Mastropiero
Do Both Pilots Have To Wear Their Headsets?
Tue Nov 18, 2008 9:23 pm
Hi everyone!
I am asking this because it is something I have always taken for granted, that is, that both pilots would have to wear them, particularly during the critical parts of a flight.
However on the next image the captain does not wear it, albeit they are close to landing.
Photo © Ismael Jorda
What are the rules about this? In case of a medical emergency - meaning, the PIC suffers a stroke - would not be more practical if the PNF was wearing his headset as well? I now that first you aviate, then you navigate, then you communicate but still..... one less thing to do when you have to fiddle around with the airpline on your own...
Thank you!
cptspeaking
RE: Do Both Pilots Have To Wear Their Headsets?
Tue Nov 18, 2008 9:38 pm
Just because they aren't wearing a headset doesn't mean they aren't on the radios...they could have the speaker on instead. Headsets become very uncomfortable after about 30 seconds  Smile
And technically, most times the PNF is the one on the radios...
Your CptSpeaking
...and don't call me Shirley!!
CosmicCruiser
Tue Nov 18, 2008 9:55 pm
In the US FAR 121.359g says the crew will wear headsets and boom mikes below FL180. Above crew's choice
airbuster
Tue Nov 18, 2008 11:04 pm
i saw that photo and it was the first thing i noticed, the captain not having his headset on whilst performing the approach!!
At our airline it is mandatory to have your headset on below 10.000ft. And i consider it good airmanship as it increases the communication aspects in the flight deck. It is much easier to misunderstands commands from the other pilot or atc whilst not wearing your headset. And during approach there can be a lot of sound, gear, rain, engines, callouts....even more so, what if the captain has to take over control because of incapacitation of his FO like you said, is he going to fly the plane and hold the hand mic in his hand? no way....he cannot do a single pilot manual go around and grab the mic or put on his handset in that time frame.
If he can i would gladly see a demonstration of his skills.
just not my cup of tea.
rgds
ab
[Edited 2008-11-18 15:07:06]
FLY FOKKER JET LINE!
AAR90
Tue Nov 18, 2008 11:36 pm
All this photo shows (if you look closely enough) is that the FO is wearing an over-the-head type of headset and the CA is not. That does not mean the captain is not wearing a headset, just that it is not an over-the-head style one [such as that hanging on his side bulkhead. For all we know he could be using an in-the-ear style boom-mic set.
Tue Nov 18, 2008 11:53 pm
It also depends on the aircraft. Some cockpits are much noisier than others, more or less requiring headsets if you want to hear the radio and each other. Others are quieter, so apart from regulations there is no problem without the headsets.
airbuster
Wed Nov 19, 2008 9:34 am
the question still remains, how is he going to handle the single pilot go around? At busy airports i'd like to make a atc call fairly quickly....but i guess he'll just wait a few seconds then....
BTW, on the FO side you see the headset cable running to the right of the picture, i can't see it anywhere on the captains side. The only other thing that crossed my mind was that the headset was U/S!
rgds
ab
CosmicCruiser
Wed Nov 19, 2008 1:11 pm
Quoting Airbuster (Reply 6):
At least here you wouldn't dispatch in that condition. Another station would be deferred and that headset put on the capt.s side, eg. an observers seat headset. There should be a spare in the cockpit as well. If the headphone jack failed inflight then there's nothing else to do. Maybe he was a little forgetfull. There's not many cockpits quiter than the MD-11 but we still wear them up to 180 and if I'm flying into a country that I may have a hard time understanding the controller then I'll wear them all the time. That's when I wish I had the Bose on my head. I used a F/Os pair once and there was a big diff in clarity but at this point in my career I'm not going to spring for a $1000 headset.
Wed Nov 19, 2008 10:26 pm
Quoting CosmicCruiser (Reply 7):
Are you saying if the spare headset is also u/s on a transit station.The Aircraft will not be despatched?
regds
MEL...
CosmicCruiser
Thu Nov 20, 2008 12:55 am
Hawk21M, greetings! I've never seen such a situation because there are headsets at each position in the cockpit and a spare and most stations have them. I'm waiting for a more definitive answer from a more informative source here and I'll explain my lack of a good answer tomorrow. There's an interesting twist here. Thanks for your patience. CC
AAR90
Thu Nov 20, 2008 8:02 am
Quoting HAWK21M (Reply 8):
For AA 738s, you may dispatch without ANY boom mic operating; however, (a) the FDR must be operative, (b) the hand mic for that station must be operative; and (c) AA has 3 calendar days to repair the boom mic for that station. I'm sure other AA planes have a very similar MEL allowance. Not sure what any other airline allows though.
CosmicCruiser
Thu Nov 20, 2008 3:18 pm
I wanted to verify my interpretation of the FARs and our ops before I spoke but yes the rule is the headphones/mike are deferrable in the MEL for 3 days and our policy states that according to FAR 121.359g each crew will wear a headset/boom mike below 180 UNLESS deferred by the MEL. As I said I've never seen it in reality because heads are plentiful and jacks don't fail that often.
pilotpip
Thu Nov 20, 2008 5:25 pm
Our aircraft were equipped with 3 headsets. 2 needed for dispatch. If one was missing/inop nobody got to use the jumpseat even if they had their own.
DMI
pilotaydin
Thu Nov 20, 2008 5:40 pm
at our company, the SOP for most a/c state that above 10,000feet you can take off the headset during a climb out, but during approach it would be wise to keep the sets on as of TOD because you're tired, in an unfamiliar airport perhaps, and so on...
The only time there is too much fuel onboard, is when you're on fire!
Users browsing this forum: HA_DC9 and 1 guest
