FlyASAGuy2005
Flaps Not In Clean Config. On The Ground On RJ
Fri Oct 17, 2008 4:23 am
I noticed this while working with a regional carrier but never thought about it but gave it even more thought tonight off of my DCI flight from PHF to ATL. Flap configuaration on the ground is always in the 8 (?not sure what degree?) position but in the air, the wing is clean after the take-off setting is retracted.
When we landed in Atlanta, the flaps were brought up and again, stopped in the position before 0.
Why is this?
What gets measured gets done.
Sasha
RE: Flaps Not In Clean Config. On The Ground On RJ
Fri Oct 17, 2008 1:31 pm
Have u noticed for the take off if they remained in the same position as before taxiing? Maybe the pilots and engineers around here will confirm that this could be an airline policy on fuel saving or smth?  Smile
An2/24/28,Yak42,Tu154/134,IL18/62/96,B737/757/767,A310/320/319,F100,BAe146,EMB-145,CRJ,A340-600,B747-400,A-330-300,A-340
DeltaGuy
Fri Oct 17, 2008 3:33 pm
Not sure which DL regional you were on, but (IIRC it was Comair or ASA), keeps the flaps down for inspection during the preflight walkaround.
DeltaGuy
dispatchguy
Fri Oct 17, 2008 3:39 pm
There is (well was) an airworthiness directive out on the flaps system that for ground ops, they need to be at flaps 8 - something about the drive system...
Nobody screws you better than an airline job!
thegreatchecko
Fri Oct 17, 2008 4:18 pm
I'm sure there is a good reason, however, I know I once missed bringing the flaps all the way up after we landed.
No big deal really and it probably allowed for a better inspection during the walk around.
"A pilot's plane she is. She will love you if you deserve it, and try to kill you if you don't...She is the Mighty Q400"
pjflysfast
Fri Oct 17, 2008 9:50 pm
I think it may have to do with with the motors. The more cycles its just that much more maintenance on the motors and that takes the aircraft down and cost more money.
BigSaabowski
Fri Oct 17, 2008 10:41 pm
Quoting Dispatchguy (Reply 3):
You got the gist of it. We put the flaps in the planned takeoff position after a landing. So in Atlanta, you will always see the flaps coming up to 8 after a landing. In CRW, for example, the flaps will always go to 20. This is all because of an AD, having to do with the twisting of the outboard flap, that requires a visual inspection prior to every takeoff.
kcrwflyer
Fri Oct 17, 2008 10:43 pm
Quoting FlyASAGuy2005 (Thread starter):
It looks like they keep them at 20 here in CRW.
Is it always 8, or is it the setting that will be used for the next takeoff?
DeltaGuy
Sat Oct 18, 2008 2:48 am
Quoting BigSaabowski (Reply 6):
Dude, I just saw your username....brilliant Big grin
That rug really tied the room together......
DeltaGuy
dispatchguy
Sat Oct 18, 2008 10:24 pm
Quoting KcrwFlyer (Reply 7):
Next subsequent takeoff; I havent dispatched an RJ in a while, so I was going with rusty brain cells.
kcrwflyer
Sun Oct 19, 2008 2:27 am
Quoting Dispatchguy (Reply 9):
That explains why I always see them parked here with 20 in. Is there any reason some operators do this while others dont? ASA and Comair always do, but PSA, Pinnacle, and Skywest park clean.
AAH732UAL
Sun Oct 19, 2008 2:30 am
I think Mesa does this so the pilots won't forget to set them for t/o  Smile
DME/DME RNP0.3 NA -Escalators don't break---- they just become stairs!
kstatepilot
Sun Oct 19, 2008 5:05 am
Quoting AAH732UAL (Reply 11):
Haha, very funny. Actually there is an TSO that you can get that fixes the problem of the flap twisting, costing money, hence we don't but...
Quoting KcrwFlyer (Reply 10):
FlyASAGuy2005
Sun Oct 19, 2008 5:40 pm
As soon as you guys mentioned the AD, my mind started buzzing about a thread about problems with the CR2 flap system.
So what is the deal exactly? Has there ever been any modifications?
dispatchguy
Mon Oct 20, 2008 1:28 am
Quoting FlyASAGuy2005 (Reply 13):
(d) This AD results from a number of cases of flap system failure that resulted in a twisted outboard flap panel. We are issuing this AD to prevent an unannunciated failure of the flap system, which could result in a flap asymmetry and consequent reduced controllability of the airplane.
This is per FAA AD 2006-12-21, which is available from the FAA website.
It appears that there are acceptable modifications, but if the carrier hasnt yet complied with the modification, then they are subject to the original AD.
Users browsing this forum: dragon6172 and 1 guest
