Triebwerk
How Fast Does Air Travel Out Of A Turbofan?
Wed Oct 08, 2008 4:38 am
(Assume that the air is traveling out of the jet portion, not the fan portion. I'm talking about the kind of turbofan you would find on a 777, say, or an A380.
tdscanuck
RE: How Fast Does Air Travel Out Of A Turbofan?
Wed Oct 08, 2008 6:40 am
Quoting Triebwerk (Thread starter):
I've been told before that it's very close to Mach 1, although I haven't seen any hard numbers to back that up. It has to be higher than the aircraft's forward speed (typically around Mach 0.8-0.89) but, for noise reasons, wouldn't be supersonic so it's a fairly narrow band.
Tom.
Tristarsteve
Wed Oct 08, 2008 7:15 am
Quoting Tdscanuck (Reply 1):
Well now you made me think. What about when the aircraft is stationary on the ground, is the exhaust speed still M0.9?
What about Concorde? Travelling at M2.2, engine exhaust only M0.9?
I will go away for a think.
Triebwerk
Wed Oct 08, 2008 9:17 pm
There has to be enough force from the air exiting the turbofans to propel the plane forward, of course. Perhaps the answer is as simple as finding the momentum of an accelerating plane, then finding out how quickly the displaced air would have to be traveling to equal that momentum.
(Weight of plane x speed) = (weight of air displaced x speed).
I'm no physics major, though, so I figure this question is best left to someone who knows what they're doing.
WPIAeroGuy
Wed Oct 08, 2008 9:34 pm
Theoretically you want the air moving as close the forward velocity as possible. In practice it will always be moving faster, because if they were equal your mass airflow through the engine would have to be infinite. Treibwerk you're on the right track with the momentum, but I think you're going to have to account for the aerodynamic drag as well. To find the velocity its pretty simple, its T=mdot(u9-u0) where the u's are exit and inlet(aicraft) velocity and mdot is the mass airflow through the engine. The problem is finding the mass airflow, you need engine specific information to find that out. I'll agree with Tom in that its somewhere short of Mach 1 but I'm not sure.
Most supersonic aircraft use low-bypass turbofans because they need the high-velocity air to reach supersonic speeds. The larger the fan, the more air you move, but you move it slower for the same thrust. From the equation above, your thrust will be negative if your exit velocity is slower than your inlet velocity, therefore supersonic planes need thrust, but they must get it from a high exit velocity rather than greater mass airflow.
-WPIAeroGuy
thegeek
Thu Oct 09, 2008 11:00 am
Wouldn't even the bypass air be hotter than the ambient air, so therefore it's supersonic speed would be faster than the aircraft's supersonic speed?
tdscanuck
Fri Oct 10, 2008 5:56 am
Quoting TristarSteve (Reply 2):
Should be, yes.
No, Concorde (and any other supersonic aircraft) has supersonic exhaust. It's subsonic at the back of the engine and accelerated to supersonic speed by a con/di nozzle. This is part of the reason you see variable nozzles on supersonic aircraft but almost never on subsonic.
Quoting Triebwerk (Reply 3):
This is the gist of it, but you really need to do it as (sum of forces) = (change in momentum). You pick up drag in the sum of forces and the change in momentum drives you to delta-speeds, not absolute speeds.
Quoting Thegeek (Reply 5):
Yes, fan air is noticably hotter than ambient, so it has a higher sonic velocity. However, for noise reasons I think you need to stay below ambient sonic, otherwise I think you'd induce shockwaves at the interface between the fan flow and ambient air.
Tom.
UAL Bagsmasher
Sat Oct 11, 2008 12:39 pm
On the CRJ-200, the exhaust speed at maximum thrust is approximately 544 mph measured at 25 feet behind the engine. The temperature of the exhaust at this point is approximately 440 degrees F. These numbers are from the CRJ-200 AMM and the engine in this example is the CF-34.
The same engine at idle thrust produces an exhaust speed of approx. 68 mph at a temperature of approx. 140 degrees F measured at the same location. I hope this helps.
Triebwerk
Sat Oct 11, 2008 11:47 pm
544 miles an hour and 440 degrees at 25 feet away? Hope the people at Juliana make sure to keep their distance.  Smile
On that note, does anyone have any exhaust velocity statistics for rockets? The Saturn V, for example?
jetmech
Sun Oct 12, 2008 3:52 am
If the engine is at idle, I'd hazard a guess that the exhaust velocity would be somewhat lower than M 0.9 . I was recently involved with the marking of a propulsion assignment, where the students were asked to calculate the exhaust velocities of a given twin spool engine operating as alternatively as a turbofan and turbojet.
Obviously, there was a fair bit of simplification involved, but as far as I could tell, the exhaust gas velocities from the various streams were calculated from temperature differences. For the core flow, it was the temperature difference between the LPT discharge and exhaust nozzle exit (To5 - To9).
Getting back to the aircraft being stationary on the ground, I'd say that the core velocity would change somewhat between idle, and say T/O power settings. If we assume that as the power setting increases, that there is more heat discharged from the LPT - and hence a higher To5 - and that furthermore, To9 is ambient temperature and constant, then in theory, the core velocity should be higher compared to lower power settings.
