Tires-Electrostatically Grounded Or Not
Sat Sep 27, 2008 8:47 am
Can one tell by looking at a tire if the airplane is normally electrostatically grounded through
conductive tires or not?
regds
MEL...
tdscanuck
RE: Tires-Electrostatically Grounded Or Not
Sat Sep 27, 2008 7:40 pm
Quoting HAWK21M (Thread starter):
Can one tell by looking at a tire if the airplane is normally electrostatically grounded through conductive tires or not?
Even if you had conductive tires, I'm not sure you could ever assume the airplane is grounded because you don't know the conductivity or grounding of the surface the airplane is sitting on.
Tom.
Sun Sep 28, 2008 6:47 am
Quoting Tdscanuck (Reply 1):
Thats true.But what I'm indicating is if there is any print etc on the Tire exterior stating that that particular tire is a conductive one.
regds
MEL
cal764
Fri Oct 03, 2008 5:38 pm
Quoting HAWK21M (Reply 2):
IIRC Blackbird tires contain Aluminum in the rubber...would that constitute conductivity?
1. Fly to Win 2. Fund Future 3. Reliability 4. Work Together CO: Work Hard, Fly Right...
nomadd22
Sat Oct 04, 2008 2:31 am
Some auto tires created problems by being such great insulators that large static charges were building up on the vehicle, but most tires aren't that bad. I'd imagine that part of the specs for aircraft tires would be to have a tiny bit of conductivity so they'll discharge the plane to ground within a few seconds.
Concrete and asphalt don't conduct very well, but they do conduct, and you don't have to pass much current to discharge static buildup. You're not trying to protect aginst a lightning strike.
Just don't do like the occasional moron who puts the fuel truck ground lead on something that's obviously non conductive.
Anon
474218
Sat Oct 04, 2008 3:22 am
I don't how you could tell by looking. However, tires are naturally conductive.
See page 16 of the following:
http://www.goodyearaviation.com/img/pdf/aircraftmanual.pdf
Sat Oct 04, 2008 8:26 am
Quoting 474218 (Reply 5):
Looking as in the sense of print present on tire exterior indicating same.
regds
MEL
avioniker
Sun Oct 05, 2008 4:29 pm
If you want to look and tell if it's conductive or not you need only note the color.
If it's black that indicates the use of carbon black in the reinforcement structure of the basic formula. Carbon black is highly conductive.
Latex rubber is neutral white before the additives are blended in.
 Smile
Tue Oct 07, 2008 8:20 am
Quoting Avioniker (Reply 7):
On line I don't think the colour would differ.hence Tire print aka S/N,loading/Ply rating/Retread status etc on the circumfrence.
regds
MEL
Users browsing this forum: Coronado990, Yahoo [Bot] and 2 guests
