josekmlb
MD-88 Question
Wed Oct 29, 2008 7:28 am
Last night we had an MD-88 taxi into the gate with oil on top of the flaps. I never see oil on top of the flaps or the wing, but I have seen it on the bottom and off the engines. I told the capt. while he did his walk around but I never got to ask him where it would come from because we were offloading the plane. I did see him call MTC then check both mains and walk around to the other wing and look at that and then go back to the other side and he talked for a little bit more and that was it.
Does anyone know where that oil would come from? It was more in-bored close to the main gear area but on top of the flaps.
fr8mech
RE: MD-88 Question
Wed Oct 29, 2008 12:16 pm
It was probably grease. After sitting in the airstream, it takes on a look of oil staining. The grease comes from an over-zealous person with a grease gun during routine maintenance. If you don't wipe-off the excess it gets everywhere. Hell, even if you do wipe it off, it shows up in the dardest places.
Dalmd88
RE: MD-88 Question
Wed Oct 29, 2008 6:31 pm
Sounds like hydraulic fluid to me. I would bet the fitting on the top of the gear extend actuator.
josekmlb
RE: MD-88 Question
Fri Oct 31, 2008 7:02 am
Yeah it could of been grease as well thanks for the repleys.
FBU 4EVER!
RE: MD-88 Question
Thu Nov 27, 2008 5:27 pm
Could also be a leaking actuator for the inboard ground spoiler panel. The flap sections retract and stowe underneath the spoiler panels hence oil on top of the flap surface.
"Luck and superstition wins all the time"!
AA737-823
RE: MD-88 Question
Fri Nov 28, 2008 3:51 am
My vote would be a leaky spoiler actuator. It can actually be quite common (cough cough, 757 cough) to see skydrol seeping toward the trailing edge on the upper surface of the wings.
RE: MD-88 Question
Fri Nov 28, 2008 8:01 am
Sounds like a dynamic leaking spoiler actuator.
regds
MEL
Users browsing this forum: asepmauldi, joelliot and 1 guest
