747400sp
How Safe And Strudy Was The A300?
Wed Oct 08, 2008 2:05 am
Growing up, I was told all kind of stories of how the A300 was falling out of the air left and right in the 70's. I have looked at the accident record of the A300, and fond out it was the only first generation wide body not to have a fatality in the 70's. I would say it safer than a 747 looking at it's record, but then I can not rule out that AA crash in 2001 ware that newer model A300 tail riped off because of over steering.
So here is my question, is the A300 a well built plane? If so was it as well built as the US built first gen widebodies?
Sasha
RE: How Safe And Strudy Was The A300?
Wed Oct 08, 2008 2:20 am
I am no tech expert with A300 but the fact that only last year they shipped the last one off the conveyor belt, tells some story. Imho, it's a well built plane, yes. As for the AA over steering - the accident is reported to have resulted in AA amending their pilot training procedures, which would suggest it probably wasn't the plane sturdiness issue but poor airmanship? Gee, I mean... if flaps are deployed at speed exceeding their limit.. they gonna eventually come off just as easily, won't they.
An2/24/28,Yak42,Tu154/134,IL18/62/96,B737/757/767,A310/320/319,F100,BAe146,EMB-145,CRJ,A340-600,B747-400,A-330-300,A-340
Nicoeddf
Wed Oct 08, 2008 2:22 am
Do you have any serious doubt?
Me thinks a plane proofs its sturdiness over the life cycle. The 300 has done exactly that.
Hence, no doubts from my part why the 300 shouldn't be well built. After all, the Airbus engineers in the 70s didn't exactly come out of the toy industry but were experienced professionals.  Wink
Enslave yourself to the divine disguised as salvation
that your bought with your sacrifice
Deception justified for your holy design
High on our platform spewing out your crimes
from the altar of god
Wed Oct 08, 2008 4:20 am
Quoting 747400sp (Thread starter):
Doesn't count. There was nothing wrong with the aircraft. The rudder control may have been "oversensitive" but the pilot should not have touched it anyway.
Wed Oct 08, 2008 8:39 am
Any Examples of these stories.....A300s seem to be very good at IC until they were retired a few years ago.The only complain some Mx folks had of them were of Hydraulic wetness in the areas of Hydraulic lines every where.
regds
MEL
Viscount724
Wed Oct 08, 2008 9:21 pm
In fact there were no A300 crashes or hull losses for any reason in the 1970s. Both the A300 and A310 went more than 10 years between their first flight and first hull loss, a much better record than other widebodies of that era especially when considering the higher number of sectors flown by the A300 due to its shorter range. And few A300/310 hull losses to date appear to involve design issues,certainly no more than any other widebodies. Most A300/310 hull losses were the result of pilot error, terrorism, being shot down, fires during maintenance and a variety of other causes.
For information, the number of hull losses during the 10 years after their first flights.Many losses of other types also for reasons unrelated to the aircraft type.
A300......0
A310......0
L1011....3
747.........8
DC-10....8
[Edited 2008-10-08 14:27:54]
474218
Wed Oct 08, 2008 9:55 pm
The following statics are from the "Flight Safety Network" web site:
Aircraft - Hull Loss Accidents - Fatalities
A300 - 17 - 1126
A310 - 8 - 673
A330 - 2 - 7
A340 - 2 - 0
747 - 39 - 2350
767 - 6 - 539
777 - 1 - 0
DC-10 - 26 -1261
MD-11 - 5 - 235
L-1011 - 7 - 534
Based on these numbers the A310 is slightly safer than the DC-10.
Wed Oct 08, 2008 11:38 pm
Quoting 474218 (Reply 6):
A300 - 17 - 1126
A310 - 8 - 673
A330 - 2 - 7
A340 - 2 - 0
747 - 39 - 2350
767 - 6 - 539
777 - 1 - 0
DC-10 - 26 -1261
MD-11 - 5 - 235
L-1011 - 7 - 534
Those statistics are unfortunately useless. They do not account for number of flights, flight hours or cause of accident. For example the 330 accident was during a test flight, not indicative of real life ops.
474218
Thu Oct 09, 2008 1:10 am
Quoting Starlionblue (Reply 7):
You are correct. However, they are every bit as usefull as these!
