747400sp
What If There Was A Trijet Built Off The 777 Tec?
Sat Sep 13, 2008 1:33 am
I was thinking earlier, about how Airbus got started. Airbus got it's name, because of what the A300 was design to do, which was to do the job L1011's and DC10's was design to do. The US airbuses (L1011, DC10) was originally twin jets but was change to trijets thank to a request from TWA and UA, but Airbus Kept there airbus a twin jet.
I was wondering, if there was an aircraft company that designed a band new plane around the same time the T-7 was design, but it was a trijet using the same engines as T-7 has, want do you think would become of that airliner?
jcchristie
RE: What If There Was A Trijet Built Off The 777 T
Sat Sep 13, 2008 7:54 am
I would think it would fail. Why have 3 engines when you do just fine with 2?
andz
Sat Sep 13, 2008 8:09 am
Imagine a GE-90 in the tail, that would be outrageous!
acNDTTech
Sat Sep 13, 2008 4:51 pm
Quoting Jcchristie (Reply 1):
Why have 4 when you could have 2 or 3?
DfwRevolution
Sat Sep 13, 2008 6:11 pm
Quoting AcNDTTech (Reply 3):
Four engines is preferable over three. Tail-mounted engines bring a host of technical issues that make them more complicated than just hanging 4 smaller engines from the wing.
RussianJet
Sat Sep 13, 2008 7:58 pm
Man, it would look cool though.
✈ Every strike of the hammer is a blow against the enemy. ✈
columba
Sun Sep 14, 2008 7:34 am
Quoting 747400sp (Thread starter):
The same engines would have been difficult as the fan diameter of the 777 engines are too big for a third engine, there was a trijet that competed with the early 777s the MD 11.
It will forever be a McDonnell Douglas MD 80 , Boeing MD 80 sounds so wrong
HT
Sun Sep 14, 2008 4:21 pm
Quoting Andz (Reply 2):
It also would add an enourmous weight to the tail of the a/c.
Isn't it the case that a MD-11F (and the DC-10/MD-10F's) need to be loaded / unloaded carefully in order to keep the Center of Gravity within the triangle made up by the landing gear (i.e. to prevent that the a/c's nose ponts high in the air while it rests on its aft section) ?
-HT
wilco737
Mon Sep 15, 2008 5:36 am
Quoting HT (Reply 7):
Yes, you need to be careful. And on ferry flights you need a lot of ballast fuel to keep her in trim as well and make her flyable.
3 engines made sense when we had only a small amount of ETOPS, where it was not possible to fly across the north atlantic with only 2 engines. McDonnell had the idea to put the 3rd engine on the tail to fly across the pond. Nowadays with such high ETOPS, you don't need it anymore. Although I remember a thread not too long ago where Airbus is in plans (or thinking) about an aircraft with 3 engines.
WILCO737 (MD11F)
 airplane
RE: What If There Was A Trijet Built Off The 777 Tec?
Mon Sep 15, 2008 9:49 am
WILCO737 has it right. The triplet came about from a particular set of requirements at a particular time. Nowadays you'd just stay at 2 (777, 350) or go to 4 (380).
This is true. But there are plenty of pics in the database of 747s sitting on their tails as well.
Trijets (and tail engined aircraft) have the wings and gear further back, thus solving some of the weight distribution issue.
Quoting WILCO737 (Reply 8):
The one with the split tail. Yeah that was cool.
Alessandro
Mon Sep 15, 2008 3:57 pm
Hmm, I´m not sure that the DC-10 and Tristar was meant as twin engined first. Later the company
worked on a Bistar, but it never made it.
Alessandro
Mon Sep 15, 2008 4:02 pm
-HT
Well, if an imaginary 3 engined aircraft would´ve been made like that, I would´ve suggested a
supportwheel like the Il-62 got, for parking the aircraft.
Mon Sep 15, 2008 11:48 pm
Quoting Alessandro (Reply 10):
As you say it was the other way round. They were triplets first.
IIRC there was a LGA requirement that necessitated certain take-off performance with certain range. The only way to do that with the engines at the time was to install three.
tdscanuck
Tue Sep 16, 2008 6:05 am
Well, it would either be *massively* overpowered or need a takeoff weight greater than an A380.
With three 777 engines, you're talking an engine-out thrust of 230000 lbs. That's comparable to what an A380 has, and far more than a 777 or 747. So you're either packing around a *lot* more engine than you need (with related weight and fuel burn penalties) or you're talking about a very very big aircraft, so big that there's probably not enough market to justify it.
Tom.
ovrpowrd727
Fri Sep 19, 2008 3:57 am
im sure the trents would look funny too, it sux that in today's day you wouldn't see it, i have spoken to a few MD-11 pilots, specifically RG and AY and the airframe is pilot friendly... they both agreed that the power and range are not sacrificed because of load factors to a degree, the MD-11 is actually very capable, wasn't there a plan to stretch the Md-11 once more but it was scrapped because Mcdonnell Douglas went under?? aside from maintenance a tri-jet can be very durable
Fri Sep 19, 2008 4:06 am
Quoting Ovrpowrd727 (Reply 14):
There was indeed:
http://rosboch.net/aviationmedia/Proposed_MD-XX_MD-12_trijet.jpg
I should be noted that the tail engine mounting is a very costly engineering challenge. Bigger fans make the cost grow very fast.
wn700driver
Fri Sep 19, 2008 7:50 am
Quite relevant. A bit off topic, but along those lines, I have often wondered why the 747-8 is remaining a quad. I realize its a bit heavier than a 77W, but is it so much so that four smaller units are better than what the two 77W or 77L packs? I guess it makes more difference with the cargo ops, but I can't see very many segments out there where the extra few percent of power or 200-300km of range really makes that much difference.
Of course for Boeing to do that they would need a new wing, but weren't they doing that anyway? Just something I've been thinking about here & there. . .
Base not your happiness on the deeds of others, for what is given can be taken away. No Hope = No Fear
Fri Sep 19, 2008 9:57 am
Quoting WN700Driver (Reply 16):
The MTOW of the 747-8 will be 970,000 lb. The MTOW of the 777-300ER is 775,000 lb. So it's not a few percent extra.
The 747-8 will be powered by the GEnx-2B67 at 66500 lb/f of thrust. That's 199500 with an engine out. To make it a twin you'd need 200k thrust engines (200k with an engine out). That's about 75% more power than the current most powerful engine.
2H4
Fri Sep 19, 2008 1:06 pm
They'd need all new systems, too, would they not? Hydraulic, pneumatic, electrical, fire protection....all of it would have to be reengineered and rerouted to the new configuration.
Then, the certification would require full flight test in every flight regime, whereas (I assume) the 747-8 can get away with significantly less testing, as the airframe and aerodynamic changes are comparatively minimal.
2H4
Intentionally Left Blank
ovrpowrd727
Fri Sep 19, 2008 1:08 pm
why can't the freighters pick it up?? they hardly use the planes already in service to their full potential anyway there's no call for it... freight revenue and pax revenue are two different things completely, c'mon when are you going to see MD-11's doing domestic flight unless its freight
Users browsing this forum: RushmoreAir and 1 guest
