kevin
Trans Pacific Emergency Airports
Tue Nov 18, 2008 7:52 am
During my recent trip from Tokyo to Vancouver the inflight map showed the aircraft flying right above the Pacific with the nearest land being too far. So let's say there is an emergency where would an aircraft land. Aleutian Islands? Do they have the necessary infrustructure?Or can a twin jet make it to US or Canada on one engine?
Very interesting to hear what experts say.
denverdanny
RE: Trans Pacific Emergency Airports
Tue Nov 18, 2008 8:04 am
Not an expert here, but I was reading about each of the outer Hawaiian Islands recently. Apparently, Midway Island is an emergency landing spot. Could be wrong about that though. Sounded like the airfield there is maintained for that purpose.
HAL
Tue Nov 18, 2008 8:18 am
For any overwater flight in a twin-engined aircraft, it is mandatory to have alternate airports within the designated ETOPS range (normally about 3 hours) on one engine. Fuel calculations must allow for diversion to these airports with adequate reserves. For longer flights (like your NRT-YVR, or the HNL-SYD I often fly) there are several planned diversion airports along the way, so that there is at least one within that 3-hour window at all times.
Each of the airports must meet certain requirements for runway length, rescue equipment, and current weather. So the short answer is - no, you aren't stuck at any point in your flight with no place to land in an emergency.
HAL
One smooth landing is skill. Two in a row is luck. Three in a row and someone is lying.
pqdtw
Tue Nov 18, 2008 9:58 am
Quoting DenverDanny (Reply 1):
I had a medical emergency landing back in 1989 on Midway Island working NRT-HNL (or the other way around--can't remember) on the 742. If I remember correctly, there was one runway with no parallel taxiways, and we had to be pushed back all the way down the runway so that we could take off again. I was just in my first few months of flying so I didn't quite understand how strange that emergency landing was at the time. I thought it happened all the time... Wish I had taken pictures and written down more so I could remember the experience all these years later...
chapavaeaa
Tue Nov 18, 2008 12:58 pm
I had a aquaintence that wound up taking nearly six months to visit every single (and I do mean every one) of the potential alternate airports for American Airlines. He visited Pacific islands that only had one flight per week and Russian airports in the winter. Military airports...everything. He had pictures and detailed reports on all of the capabiliities ranging from runway conditons to actual de-icing conditions. He had stories to last him a lifetime. It really wasn't that many airports when it came down to it...the problem was that many of these were so remote they only had service once or twice a week....the scheduling to do all the visits was the really tough part.
atcrick
Tue Nov 18, 2008 1:08 pm
Wake Island is always on stand-by for any emergency airline operations. I had a chance to go over there a while back (glad I turned it down), and that was one of the job descriptions for people associated with the airfield.
natch!!
andrew
Tue Nov 18, 2008 1:15 pm
Besides the established internation airports such as ANC, FAI and HNL, the other SQ Pacific ETOPS airports are:
Russian:
Magadan (UHMM)
Petropavlovsk-Kamchatsky (UHPP)
Yuzhno-Sakhalinsk (UHSS),
Khabarovsk (UHHH)
US:
King Salmon (PAKN)
Cold Bay (PACD)
Shemya-Eareckson (PASY)
Midway Atoll (PMDY).
Viscount724
Tue Nov 18, 2008 9:34 pm
Quoting Andrew (Reply 6):
Cold Bay (PACD)
Cold Bay and Shemya were common fuel stops on flights to/from Japan in the propeller era. After the USAF closed the Shemya base in the mid-1950s, NW leased it for several years for use as a technical stop in their routes. The military moved back in sometime in the 1960s but it's still available for ETOPS diversions etc. The 10,000 ft. runway was originally built during WWII and was intended for B-29s on bombing runs to Japan but was never used for that purpose.
A China Eastern MD-11 diverted to Shemya in 1993 after an inflight upset that killed 2 passengers and injured many others.
http://aviation-safety.net/database/record.php?id=19930406-2
GentFromAlaska
Tue Nov 18, 2008 10:58 pm
There are several U.S. Naval vessels which sail from Puget Sound and San Diego to Pearl Harbor.
Several years ago my son asked a similar question to a USAF C5A Galaxy aircraft commander. If a water ditching was imminent they would identify a U.S. Naval vessel, commercial cruise ship or other merchant vessel who participates in the AMVER program and ditch near it.
Depending on how far north you were crossing the pond. I suspect a inflight emergency would be handled by the North Pacific Rescue Coordination Center at EDF Anchorage.
In addition to the islands mentioned above there are airports at Attu Island which is the last island in the Aleutian chain. Kodiak is farther up the chain. Saint Paul island might be another choice. The Coast Guard also does a lot of flying in the north pacific.
Man can be taken from Alaska. Alaska can never be taken from the man.
Arcrftlvr
Tue Nov 18, 2008 11:37 pm
Quoting Kevin (Thread starter):
Depends on how far you are from the US or Canada. You may divert to Asia, Russia, etc. It all depends on distance from the closest suitable airport.
Quoting Pqdtw (Reply 3):
Why wouldn't you have back-taxiied? Seems odd to get pushed all the way down the runway.
chapavaeaa
Tue Nov 18, 2008 11:50 pm
Years ago a friend of mine was
Quoting GentFromAlaska (Reply 8):
Years ago I was on my way into Honolulu from the west coast and a Twin Otter had to ditch due to low fuel. They were only about 200 miles short or so as I recall. They were directed to a freighter or coast guard cutter (I don't remember which) along with a C-130 that circled while they burned off their remaining fuel load. We got to hear a fair amount of it on the "inflight" communciations channel of the entertainment system...three on board...all made it out fine.
