FlyMKG
LORAN-C Approaches
Tue Oct 07, 2008 12:53 am
Does anybody know if there are any current LORAN approaches in the US? I'd bet there hasn't been any in about 15 years but what do I know. Also are there any LORAN approaches in use anywhere else in the world and if so could a LORAN plate be posted? Finally does anybody know when the AZO LORAN approach was decommishoned? Thanks.
FlyMKG
Essential Power, Operating Generator.
ArmitageShanks
RE: LORAN-C Approaches
Tue Oct 07, 2008 2:31 am
I never knew LORAN could be used for approaches. I remember using it on cross countries in the late 90's but the closest accuracy we had was a tenth of a mile indicated. I thought it was so great until I took my gps along.
AAH732UAL
Tue Oct 07, 2008 2:50 am
I doubt it...... heck most of the VOR/DME RNAV approaches have either been converted to GPS, RNAV(GPS), or have been decommissioned all together and that stuff is sorta recent.
IIRC LORAN was going to be decommissioned but I guess the FAA has decided to keep it just in case SA (Selective Availability) gets put back on GPS by the military. Though with all the new RNAV(GPS) and (RNP) approaches, all the money invested into WAAS and LAAS, and a ton planes having GPS of some sort, I doubt that SA will be seen again. Plus if that is the case, then we could use EGNOS, MSAS, CWAAS, etc etc.
I also have NOT found any design criteria in TERPS or PAN OPS for LORAN approaches. So I don't think there is any anywhere in the world.
[Edited 2008-10-06 20:02:09]
DME/DME RNP0.3 NA -Escalators don't break---- they just become stairs!
Woodreau
Tue Oct 07, 2008 5:56 am
Quoting AAH732UAL (Reply 2):
I doesn't matter whether SA is turned back on again. The whole point of WAAS/LAAS and differential GPS is that the ground reference stations know exactly where they are located. (They've been surveyed) And if there is a degradation of the accuracy of the position reported by GPS, that ground station knows what that difference is and transmits a correction signal for GPS units in a certain area to correct the "SA" degraded GPS signal. Correction signals for WAAS comes from one of two satellites in orbit.
I doubt the military uses the encrypted PPS GPS signal anymore - commerical GPS units using the civil SPS signal (with correction) are so much more accurate.
AAH732UAL
Tue Oct 07, 2008 12:24 pm
Quoting Woodreau (Reply 3):
Exactly but IF they ever put it back on, we in the US has other ways to get the GPS and augmented GPS signals......
I know the planes I fly have MSAS augmentation along with WAAS. Again though I doubt SA will ever come back b/c a lot of civil aviation w/o the above augmentation systems to correct SA would grind to a halt.
[Edited 2008-10-07 05:38:53]
jgarrido
Tue Oct 07, 2008 3:18 pm
For what it's worth the military said that the next generation of GPS satellites will not have the capability of SA. I know it's the military talking, so don't shoot the messenger.
http://www.defenselink.mil/releases/release.aspx?releaseid=11335
AAH732UAL
Tue Oct 07, 2008 5:46 pm
Quoting Jgarrido (Reply 5):
Hum..... still right now most of the satellites have SA. Like IIRC there is 31 now up and about. So maybe only about 3 or 4 fall under that letter you posted.
KELPkid
Tue Oct 07, 2008 6:20 pm
Nothing like having the dreaded "RAIM Unavailable" flash in your face in the middle of an approach...(okay, okay, my flight instructors and I were too lazy to do a RAIM check for each approach while shooting multiple approaches...on instrument flight lessons Big grin ). Technically, though, a GPS approach is an RNAV approach, which means that any IFR-approved RNAV system with coverage in the area could be used for the approach, as long as it has all the waypoints in its database, however I don't think I've seen a working LORAN-C panel mounted unit in at least a decade...
Next time you drive on I-10 between Las Cruces, NM and Deming, NM, wave to the mid-continent LORAN chain transmitter next to the interstate  wave
Fly2HMO
Wed Oct 08, 2008 2:00 am
Quoting KELPkid (Reply 7):
What?!?! I drove by a Loran site without even realizing it 8 times!?!?  banghead
Must not be anything special, since all the antennas I saw the whole way looked like your average cell phone antennae.
KELPkid
Wed Oct 08, 2008 5:33 pm
Quoting FLY2HMO (Reply 8):
Well, a Loran site is a wee bit taller, the tower is 722'...  Wink From the air, it's pretty unremarkable, it looks like a rather tall AM broadcast tower. On the ground, it's a fully functioning mini US Coast Guard station... kinda wierd in the middle of a landlocked state like New Mexico. Your tax dollars at work-keeping "obsolete" navigation systems functional.