Quoting Viscount724 (Reply 5):
A300......0
A310......0
L1011....3
747.........8
buckfifty
Thu Oct 09, 2008 2:49 am
Quick Google search came up with this:
http://www.airsafe.com/events/models/airbus.htm
# 27 June 1976; Air France A300; Entebbe, Uganda: Aircraft was hijacked and all aboard taken hostage. Some passengers were released shortly after the hijacking and the remainder were taken to Entebbe, Uganda. The remaining hostages were eventually rescued in a commando raid. About seven of the 258 passengers were killed.
# 3 July 1988; Iranair A300; Persian Gulf, near Straits of Hormuz: Aircraft was shot down by a surface to air missile from the American naval vessel U.S.S. Vincennes. All 16 crew and 274 passengers were killed.
# 28 September 1992; Pakistan International Airlines A300B4; near Katmandu, Nepal: The crew was flying the aircraft was flying an approach about 1300 feet (400 meters) lower than planned when the aircraft collided with high ground. The event happened in daylight and with cloud shrouding the mountains. All 12 crew and 155 passengers were killed
# 26 April 1994; China Airlines A300-600; Nagoya, Japan: Crew errors led to the aircraft stalling and crashing during approach. All 15 crew and 249 of the 264 passengers were killed.
# 24 December 1994; Air France A300; Algiers Airport, Algeria: Hijackers killed 3 of the 267 passengers. Later, commandos retook the aircraft and killed four hijackers.
# 26 September 1997; Garuda Indonesia Airways A300B4; near Medan, Indonesia: The aircraft was on approach to Medan on a flight from Jakarta when it crashed in a mountainous area about 19 miles (30 km) from the airport. Extensive smoke and haze from numerous forest fires caused reduced visibility in the area. All 12 crew members and 222 passengers were killed.
# 16 February 1998; China Airlines A300-600; near Taipei, Taiwan: The aircraft crashed into a residential area short of the runway during its second landing attempt. The scheduled flight had been inbound from the island of Bali in Indonesia. The event occurred under conditions of darkness with rain and reduced visibility due to fog. All 15 crew and 182 passengers were killed. At least seven persons on the ground were also killed.
# 24 December 1999; Indian Airlines A300; near Katmandu, Nepal: The flight was hijacked shortly after takeoff. The hijackers killed one of the 173 passengers, but none of the 11 crew members.
# 12 November 2001; American Airlines A300-600; Queens, New York: The aircraft was on a flight from New York to Santo Domingo, Dominican Republic when it crashed into a residential neighborhood just outside JFK airport. The aircraft experienced an in-flight breakup, with the vertical fin and one engine landing away from the main impact site. The crash damaged or destroyed several homes, and killed five people on the ground. Also killed were all nine crew members and 251 passengers on the aircraft, including five infants.
Doesn't sound like there were any hull losses attributed to the type because of an inherent design flaw, but I could be wrong.
Viscount724
Thu Oct 09, 2008 4:11 am
A300 - 17 - 1126
A310 - 8 - 673
A330 - 2 - 7
A340 - 2 - 0
747 - 39 - 2350
767 - 6 - 539
777 - 1 - 0
DC-10 - 26 -1261
MD-11 - 5 - 235
L-1011 - 7 - 534
You seem to have excluded some hull losses from your totals. Did you not include terrorist incidents for example? Aviation-safety.net (assume that's the site you're referring to) shows the following total "hull loss occurrences" which includes losses of all types (terrorism, hangar fires etc.) Many of the numbers are higher than yours, for example 25 A300 hull losses (vs 17). Fatality totals also much higher than your numbers in some cases (e.g. 747 fatalities 3760 vs your 2350). Fatality totals below include those on the ground except those in the 9/11 767 crashes. Was just curious what you excluded to account for such large differences in some numbers.
A300 - 25 - 1438
A310 - 8 - 673
A330 - 4 - 7
A340 - 5 - 0
747 - 47 - 3760
767 - 11 - 851
777 - 1 - 0
DC-10 - 30 - 1442
MD-11 - 5 - 240
L-1011 - 11 - 553
474218
Thu Oct 09, 2008 4:21 am
Quoting Viscount724 (Reply 10):
Because I don't think a "hull loss due to hijacking" should be held against the airframe.
soon7x7
Thu Oct 09, 2008 1:52 pm
All aircraft have a stat list for one reason or another but in answer to your question...the a300 proved itself over a timely record...it was the first major transport to incorporate a perfectly round pressure vessel as this results in optimum fuselage strength. Earlier models were introduced with all metal tail feathers and later models retro fitted with carbon tail feather assemblies. Earlier models even had outboard ailerons...currently spoilerons are used along with inboard high speed ailerons but no outboards. On one trip to the carribean we edged around a hurricane in an AA A300. We got the sh-t beat out of us. I was afraid the superstructure was going to come apart...but as luck would have it...it did not...aircraft still in service today...