COSPN
Wed Nov 19, 2008 12:28 am
CO 772's have diverted to Midway and Cold Bay in the Past, Runway is fine but for Pax there Gooney Birds to watch and a workers canteen in Midway... and the Cold Bay Comunity Center to hang out awaiting for the "rescue flight"...but the name of the ETOPS game is get on the ground...
mtnwest1979
Wed Nov 19, 2008 12:33 am
Quoting ArcrftLvr (Reply 9):
Don't know specs, but perhaps r/w not wide enough to accommodate a 747 to turn around. Or positioning of plane prevented it.
"If it ain't broke, don't fix it!"
sq2ams
Wed Nov 19, 2008 5:29 am
Quoting ATCRick (Reply 5):
ATCRick From United States, joined Jun 2004, 755 posts, RR: 12
Reply 5, posted Tue Nov 18 2008 08:08:15 your local time (15 hours 43 minutes 45 secs ago) and read 1340 times:
All I can say is you missed the time of your life by not going. I spent a year there and although it's remote and you have to attend human being training when you leave and reenter civilization again, it's actually quite busy and is still an active emergency strip for any a/c in trouble. There is no way to describe life on Wake Island, but laid back doesn't even come close. I loved it and tried to go back several times but never made it.
It's The Perception, Not Reality Unfortunately, That You Are Judged By.
don81603
Wed Nov 19, 2008 5:57 am
Quoting MtnWest1979 (Reply 12):
From what I recall seeing in the 80's, there is no room to turn a wide body around at the end of the runway. And the runway isn't really all that long, as I recall either.
Eagles may soar, but weasels don't get sucked into jet engines.
N104UA
Wed Nov 19, 2008 5:58 am
Quoting Chapavaeaa (Reply 4):
Did he do it for Fun or was AA making sure that the airports were suitable
My guess is that the r/w was not wide enough to turn the a/c around
A lot of airlines use 4 engine a/c on those routes so they do not need to fly ETOPS, I know flying LAX-SYD with out 4 engines is longer because they must fly with in ETOPS limits
[Edited 2008-11-18 22:00:26]
"Learn the rules, so you know how to break them properly." -H.H. The Dalai Lama
1KCLAY
Wed Nov 19, 2008 6:32 am
Just curious....Does anyone know what locations Air New Zealand's 777s that fly between LAX/SFO and AKL would use in an emergency and what locations V Australia will use once they start flying. I remember flying to AKL and wondering about it, since there didn't seem to be many islands near our flight path on the onboard flight tracker program.
HAL
Wed Nov 19, 2008 7:58 am
Quoting 1KCLAY (Reply 16):
'Near' is a relative term. Three hours of flying time on one engine equates to nearly 1200 nm. Flying a direct line from LAX to AKL is within the ETOPS range of a 777 almost all the time, although if the winds are blowing the wrong way a slight detour towards Hawaii might be required.
Most airlines that fly ETOPS operations have at least 180 minutes approval, although some (I don't know about ANZ) may have more, which increases the flexibility of routing even more.
Leaving the west coast of the US LAX or SAN could be used, followed by ITO or KOA in Hawaii. After that it would be either CXI (Christmas Island - daytime operations only) or PPT, Papaete, Tahiti. Beyond that, there's no lack of alternates including PPG, APW, RAR, TBU, NAN, and more.
HAL
pqdtw
Wed Nov 19, 2008 8:40 am
Not sure about that. I was a brand-new flight attendant back then and didn't pay attention to the ins-and-outs of it, and didn't realize that that was something really out of the ordinary, so I never discussed it with our pilots. Looking back, I definitely should have. My guess is what others have proposed---that the runway wasn't wide enough to turn the whale around on.
chapavaeaa
Wed Nov 19, 2008 1:07 pm
Quoting N104UA (Reply 15):
He did it for AA. He probably wouldn't have been allowed on a number of the facilities in Russia and Kwajalien for example. I'm not sure how he got a plum assignment other than he was single and nearing retirement.
Viscount724
Wed Nov 19, 2008 10:22 pm
Quoting HAL (Reply 17):
A UA 777 operating AKL-LAX in March 2003 (shortly before they dropped the route) shut an engine down and diverted to Kona, Hawaii. The single-engine diversion took 192 minutes. I believe it was operating under the 180 minute rule but they enountered stronger winds than expected and exceeded the limit by 12 minutes. I think that's also why they went to KOA rather than HNL. I believe that still ranks as the longest single-engine diversion under ETOPS rules.
dynamicsguy
Thu Nov 20, 2008 11:06 am
Quoting COSPN (Reply 11):
A friend had to stop in at Midway during a yacht race for repairs - they'd lost half their mast. They seemed to have a good time there - the residents even fired up the bowling alley for them.
sunrisevalley
Sat Nov 22, 2008 5:28 pm
Where did you get this notion from? Sounds like another of those myths propogated on Anet! AC flies YVR -SYD daily with twins and NZ the same LAX-AKL. The only south Pacific route from the U.S. west coast that encounters greater than ETOPS180 is LAX-PPT. NZ used to fly it with the 767-300ER for which they had ETOPS180 .They flew around the limitation which added about 100nm to the route.
Users browsing this forum: Iemand91 and 1 guest
