Speedbird741
A340 Landing Procedures
Tue Sep 09, 2008 6:43 am
I was wondering why in the initial a342/3's , when landing their pop up spoilers only came up after the nose gear touched the ground and only after this the reversers could be pulled ?
And also why do sometimes pilots, and this I've seen on all 340's except for the 500, only pull the inboard reversers and in full reverse instead of pulling all 4 reversers to a reduced trust for example ?
http://www.airliners.net/photo/Lufth...C_&prev_id=0905962&next_id=0559920
http://www.airliners.net/photo/Airbu...C_&prev_id=0524587&next_id=0324997
Speedbird741
Boa noite Faro, Air Portugal 257 climbing flight level 340
Nicoeddf
RE: A340 Landing Procedures
Tue Sep 09, 2008 7:31 am
My guess would be to avoid dirt ingestion due to the outer engines hanging close to the runway side edges.
Its the same reason, the 380 has no outbord reverser at all.
Speedbird741
Tue Sep 09, 2008 2:25 pm
Quoting NicoEDDF (Reply 1):
Well i thought of that, but then again, i've never seen a 747 do it nor any other 4 engine....
Airbus_A340
Tue Sep 09, 2008 3:48 pm
Hey there,
On landing, with the main landing gear touched down, the spoilers will deploy if thrust levers are idle or is reverse is selected on 2 engines (one each side).
There are circumstances when just one main landing has touched down, this will still deploy spoilers, but only partially, reverse has to be selected on 2 engines (one either side again). The theory is that this will slightly decrease the lift to bring the other main landing gear to the ground more gently than by deploying full spoilers. Normal spoiler deployment sequence continues when both gear is down.
As for deploying reverse thrust straight from the A340 manual:
"Deployment requires :
— one FADEC channel operating with its associated throttle reverse signal
— aircraft on ground from at least one LGCIU
— TLA (thrust lever angle) reverse signal from PRIM 1 (FLT CTL PRIMARY COMPUTER 1) or associated PRIM
— switch reverse signal from associated EIU
Before the transit completion of the blocker doors, the FADEC sets reverse idle thrust."
As for deploying just the inboard reversers, when pulling the levers, I have personally found the inboard to immediately deploy, the outer ones follow almost immediately after, must be something to do with the interlock mechanism. Another note/possibility is that I have often flown with an outboard thrust reverser MEL..so the opposite outboard thrust reverser is interlocked, so it cannot supply reverse thrust, only idle reverse.
In Cathay, our procedures are to pull the thrust reverser levers immediately after touchdown.
Hope that helps
[Edited 2008-09-09 08:52:19]
People. They make an airline. www.cathaypacific.com
Speedbird741
Tue Sep 09, 2008 4:20 pm
Quoting Airbus_A340 (Reply 3):
Hope that helps
All said dude....thanks a lot  Wink
Users browsing this forum: NPeterman, ucdtim17 and 14 guests
