soon7x7
Drilling, Countersinking Kevlar?
Fri Oct 17, 2008 7:25 pm
I'm looking for a supplier that has counter sink bits that are used on Kevlar panels. Tooling for this material is different than most others...any help...is appreciated...
tdscanuck
RE: Drilling, Countersinking Kevlar?
Sat Oct 18, 2008 2:31 am
These guys seem to make them (put "kevlar" in the search field):
https://www.onsrud.com/
Solid carbide with a major cutting tip at the front, I assume to cut the Kevlar fibers before they turn into a string ball around the drill shaft.
Tom.
soon7x7
Sat Oct 18, 2008 3:29 am
Quoting Tdscanuck (Reply 1):
That is correct...thnxmuch....j
vikkyvik
Sat Oct 18, 2008 5:28 am
Interesting, Onsrud is the only company I ran across when I just searched.
I haven't worked with Kevlar before. What, specifically, makes it difficult to machine?
For reference, I work mostly with aluminum, PVC, expanded PVC, delrin, and occasionally steel.
tdscanuck
Sat Oct 18, 2008 6:13 am
Quoting Vikkyvik (Reply 3):
Kevlar has an extremely high toughness, unlike glass or carbon. As a result, you effectively can't pull it or bend it apart, you have to shear it. If your cutter damages the matrix to the point that the fiber is "free", it'll just flop around forever and never get cut. Imagine trying to cut limp fishing line with a knife...you need to get the fiber in tension to stabilize it before you can cut it.
Dupont has a nice guide on this:
http://www2.dupont.com/Kevlar/en_US/...Cutting_Drilling_Sawing_KEVLAR.pdf
Tom.
vikkyvik
Sat Oct 18, 2008 6:34 am
Quoting Tdscanuck (Reply 4):
Interesting, thanks.
I'd imagine Kevlar is much tougher, but I wonder if it's conceptually similar to machining FR-4, which I had to do a fair amount of at my last job. Although, even though FR-4 has woven fibers, they are encased in an epoxy or whatever. But many times, you'd end up with tons of little strings hanging off of a machined edge.
Not to mention, I had to use end mills with the titanium-nitride coating - they could resist higher temperatures, and that FR-4 got HOT if you machined too deep at once (not to mention, the machine I was using didn't have coolant). I ended up machining in depth cuts, probably 0.02" at a time or so.
tdscanuck
Sat Oct 18, 2008 4:11 pm
Quoting Vikkyvik (Reply 5):
Same deal. I think the Kevlar guys call it "fuzz out" or something like that.
Tom.
soon7x7
Sat Oct 18, 2008 10:23 pm
When Kevlar is layed up in the manufacturing process, it pretty much acts like carbon fibre and fibre glass. After the component is cured...it has outstanding strength, just like all the others...the difference I have found is that once cured...the epoxy resins encapsulate the fabric weave and the components seem welded together. That way, due to the resulting stiffness and brittle qualities...the component can be drilled, machined and countersunk with clean results. Just like it is a solid core of a substrate...however Kevlar seems to defy the "we are one" philosophy...the Kevlar fabricated panel, though extremely strong...once disturbed mechanically by virtue of tooling, (drill, scissors, countersinking bits, that sort of thing). The Kevlar wants no part of it unless you use very sharp, specially designed tools, to deal with the stuff. Basically the fibre is encased in the resin till you tool it and it becomes a very tough fabric pain in the a__!, It does not like to be cut, drilled etc...so it frays, it seems to want to just be a layer of fabric sandwiched in some epoxy where as the other fabrics like to become one with the epoxy. The result of tool missuse w/ Kevlar is a sandy colored furry look around the drilled out hole or a sanded edge will reveal sandy color fur or weave. I'm not sure about this but I would not be surprised if it is no longer used on Boeings.
tdscanuck
Sat Oct 18, 2008 11:27 pm
Quoting Soon7x7 (Reply 7):
Still used.
Tom.
soon7x7
Sun Oct 19, 2008 3:56 am
Quoting Tdscanuck (Reply 8):
I suppose if any one could or should perfect techniques dealling with the stuff...it should be Boeing...Thnx...J
tdscanuck
Sun Oct 19, 2008 5:15 am
Quoting Soon7x7 (Reply 9):
Boeing...Thnx...J
No problem. I know it's not used that much...only places where the oddball properties of Kevlar really pay off. Glass and carbon show up a lot more often. It's pretty easy to go off the deep end with aerospace materials if you just look at performance and raw material cost and don't look at manufacturing cost.
Tom.
vikkyvik
Sun Oct 19, 2008 6:55 am
Quoting Tdscanuck (Reply 6):
Interesting, thanks for the explanations.
I think I would pull out my hair if I had to machine Kevlar at work. Lord knows I get frustrated enough with delrin and PVC, and those are cake to machine by comparison.
soon7x7
Mon Oct 20, 2008 3:30 am
Tom,,,thnx on the Dupont listing...it is good info!...J
Users browsing this forum: CrimsonNL, SAAFNAV, TOGA10, trav110 and 2 guests
