A346Dude
Cessna 172 POH (Fuel System Schematic)
Thu Oct 30, 2008 1:04 am
Does anyone have a copy of the 172 POH, and would be kind enough to scan the fuel system schematic? I have a presentation on the 172, and even went to the trouble of ordering a POH from Essco, but I don't think it's going to arrive in time (looks like it got held up at the border). Specifically, I am looking for the 1974 172M (or any model with a gascolator instead of a fuel strainer) but I won't be picky! Major thanks to anyone who can help me out.
A346Dude
[Edited 2008-10-29 18:11:13]
You know the gear is up and locked when it takes full throttle to taxi to the terminal.
Northwest727
RE: Cessna 172 POH (Fuel System Schematic)
Thu Oct 30, 2008 1:15 am
All I have is the 172R, will that work?
Northwest727
Thu Oct 30, 2008 1:35 am
These are scans of the 172R PIM, hope this at least helps out somewhat, though I know there are some differences in the fuel system between the -Ms and the -Rs
Big version: Width: 1014 Height: 1700 File size: 190kb
Big version: Width: 1020 Height: 1700 File size: 186kb
On the 172R, one is for serial#s 17280001-17281187
The other is for 17281188+
DiamondFlyer
Thu Oct 30, 2008 1:53 am
Best I can do for you is the same, a C172R model, or even the C172S model. The only difference there is a slightly different setup for fuel gauges, being digital for the G1000. If you want that one, I can get it scanned in for you.
From my cold, dead hands
A346Dude
Thu Oct 30, 2008 2:20 am
Thanks Northwest, those will work.
Only thing is the aircraft in question has 1 drain per wing tank and a gascolator. If anyone has something close to this please let me know. Otherwise I will use the 172R and just explain the difference.
Northwest727
Thu Oct 30, 2008 2:53 am
Quoting A346Dude (Reply 4):
Yeah, these are the newer 172s, with the 5 drains/wing and the 3 drains on the bottom of the fuselage, near the engine. When do you need the drawings? I might be able to get an older 172 manual scanned tomorrow...
DashTrash
Thu Oct 30, 2008 3:03 am
When do you need this by?
A346Dude
Thu Oct 30, 2008 3:05 am
Quoting Northwest727 (Reply 5):
Ironically, my presentation is on an engine failure due to water contamination which probably would have been prevented if the aircraft had 5 drains!
The presentation is on Friday so I would need it by tomorrow night. Don't go to great lengths as the ones you have sent already are good enough if necessary.
Illini_152
Thu Oct 30, 2008 4:26 am
Another difference is the additional header tank, and the fuel pumps the in R/S models for the fuel injection system that the previous models did not have.
Happy contrails - I support B747Skipper and Jetguy
Northwest727
Thu Oct 30, 2008 7:39 pm
I'm sorry, all I could find was a 1982 Cessna 172RG model PIM. It's fuel system is closer to a mid-70s model than the 172R, however, it has a electric boost pump on it, so still not quite the same.
A346Dude
Thu Oct 30, 2008 7:51 pm
Quoting Northwest727 (Reply 9):
Thanks for checking.
ThirtyEcho
Sat Nov 01, 2008 10:55 am
You need this by when?
I have C172 POHs going back to 1956; up in the attic, dig, root, root, dig.
You want my hand-calculated Vref speeds for a 1960 Skylark? Nope? OK, more digging.
A346Dude
Sat Nov 01, 2008 3:13 pm
ThirtyEcho,
Thanks but the presentation was yesterday.
Users browsing this forum: Bing [Bot] and 1 guest
