litz
How Long Can An APU Run?
Mon Oct 20, 2008 5:35 pm
This weekend was the Wings over Marietta (GA) airshow, and Delta - as they often do - dispatched 'Pinkie', aka N610DL, to the show to fly the Delta flag and help breast cancer awareness.
(aside: no other airline does something like this ... just part of what makes DL so cool)
It was powered up off the APU the entire weekend (or at least for saturday and sunday during the hours of the airshow, probably 8am-5 or 6pm).
Is there a limit to continuous runtime on an APU?
- litz
oly720man
RE: How Long Can An APU Run?
Mon Oct 20, 2008 7:08 pm
I think as long as they've got fuel and oil they'll keep going.
A few years ago we got one for our lab to do experiments with (before H+S raised various worries/issues - noise and fuel storage, mainly - and the plan was abandoned). Anyway, having got the APU (from a Trident) we got a couple of roving engineers from the manufacturers to visit and the impression they gave was that APUs are pretty well indestructable.
jetstar
Mon Oct 20, 2008 7:32 pm
What damages any turbine engine like an APU is starting and shutting down, this creates thermal expansion and contraction. Once running a turbine engine can almost run indefinitely if provided with enough fuel and oil.
APU’s do not have to go through the take off and reverse thrust applications that jet engines go through, they basically run at one speed, which is usually not maximum rpm or egt, so the limiting factors are the wear and tear on the unit and accessories.
Natural gas pipelines use turbine engines to pump the gas along the pipelines. These engines usually run without any accessories attached to them and have a large supply of oil, and use the unlimited supply of natural gas in the pipeline for fuel. I have been told that these engines can run up to 50,000 hours before they are removed for cleaning and servicing.
Tue Oct 21, 2008 9:26 am
Supply Fuel & Oil & run until & autoshutdown occurs. Smile
regds
MEL
CanadianNorth
Tue Oct 21, 2008 1:17 pm
It's just a simple turbine engine; so as the others have said as far as I know as long as it has fuel, air and oil it should - in theory - run as long as you want it to...
CanadianNorth
HS-748, just like a 747 but better!
AA737-823
Wed Oct 22, 2008 1:08 am
Theoretical postulating aside, APUs can run for a VERY long time. It's wasteful and loud- you're much better off to pull up a newer, quiet GPU cart and plug her in. But the APU is certainly up to the task of endless hours of thankless work.
Quoting Jetstar (Reply 2):
Actually, APUs DO run at full RPM. Their minimum RPM is 100% N1 (which is the only N they have!), and aren't considered to be "over-revved" until about 110%, depending on the model.
If the APU gets down to 95% N1, all loads are shed in an effort to save the APU. Sometimes it works, and sometimes you're doomed.
Now, with EGT, you're certainly right. If all you're doing is running the generator, the EGT generally stays at a low 325-350 (on the GTCP85, I'm talking about... I'm sure others are similar). But if you open up pneumatics, the EGT can climb quickly and get ugly.
Newer APUs are MUCH more reliable than the older ones. The older ones had to be changed frequently, and are placarded INOP half the time! But newer designs have addressed issues, and with improved materials, we can see APUs with high numbers of hours between being removed from the airplane.
Users browsing this forum: fr8mech and 25 guests