474218
Thu Oct 09, 2008 2:59 pm
Quoting Soon7x7 (Reply 12):
Could you explain this statement. What do you mean by "first major" to incorporate a "perfectly round".
kimberlyRJ
Thu Oct 09, 2008 6:05 pm
From what I understand the Airbus A300 was the type of aircraft that would fly no matter what was thrown at it. It did suffer a lot of technical issues, however once these were ironed out the aircraft (A300-600 series) became a very reliable aircraft which still flies in many fleets today.
A300 - 17 - 1126
A310 - 8 - 673
A330 - 2 - 7
A340 - 2 - 0
747 - 39 - 2350
767 - 6 - 539
777 - 1 - 0
DC-10 - 26 -1261
MD-11 - 5 - 235
L-1011 - 7 - 534
Would we not need to know total hours, amounts that were built etc
I would like to know what Airbus A300's pilots feet about her!? Anyone know if there are any on this site?
Kimberly.
David L
Thu Oct 09, 2008 6:41 pm
You may have seen a little of such nonsense here. There have been a few members whose "dad knew a guy, who knew a guy, who knew a guy, who said Airbus make inferior aircraft". When pressed for details, they usually fell silent. Funny, that.  Smile
stratosphere
Sat Oct 11, 2008 1:52 am
Quoting SashA (Reply 1):
One problem notorious for both the A300 and the 310 is in the cargo environment is if you let these aircraft sit for more than a day you will have fuel leaks out the ying yang. Fuel and fuel qty issues plague this fleet at FedEx.
474218
Sat Oct 11, 2008 3:21 am
Quoting David L (Reply 15):
When Eastern first started flying the A300 a group of us went to LAX to check one out. My first impression was that you could really tell it was made by a consortium. Fuselage joints between major sections did not line up, the wings looked like they were installed half way up on the fuselage, the main landing gear seemed like it was as long as a Connies nose gear and the raised floor in the aft cabin just cemented my option.
However, I have flown on the A300 and A310 found them provide a smooth comfortable ride. The only complaint being how the sidewalls will not allow you to set straight up in a window seat.
MD11Engineer
Sat Oct 11, 2008 4:03 am
Quoting Stratosphere (Reply 16):
I've discussed this issue with a guy who worked for Fedex (I used to work for a few years for the other big US cargo company or similar aircraft).
We had similar issues with our brand new A300-600s, but we traced down the fuel qty issues to production swarf (drill shavings, rivet heads etc.) being left inside the wings after manufacturing and thus shortening out the fuel probes, setting the fuel qty system inop, which then would affect other aircraft systems, like flight management, auto trim etc..
On one aircraft, we removed a whole bucket full of drill shavings etc. from the inside of a wing and the plane was just a few weeks old at this time.
Once these quality issues were ironed out in conjunction with the manufacturer (I assume some people in Airbus's wing plant in Filton, England, got a sound b*ll*cking for not cleaning up after finishing their work), the planes proved to be very reliable.
BTW, we didn't have any problems with fuel leaks.
Jan
Sat Oct 11, 2008 8:46 am
Quoting MD11Engineer (Reply 18):
Amazing that Airbus Quality control did not ensure these cleanings.
regds
MEL
David L
Sat Oct 11, 2008 6:49 pm
Quoting 474218 (Reply 17):
Strange - there didn't seem to be that problem on the earlier Concorde programme.
But weren't they pretty much the way they were meant to be?
I think the reason for this was discussed fairly recently - optimising the passenger deck and cargo deck, rather than just the passenger deck.
474218
Sat Oct 11, 2008 9:48 pm
Quoting David L (Reply 20):
It is clearly visible in this photo of an A300. The skins appears to be a patch work pattern.
Photo © Juan Carlos Guerra - APM
Notice on the 767 how the skins panels are straight and the seams symmetrical.