The formula used by the students to calculate the velocity was v = SQRT [ 2*Cp*(To5-To9) ] , with Cp equal to 1005 J / Kg*K .
Quoting Tdscanuck (Reply 6):
Yes, fan air is noticeably hotter than ambient
The fan air velocities were also calculated in the same manner. This time, IIRC, they worked out the temp rise across the fan (To13-To2), assumed it was the same as the temp drop from fan discharge to the nozzle exit (To13-To9), and again, the used the formulae v = SQRT [ 2*Cp*(To13-To9) ].
Quoting WPIAeroGuy (Reply 4):
To find the velocity its pretty simple, its T=mdot(u9-u0) where the u's are exit and inlet(aircraft) velocity and mdot is the mass airflow through the engine.
I think there are two different, but related thrust formulas. The first is from F=Ma, which upon substitution gives N = kg*(m/s^2), which coverts into the impulse - momentum equation, N.s = kg*(m/s). There is also the mass flow rate - change in velocity formula, N = kg/s*[ V exit (m/s) - V inlet (m/s) ].
I think the impulse-momentum and mass flow rate - change in velocity formulas are most often used for aerospace applications. I have seen the impulse - momentum equation used for rockets, and the mass flow rate - change in velocity used for propellers and turbofans.
I'm curious as to whether a high-bypass turbofan would be more efficient if used for supersonic aircraft, compared with the low by-pass devices currently used? As far as I can tell, a CD nozzle works by having a certain upstream stagnation pressure before the throat. If the area ratio of the throat is designed correctly, and exposed to a certain upstream stagnation pressure, the gas should reach sonic velocity at the throat, and then get expanded to supersonic velocity by the divergent part.
In any case, the important thing to me at least, seems to be the large pressure difference across the nozzle that accelerates the gases from sub to super sonic velocities. If this is the case, I wonder if a high-bypass turbofan could be successfully used as the device to supply gasses to a CD nozzle?
Is there something intrinsically unsuitable about a CF-6 for instance that makes it unable to be used for supersonic duties? I understand the large fan of a high bypass device may create drag issues, but if we ignore this, is there anything else making a high-bypass engine unsuitable?
Regards, JetMech
jetmech
Sun Oct 12, 2008 4:01 am
Quoting Triebwerk (Reply 8):
The Rocketdyne F1 apparently had exhaust gases that had a temperature of about 3,200 degees Celcius ( 5,800 Fahrenheit ). The ehxaust gas velocity for the Space Shuttle Main Engine (SSME) is apparently 4,444m/s ( 14,580 fps )
http://en.wikipedia.org/wiki/F-1_(rocket_engine)
http://en.wikipedia.org/wiki/Space_shuttle_main_engine
http://en.wikipedia.org/wiki/SSME_energy_and_power_relationships
Regards, JetMech
WPIAeroGuy
Sun Oct 12, 2008 4:31 am
Quoting JetMech (Reply 9):
I think theoretically it would work, but the inlet diffuser would be so large it wouldn't work well on todays designs. Maybe along the lines of a supersonic BWB?
-WPIAeroGuy
tdscanuck
Tue Oct 14, 2008 8:20 am
The issue is pressure...a C/D nozzle converts pressure to velocity. You need to feed it with high pressure to get high velocity out.
A big fan moves a lot of air with a low delta-V, which is equivalent to a low-delta P. It's like the difference between a high-volume low-pressure pump and a low-volume high-pressure pump...the former is more efficient at moving fluid around *if* you don't need a big pressure differential. Unfortunately, TANSTAAFL and you need a lot of pressure to feed your C/D nozzle.
Tom.
jambrain
Tue Oct 14, 2008 8:36 pm
If you care to put a few sums into an equation
Fundamentals of Compressible Fluid Dynamics By P. Balachandran section 13.2.4 on turbofans
see on Google books:-
http://books.google.co.uk/books?id=K...wqqUMSNccja0q0MuV-QDJaDA#PPA447,M1
but say Trent 1000
Fan diameter: 112 inches (2.85 m)
Take-off thrust: 75000 lbf (flat-rated to ISA+15C)
Airflow: ~2850lb/s
334090 N Force
1295 kg / s Airflow
F=Ma
At full thrust on ground with no forward velocity
260 m/s (that's average not jet portion)
I haven't done the math for jet velocity but one of the examples gives jet velocity of 670 m/s at static temp of 800K
Jambrain
jetmech
Thu Oct 16, 2008 1:47 am
Quoting WPIAeroGuy (Reply 11):
Quoting Tdscanuck (Reply 12):
I see. I was actually thinking along the lines of what you have mentioned. I suppose that an engine used as a motivator for a CD duct would not only need to put out a decent mass flow rate, but also have the ability to develop a good head of stagnation pressure as well. As you have pointed out, a turbojet or low bypass turbofan seem to be the best type of jet engine to provide these requirements.
Regards, JetMech