Wonder why LORAN was deemed obsolete? It seems a terrestrial-based system has to be eons cheaper to maintain than a constellation of satellites...I guess for the FAA, it doesn't matter either way, as one way the Coast Guard was paying for the system, the other way the Air Force is paying for it.
AAH732UAL
Wed Oct 08, 2008 5:38 pm
And the approach has to be Line Selected by name. I know you know that BUT you would not believe how many people there are that think you can hand build and RNAV approachs/SID/STARs.
Also IIRC all GPS stand alone approaches are being converted/redesigned to RNAV(GPS) approaches
Quoting KELPkid (Reply 9):
Well GPS is more actural and has can do a lot more things...... IE (RNP) approaches, LPV, etc etc. I would bet that GPS has a lot more functions that can be made then LORAN did.
[Edited 2008-10-08 10:40:06]
KELPkid
Wed Oct 08, 2008 6:00 pm
Quoting AAH732UAL (Reply 10):
The only one I can think of is that you can derive altitude from GPS, whereas LORAN is LNAV-only...a handy feature for the new RNP approaches  Wink
AAH732UAL
Wed Oct 08, 2008 6:40 pm
Quoting KELPkid (Reply 11):
No MRAs and not limited by line and sight and stuff like that prolly
Can augment the signal for even more precision
WAAS VNAV for LPV approaches
Less money to keep keep the facilites working
List goes on
[Edited 2008-10-08 11:46:29]
KELPkid
Wed Oct 08, 2008 7:04 pm
Quoting AAH732UAL (Reply 12):
Nah, LORAN is (was?) based on MW radio (below the AM broadcast band), which propogates quite well beyond the line of sight...  Wink There was one minor disadvantage to this: the MW radio signal was susceptible to interference by electrical storm activity.
AAH732UAL
Wed Oct 08, 2008 8:43 pm
Quoting KELPkid (Reply 13):
Aw ok..... I was unsure if there was actual line of sight problems, I just threw it to see if it would stick  Smile
Northwest727
Sat Nov 01, 2008 4:57 pm
I didn't even think that LORAN-C was approved for approaches...I thought LORAN-C was for enroute navigation only (?).
rwessel
Sat Nov 01, 2008 11:16 pm
Last time I saw budget numbers (around 2000), the ongoing cost to maintain the LORAN-C system in the US was on the order of $15m/yr. IOW, two or three percent of what's spent on the GPS system.
IMO, LORAN presents an interesting compliment to GPS. For almost no money, it provides a system with similar, if not quite as good, functionality, while being completely independent in essentially all operating parameters. So it makes a very nice backup, and can even be used to improve GPS accuracy with the appropriate mixing (shades of WAAS). That and some minor* enhancements to LORAN, significantly increased LORANs accuracy (20m or better in most cases). And there's rather less to a LORAN receiver than A GPS receiver
*While some of the eLORAN improvements needed some upgrades at the transmitter (primarily a data channel is now broadcast with the signals, plus a good clock for timing), much of the improvement happened at the receiver, which does things like use more stations (all of the ones you can see - often 20-30, and up to 40 at times - and since they're all better synced now, you can almost think of the entire array as being one huge chain), plus the receiver can use phase information on the carrier to improve distance measuring (shades of VLF/Omega). Those upgrade are pretty much all done in the U.S. (total cost over five or six years was $140m).
411A
Thu Nov 06, 2008 6:01 pm
Quoting Northwest727 (Reply 15):
Several were published in the 1980's but withdrawn later on.
Loran C is highly accurate...within ten to twenty meters, at many US mainland positions.
Years ago, even Loran A was quite good, provided lane skip was not a problem...within one mile error over the Pacific, 1500 miles from the west coast.
LORAN...a British designed navigation system.
Works good.
AAH732UAL
Thu Nov 06, 2008 9:57 pm
Quoting 411A (Reply 17):
GPS is even more accurate and augmented GPS is yet even more percise. Plus its cheaper  Cool
rwessel
Fri Nov 07, 2008 12:25 am
Quoting AAH732UAL (Reply 18):
Small GPS receivers are certainly cheaper due to the high volume they're built in. That's not true of aviation certified units, which are inherently very low volume. In that case you'd expect that the rather simpler LORAN receiver has at least a shot at being cheaper than a GPS receiver. In any event, much of the cost is not in the physical receiver, but in the stuff attached to it.
If we're talking about the infrastructure, there's no comparison - GPS is hugely more expensive.
Users browsing this forum: Woodreau and 3 guests