Photo © Carlos Borda
airxliban
Sun Oct 12, 2008 5:18 am
Surprised that no one has mentioned the DHL A300F that got shot out of the sky over Baghdad and still managed to make it back safely to SDA:
Photo © Speedbird999
soon7x7
Sun Oct 12, 2008 5:46 am
Quoting 474218 (Reply 13):
Round pressure vessels were found to be stronger over all with less flat spots or zones that over time were prone to fatigue such as the section 41 on the 747 which has flat surfaces and has since had formers redesigned,to combat cracking and other fatigue issues. The typical boeings and DC series aircraft as I'm sure your aware of, in cross section, use the double lobe design. In it of itself, this design has proven a great design but from a cost/production standpoint...the round tube was easier/cheaper. The 747 actually incorporates the round vessel as does the 777. Not sure about the 787 as I have not been following it like most a/netters but my guess is given the Carbon Fibre/ Barrel design...it too probably utilizes a round cross section. I'm sure I'll be corrected on that one...
474218
Sun Oct 12, 2008 5:03 pm
Quoting Soon7x7 (Reply 23):
The above did not answer my question: You said the A300 was the first "major transport" to use a "perfectly round" fuselage. I wanted to know how you came to this conclusion? I know of several "major transports" that used "perfectly round" fuselages before the A300.
David L
Sun Oct 12, 2008 6:30 pm
Quoting 474218 (Reply 21):
The variations in texture and colour don't seem to help and AA's (lack of) livery might exaggerate the issue. I'm still not sure how that makes it "inferior" - surely the aerodynamics and structural integrity were more than acceptable? I'm also still struggling to see how the wings were in the wrong place or that the raised cabin floor was evidence of "inferior" design.
474218
Sun Oct 12, 2008 7:33 pm
Quoting David L (Reply 25):
I had to go back and read my reply again because I didn't think I said anything about the being "inferior"? I said the A300 (and most other Airbus designs) looked like it was designed and built by a consortium, several different companies each designing and building their particular portion. Then all these portions are brought to a single location and put together.
David L
Mon Oct 13, 2008 10:04 am
Quoting 474218 (Reply 26):
Ah, it was in response to my comment about Airbus allegedly making inferior aircraft so I just assumed.
Yes, I know... some American expression about a donkey.  Smile
soon7x7
Mon Oct 13, 2008 12:15 pm
Quoting 474218 (Reply 24):
I just made it up...jeeeez!
soon7x7
Mon Oct 13, 2008 10:39 pm
In all fairness I should have stated that it was "one of the first" as the DC-10 and L1011 also had this as did the C-141 however in the sense of the A300,I was being type specific...j
tdscanuck
Tue Oct 14, 2008 5:02 am
Quoting HAWK21M (Reply 19):
I've seen this on other OEM's aircraft as well. The shear number of holes that have to be drilled to assemble an aluminum wing compared to the wing volume make it effectively impossible to catch all the drill cuttings. They'll start out dispersed throughout the wing but, after several weeks of vibration and fuel sloshing in and out they'll migrate to the local low spots (access hatches, bottom of ribs, etc.). I think the only practical way to avoid them entirely would be to take your airframe from the OEM with a lot more hours/cycles on it.
If you have bare skin, like AA, it will always look "patchy" unless the OEM took the extra step to make sure all the skins were rolled in the same direction. Otherwise the grain structure on the surface doesn't line up and you get different reflections off of different skins. It's not at all a design or structural issue, just a cosmetic one.
Tom.
johnclipper
Tue Oct 14, 2008 7:07 am
Maybe AA should have left their A300s painted to avoid that horrible "cosmetic" problem. It's not an airframe problem. I've seen Boeings with that same "problem" as well.
"Flown every aircraft since the Wright Flyer" (guys, if you take this literally, then you need to get a life...)
Wed Oct 15, 2008 12:50 am
Quoting AirxLiban (Reply 22):
That was one fantastic skill of flying.
regds
MEL
474218
Wed Oct 15, 2008 1:28 am
Quoting Tdscanuck (Reply 30):
The way the skin is rolled has nothing to do with the multitudes of seams in the photos of the A300 and the 767 I posted in Reply 21.
Aft of the flight station:
The A300 has at least nine (9) separate longitudinal seams visible in the picture.
The American 767 has only two longitudinal seams, one just above the lower case letters in the American and another just below the outflow valve.
metroliner
Wed Oct 15, 2008 7:03 pm
Quoting 474218 (Reply 33):
So what?
It's a different design.
Doesn't have an ant's arse to do with where it was built, by whom, or why. More how it was designed.  Smile
Set the controls for the heart of the Sun
Users browsing this forum: 113312, mcdu, STLflyer and 26 guests
