically Skydrol or fuel)
I'm not quite sure how it is free, but it's great that it exists...I'm sure it drives the OEM's nuts.
Tom.
Tue Sep 09, 2008 1:11 am
I'm Honoured.
Check this one too.....
http://www.sjap.nl/
regds
MEL
ALexeu
Tue Sep 09, 2008 9:01 am
Can somebody explain the diagram on the bottom of this page
http://www.b737.org.uk/pneumatics.htm
Quoting HAWK21M (Reply 10):
I'm Honoured.
http://www.sjap.nl/
Also a good technical web...
Alex
Tristarsteve
TristarSteve
Tue Sep 09, 2008 10:18 am
Quoting AlexEU (Reply 11):
Yes , but it would take a few pages of type. It is the complete air system on a B737 from engine to cabin. Never seen it on one diagram before.
On a type course for engineers, this diagram would take about 4 days to explain .
Reminds me of the Licence exam I did for the B732 for the CAA, the examiner would lay out the disgram on the table and ask you to explain it. After 10 mins he would say, Ok now for the landing gear and you would know you had passed that part.
[Edited 2008-09-09 03:25:38]
Tue Sep 09, 2008 12:39 pm
As Mentioned that would take a lot of typing.But if you could send accross an Email address.I'll try & send accross the Description details.
regds
MEL
ALexeu
Tue Sep 09, 2008 6:36 pm
Quoting TristarSteve (Reply 12):
Quoting HAWK21M (Reply 13):
I am just interested in the simple explanation! No need to describe everything...Thanks anyway.
Alex
fr8mech
Tue Sep 09, 2008 10:45 pm
Quoting AlexEU (Reply 14):
Fold the diagram in half. The sides are virtually identical from left to right. The lower part of the diagram represents the engine (the source of pneumatic power). The upper part of the diagram represents the pack or air conditioning system. The mix manifold is the last step before the conditioned air enters the cabin proper.
If you want details of specific components, just ask about them by name.
ALexeu
Wed Sep 10, 2008 8:59 am
Quoting Fr8Mech (Reply 15):
Thanks !
What's the difference between red and blue valve? and what is ''le slats''
Regards, Alex
fr8mech
Wed Sep 10, 2008 12:55 pm
Quoting AlexEU (Reply 16):
I don't see any valves of different color, but the red ducts normally denote 'hot' air and the blue 'cold' or conditioned air. The blue duct on the engine is fan air used to cool, via the heat exchanger or precooler, the bleed air.
LE Slats refers to the leading edge slats. I'll make a quick assumption, I don't have any B737 background (except for having worked on just about all Boeing jet liners), and say this is the duct for leading edge anti-ice.
Wed Sep 10, 2008 1:17 pm
http://www.b737.org.uk/images/schemeaircon300small.gif
The Red lines denote Hot/Warm air,The Blue lines indicate Cool/conditioned air.
If you are talking about the amber "cowl anti Ice" Lt & "Cowl valve open" Lt,then the former denotes If icing has occured in the Nose cowl & the latter is indicating that the Cowl A/I valve is open.
LE Slats....Indicates the line passing between the LE Slats & LE of the Wing to perform WTAI [Wing Thermal Anti Icing].
regds
MEL
ALexeu
Wed Sep 10, 2008 8:58 pm
Quoting Fr8mech (Reply 17):
Quoting HAWK21M (Reply 18):
Thanks for the info.
However, it was too late (I should have asked earlier), and I got lower mark because I didn't use that graphic in my project! At least I got to learn more about aviation pneumatics (which I never though of before).
Regards, Alex
Users browsing this forum: Mr AirNZ and 2 guests
